Help Center>
Object Storage Service>
Console Operation Guide>
Getting Started>
Logging In to OBS Console
Updated on 2024-05-31 GMT+08:00
You can log in to OBS Console using a web browser.
- Visit the Huawei Cloud official website.
- Create a HUAWEI ID.
If you already have one, start from 3.
- On the right of the top navigation menu, click Log In, and enter the username and password.
- On the right of the top navigation bar, click Console to go to the management console.
- In the upper left corner of the navigation pane, click and choose Storage > Object Storage Service. The OBS Console page is displayed.
- (Recommended) Top up your account or buy OBS resource packages, for you to properly use OBS.
Parent topic: Getting Started
