Updated on 2026-10-28 GMT+08:00
Managing Resources of Other Cloud Vendors
In multi‑cloud operations, enterprises frequently manage resources that span multiple cloud platforms, which leads to complex resource management and low efficiency. COC allows you to configure accounts for other cloud vendors and synchronize their resources. This enables enterprises to efficiently manage resources from different cloud service providers on a unified platform. You can configure accounts for other cloud vendors on COC and synchronize their resources. This simplifies resource management across multiple clouds.
Currently, resources of Alibaba Cloud, AWS, Azure, and Huawei Cloud Stack can be managed. If you need to manage resources from other cloud vendors on COC, perform the operations in Adding an Account of a Cloud Vendor.
Precautions
  1. Log in to COC.
  2. In the navigation pane, choose Resources > Application and Resource Management.
  3. Click Multi-cloud Configurations in the upper right corner.
    Figure 1 Multi-cloud configurations
  4. On the multi-cloud configuration page, click the cloud vendor to which you want to add an account. The page for configuring the cloud vendor account is displayed.
  5. Set the information about the new account as prompted.
    • For details about how to add an Alibaba Cloud or AWS account, see Table 1.
      Table 1 Parameters for adding an Alibaba Cloud or AWS account
      Master Account ID
      Account ID of the cloud vendor.
      Enter a master account ID. If you enter a non-master account ID, resources may fail to be synchronized.
      After the account is added, the account ID cannot be changed.
      Account
      Account name of the cloud vendor.
      Access Key ID
      Access key ID of the cloud vendor.
      It is a unique access key ID associated with the secret access key.
      Secret Access Key
      Secret access key of the cloud vendor.
      Secret access key is used together with an access key ID to sign requests cryptographically. It identifies a request sender and prevents the request from being modified.
    • For details about how to add an Azure account, see Table 2.
      Table 2 Parameters for adding an Azure account
      Azure Tenant ID
      Enter an Azure tenant ID. If you enter a non-tenant ID, resources may fail to be synchronized.
      Microsoft Entra ID [formerly known as Azure Active Directory (Azure AD)] is used to uniquely identify your organization's identity authentication and directory service instance in Azure.
      After the account is added, the tenant ID cannot be changed.
      Azure Tenant Name
      Application ID
      Enter the Azure application ID.
      An application ID is a unique identifier allocated by an application and is used to identify a specific application during identity authentication and authorization.
      Application Secret Value
      Enter the application secret value of Azure (added to Certificates & secrets).
      Secret string used by an application to authenticate itself when requesting a token.
    • For details about how to add a Huawei Cloud Stack account, see Table 3.
      Table 3 Parameters for adding a Huawei Cloud Stack account
      Domain Name/IP Address
      Enter the Huawei Cloud Stack domain name or IP address.
      Domain names and IP addresses are network identifiers for accessing Huawei Cloud Stack and related resources. They are used to locate and connect to Huawei Cloud Stack service components in the network environment.
      After the account is added, the domain name or IP address cannot be changed.
      Environment Name
      Enter the name of the Huawei Cloud Stack environment to be managed.
      Account
      Enter the Huawei Cloud Stack account name.
      Password
      Enter the Huawei Cloud Stack account and password.
  6. Click OK. The account is added.
    On the resource management page, select a cloud vendor. After you manually synchronize resources, you can view the information about the managed resources in the resource list.
Modifying an Account of a Cloud Vendor
  1. Log in to COC.
  4. Locate the target account and click Modify in the Operation column. The page for modifying the account is displayed.
    Figure 2 Modifying an account
  5. Modify the account information by referring to the following table.
    Table 4 Parameters for modifying the Alibaba Cloud or AWS account
    Access Key ID
    Reuse Secret Access Key
    Whether to reuse the secret access key.
    • If you select Yes, the latest secret access key (SK) is reused.
    • If you select No, enter a new SK.
    Secret Access Key
    Set this parameter only when Reuse Secret Access Key is set to No.
    Table 5 Parameters for modifying the Azure account
    Azure Tenant Name
    Application ID
    Application Secret Value Reuse
    Select whether to reuse the application secret value.
    • If you select Yes, the latest application secret value is reused.
    • If you select No, enter a new application secret value.
    This parameter is mandatory only when Application Secret Value Reuse is set to No.
    Table 6 Parameters for modifying the Huawei Cloud Stack account
    Environment Name
    Account
    Password Reuse
    Select whether to reuse the password.
    • If you select Yes, the latest secret access password is reused.
    • If you select No, you need to enter a new password.
    Password
    This parameter is mandatory only when Password Reuse is set to No.
  6. Click OK. The account is modified.
    After the modification, you can manually synchronize resources to update related resource information.
Deleting an Account of a Cloud Vendor
  1. Log in to COC.
  4. Locate the target account and click Delete in the Operation column.
  5. Click OK. The account is deleted.
    After the account is deleted, the system deletes all resources of the account from the Resources page.
