Updated on 2026-10-28 GMT+08:00
Viewing Resource Details and Topologies
During routine resource management, you often need to view resource details for refined management. However, only some attributes of resources are displayed in the resource list by default. This may cause difficulties when you need to understand a resource in depth. How do you solve this problem and ensure that you can efficiently manage resources? You can view resource details on the resource management page or application management page. For details, see Viewing Resource Details on the Resource Management Page and Viewing Resource Details on the Application Management Page.
COC displays the resource topology graphically. Nodes represent resources, and lines illustrate their relationships. Such a visual view makes resource dependencies much clearer, improving resource monitoring and management and the insight into resource usage.
  • You can view only the details of Huawei Cloud and IDC resources. For IDC resources, you can view only the details of VMs and physical machines.
  • You can view the topology of the following Huawei Cloud resources: ECSs, BMSs, MRS instances, and CCE instances.
  1. Log in to COC.
  2. In the navigation pane, choose Resources > Application and Resource Management.
  3. Select the cloud vendor whose resources need to be viewed.
    Huawei Cloud is selected by default.
  4. Select the resource type to be checked.
    By default, Elastic Cloud Server (ECS) is selected.
  5. Locate the target instance and click the instance name to access the details page.
    You can view the resource name, ID, enterprise project, region, cloud server information, application, group, and component. In addition, you can switch to the corresponding group page.
    Figure 1 Accessing the details page
  6. In the lower part of the details page, click View Resource Details to go to the resource details page.
    View the resource details on the resource details page.
  1. Log in to COC.
  3. Click Applications in the upper left corner.
  4. In the application pane on the left, select an application.
  5. Select the cloud vendor whose resources need to be viewed.
  6. Select the resource type to be checked.
  7. Locate the target instance and click the instance name. The resource details page is displayed.
    Figure 2 Viewing resource details
  8. In the lower part of the page, click View Resource Details to go to the resource details page.
Viewing Resource Topologies
  1. Log in to COC.
  4. Select the type of resources to be synchronized.
  5. Select the target instance and click View Topology in the Operation column.
    The resource topology displays the topology relationships between a resource and other resources.
    Figure 3 Viewing resource topologies
Viewing the Resources of Enterprise Projects Added to My Favorites
Resources on COC enables you to favorite enterprise projects so that you can filter resources by enterprise project. When there are a large number of resources, you can select an enterprise project that has been added to My Favorites to quickly filter resources and simplify resource search.
  1. Log in to COC.
  3. Click Favorite Configuration in the upper right corner. The favorites configuration drawer is displayed on the right.
  4. In the enterprise project list, select the enterprise projects you want to add to My Favorites.
  5. Click OK. In the displayed dialog box, click OK again to add the enterprise project to My Favorites.
  6. On the Resources tab page, expand the drop-down list on the left of the search box and select Enterprise projects in My Favorites.
    The system automatically filters the resources associated with the enterprise projects that have been added to My Favorites.
    Figure 4 Viewing the resources of enterprise projects in My Favorites
