Updated on 2026-11-02 GMT+08:00
Accessing OBS
The IP address obtained through DNS resolution for accessing a Huawei Cloud OBS bucket domain name may change over time. Therefore, you are not advised to directly use an IP address to access OBS.
Related Concepts
Before learning about how to access OBS, you are advised to understand the related concepts.
Table 1 Concepts related to OBS access
Concept
Definition
Format
Usage
Region
Regions are divided based on geographical location and latency characteristics. Public services, such as Elastic Cloud Server (ECS), Elastic Volume Service (EVS), Object Storage Service (OBS), Virtual Private Cloud (VPC), Elastic IP (EIP), and Image Management Service (IMS), are shared within the same region.
Format: <area-name>-<city-name>
Select the region for your bucket and its objects based on the location of your workloads.
Region ID
A region ID uniquely identifies a region.
Format: <area ID>-<number>
Used for request signing and other operations when APIs, SDKs, or obsutil are used to access OBS
Endpoint
OBS provides an endpoint for each region. An endpoint is the region-specific OBS domain name used to process requests within that region.
Format: Endpoint
obs.cn-north-4.myhuaweicloud.com
Used in scenarios such as establishing network connections with OBS when APIs, SDKs, or obsutil are used to access OBS
Access domain name
OBS assigns a default access domain name to each bucket. An access domain name is the publicly accessible domain name of a bucket. You can use this domain name to access the bucket.
Format: BucketName.Endpoint
BucketName is the bucket name, and Endpoint is the endpoint for the bucket's region.
Used in scenarios such as browser access to buckets, static website hosting, user-defined domain names, and CDN acceleration
Static website domain name
The domain name used to access a static website hosted in a bucket
Format: BucketName.obs-website.Endpoint
Example: bucketname.obs-website.cn-north-4.myhuaweicloud.com
Used to access static files when a static website is hosted in a bucket
User-defined domain name
A domain name you register with Huawei Cloud or another provider and license through the Ministry of Industry and Information Technology (MIIT)
Format: <user-defined-name>.<domain-name-suffix>
Suffixes include .com, .cn, and others.
Example: www.example.com
Map a user-defined domain name to a bucket's access domain name to access the bucket through the user-defined domain name.
CDN acceleration domain name
A user-defined domain name accelerated through Content Delivery Network (CDN) to improve access performance
Its format is the same as that of a user-defined domain name, but you must configure the service scope (Chinese mainland, outside Chinese mainland, or global) and service type (website acceleration, file download acceleration, or VOD acceleration).
Used to accelerate access to objects stored in OBS buckets worldwide
Intranet CIDR block
The CIDR block used to access OBS buckets over the Huawei Cloud intranet
The intranet CIDR block is the same across all regions: 100.125.0.0/16.
Used for accessing OBS over the intranet
OBS Access Solutions
OBS provides multiple access solutions. Based on your access needs, OBS recommends the appropriate features and configurations to help you build an efficient, stable, and secure access architecture, as shown in Table 2.
Table 2 OBS access solutions
Access Need
Network Access Type
Recommended Solution
Basic access
Public/Intranet access
Obtain region IDs, endpoints, intranet CIDR blocks, or Direct Connect CIDR blocks.
Regions and Endpoints
Use a bucket domain name, user-defined domain name, or CDN acceleration domain name to access OBS.
OBS Domain Name Types
Public access
Preview files online or use a unified domain name to access your content.
Accessing a Bucket Using a User-Defined Domain Name
Accelerated access
Public access
Enable global acceleration for accessing objects stored in OBS buckets.
Accessing a Bucket Using a CDN Acceleration Domain Name
Secure access
Public access
Configure an HTTPS certificate for a user-defined domain name so you can access OBS securely over HTTPS (for example, using https://example.com).
Certificate Hosting
Public access
Prevent resources stored in OBS buckets from being stolen by unauthorized websites, avoiding data leakage and unexpected traffic costs.
Configuring URL Validation to Prevent Unauthorized Access to Your Data
Web access
Public access
Store static web pages in an OBS bucket and publish them as a website.
Static Website Hosting
Public access
Enable scripts and content from different origins (with different protocols, domain names, or ports) to interact with each other, allowing for cross-origin access.
Configuring CORS to Allow Cross-Origin Access to OBS
Intranet access
Intranet access
Access OBS through the internal communication network between services.
Accessing OBS from an ECS over the Intranet
Fixed access
Public access
Access OBS using a fixed IP address through a reverse proxy.
Accessing OBS Through an NGINX Reverse Proxy
The following provides common OBS regions and their endpoints, dual-stack endpoints, intranet CIDR blocks, and Direct Connect CIDR blocks of OBS across global areas. For more information about regions and endpoints, see Regions and Endpoints.
