- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Help Center/
Cloud Operations Center/
User Guide/
Application and Resource Management/
Before performing cross-account resource operations on COC, you need to meet the following prerequisites:
- You have enabled organizations or joined an organization. You can view the information on the organization service page.
Figure 1 Organizations
- The organization to which the user belongs has set COC as a trusted service. You can view the trusted services on the organization page.
Figure 2 Trusted Services
- The account that performs the cross-account O&M operation is an organization administrator or a delegated administrator assigned by the organization administrator.
Figure 3 Delegated administrator