Table 3 Regions and endpoints
Region Name
Region ID
Endpoint
Intranet CIDR Block
Direct Connect CIDR Block
CN North-Beijing4
cn-north-4
100.125.0.0/16
120.46.235.0/25
CN North-Ulanqab1
cn-north-9
obs.cn-north-9.myhuaweicloud.com
100.125.0.0/16
Submit a service ticket to obtain it.
CN North3
cn-north-12
obs.cn-north-12.myhuaweicloud.com
100.125.0.0/16
CN East-Shanghai1
cn-east-3
obs.cn-east-3.myhuaweicloud.com
100.125.0.0/16
123.60.199.0/25
CN East-Qingdao
cn-east-5
obs.cn-east-5.myhuaweicloud.com
100.125.0.0/16
CN East2
cn-east-4
obs.cn-east-4.myhuaweicloud.com
100.125.0.0/16
CN South-Guangzhou
cn-south-1
obs.cn-south-1.myhuaweicloud.com
100.125.0.0/16
CN South-Guangzhou-InvitationOnly
cn-south-4
obs.cn-south-4.myhuaweicloud.com
100.125.0.0/16
CN Southwest-Guiyang1
cn-southwest-2
obs.cn-southwest-2.myhuaweicloud.com
100.125.0.0/16
CN-Hong Kong
ap-southeast-1
obs.ap-southeast-1.myhuaweicloud.com
100.125.0.0/16
AP-Bangkok
ap-southeast-2
obs.ap-southeast-2.myhuaweicloud.com
100.125.0.0/16
AP-Singapore
ap-southeast-3
obs.ap-southeast-3.myhuaweicloud.com
100.125.0.0/16
AP-Jakarta
ap-southeast-4
obs.ap-southeast-4.myhuaweicloud.com
100.125.0.0/16
AP-Manila
ap-southeast-5
obs.ap-southeast-5.myhuaweicloud.com
100.125.0.0/16
Table 4 Regions and endpoints
Region Name
Region ID
Endpoint
Intranet CIDR block
LA-Mexico City1
na-mexico-1
obs.na-mexico-1.myhuaweicloud.com
100.125.0.0/16
LA-Mexico City2
la-north-2
obs.la-north-2.myhuaweicloud.com
100.125.0.0/16
LA-Sao Paulo1
sa-brazil-1
obs.sa-brazil-1.myhuaweicloud.com
100.125.0.0/16
LA-Santiago
la-south-2
obs.la-south-2.myhuaweicloud.com
100.125.0.0/16
Table 5 Regions and endpoints
Region Name
Region ID
Endpoint
Intranet CIDR Block
AF-Cairo
af-north-1
obs.af-north-1.myhuaweicloud.com
100.125.0.0/16
AF-Johannesburg
af-south-1
obs.af-south-1.myhuaweicloud.com
100.125.0.0/16
Table 6 Regions and endpoints
Region Name
Region ID
Endpoint
Intranet CIDR Block
ME-Riyadh
me-east-1
obs.me-east-1.myhuaweicloud.com
100.125.0.0/16
Table 7 Regions and endpoints
Region Name
Region ID
Endpoint
Intranet CIDR Block
TR-Istanbul
tr-west-1
obs.tr-west-1.myhuaweicloud.com
100.125.0.0/16
Endpoints
Generally, the endpoint in a request must match the region where the requested OBS resource resides. In certain cases, however, you can use any endpoint.
  1. Scenarios where the endpoint must match the resource's region
    When accessing a bucket or an object, the endpoint in the request must be the endpoint of the region where the bucket or object resides.
    For example, if bucket mybucket is in region ap-southeast-1, you can list objects in the bucket by sending a request shown in the following example:
    A correct example of an object listing request and its response:
    [Request]
    GET / HTTP/1.1
    Host: mybucket.obs.ap-southeast-1.myhuaweicloud.com
    Accept: */*
    Date: Thu, 10 Mar 2016 08:51:25 GMT
    Authorization: authorization
    [Response]
    HTTP/1.1 200 OK
    x-obs-request-id: 0001EF710C000001536176DA465E4E6G
    x-obs-id-2: Rdj0zZvRkihRcjcQUqjkDGt8JuAgi2CGuLiP7Pv/cYYplsS0xTFJQHP5vSg5yOYC
    Content-Type: application/xml
    Date: Thu, 10 Mar 2016 16:58:12 GMT
    x-obs-bucket-location: ap-southeast-1
    Content-Length: 259
    <?xml version="1.0" encoding="UTF-8" standalone="yes"?>
    <ListBucketResult xmlns="http://obs.myhuaweicloud.com/doc/2015-06-30/">
      <Name>mybucket</Name>
      <Prefix/>
      <Marker/>
      <MaxKeys>1000</MaxKeys>
      <IsTruncated>false</IsTruncated>
      <Contents>
        <Key>object001</Key>
        <LastModified>2015-07-01T00:32:16.482Z</LastModified>
        <ETag>"2fa3bcaaec668adc5da177e67a122d7c"</ETag>
        <Size>12041</Size>
        <Owner>
          <ID>b4bf1b36d9ca43d984fbcb9491b6fce9</ID>
        </Owner>
        <StorageClass>STANDARD</StorageClass>
      </Contents>
    </ListBucketResult>
    If the endpoint you use does not match the region where the bucket belongs, there will be an error message indicating that the bucket does not exist.
    In the example above, bucket mybucket is in region ap-southeast-1. If you use the endpoint of cn-south-1 (mybucket.obs.cn-south-1.myhuaweicloud.com) to access the bucket, HTTP 404 is returned, indicating that the bucket does not exist. In this case, you can make an API call to obtain the bucket's region ID, and then send the request again.
    An incorrect example of an object listing request and its response:
    [Request]
    GET / HTTP/1.1
    Host: mybucket.obs.cn-south-1.myhuaweicloud.com
    Accept: */*
    [Response]
    HTTP/1.1 404 NoSuchBucket
    x-obs-request-id: 0001EF710C000001536176DA465E4E6H
    x-obs-id-2: Rdj0zZvRkihRcjcQUqjkDGt8JuAgi2CGuLiP7Pv/cYYplsS0xTFJQHP5vSg5yOYL
    Date: Thu, 10 Mar 2016 08:51:30 GMT
    Content-Length: 318
    <Error>
      <Code>NoSuchBucket</Code>
      <Message>The specified bucket does not exist</Message>
      <RequestId>0001EF710C000001536176DA465E4E6H</RequestId>
      <HostId>R2zskemlm0PtIQqw9dRrW+RVjYUj6kLtcvdPjHLdyMCgThSrWToXNyJIyx5Oe2nu</HostId>
      <BucketName>bucket05</BucketName>
    </Error>
  2. Scenarios where any endpoint can be used
    You can use the endpoint of any region in the API requests for listing buckets and for obtaining a bucket's location information, because these APIs search for buckets across all regions.
    Example request and response for obtaining a bucket's location information:
    For example, if bucket mybucket is in region ap-southeast-1 and the endpoint of the cn-south-1 region is used in the request, the bucket location information can still be obtained.
    [Request]
    GET /?location HTTP/1.1
    Accept: */*
    [Response]
    HTTP/1.1 200 OK
    Content-Length: length
    <Location xmlns="http://obs.myhuaweicloud.com/doc/2015-06-30/">ap-southeast-1</Location>
OBS Domain Names
The following describes OBS domain name types with examples.
Table 8 lists the OBS domain names, along with their formats and protocols.
Table 8 OBS domain names
Domain Name Type
Domain Name Format
Configuration Required
Protocol
User-defined domain name (recommended)
[Format]
[Example]
www.example.com
You can map a user-defined domain name to a bucket's access domain name to access the bucket through the user-defined domain name.
A user-defined domain name must be configured.
HTTPS
HTTP
User-defined domain name (acceleration domain name)
Content Delivery Network (CDN) can accelerate a user-defined domain name to improve OBS access performance.
Acceleration domain names accelerate access to objects stored in OBS buckets worldwide.
A CDN acceleration domain name must be configured.
HTTPS
HTTP
Huawei Cloud OBS domain name
To protect your services from being affected if Huawei Cloud public domain names are taken over by relevant organizations, you are advised to use a user-defined domain name to access a bucket.
Region-specific domain name (endpoint)
[Format]
Endpoint
[Example]
For the mapping between regions and OBS endpoints, see Regions and Endpoints.
Available by default
HTTPS
HTTP
Bucket access domain name
[Format]
BucketName.Endpoint
[Example]
bucketname.obs.ap-southeast-1.myhuaweicloud.com
You can construct the bucket's access domain name according to its format or obtain it directly from the bucket's basic information on OBS Console or OBS Browser+.
HTTPS
HTTP
Object access domain name
[Format]
BucketName.Endpoint/ObjectName
[Example]
bucketname.obs.ap-southeast-1.myhuaweicloud.com/object.txt
After an object is uploaded to a bucket, you can access the object using its access domain name.
You can construct the object URL according to its format or obtain it directly from the object details on OBS Console or OBS Browser+. You can also use an SDK to call the GetObjectUrl API to obtain the object URL.
HTTPS
HTTP
[Format]
[Example]
bucketname.obs-website.ap-southeast-1.myhuaweicloud.com
This type of domain name is used to access the static website hosted in a bucket.
You can use such a domain name to access static files when a static website is hosted in a bucket.
Static website hosting must be configured.
HTTPS
HTTP
Examples of Using OBS Domain Names
  • Using a browser
    The following example shows how to access an object using a browser.
    For security and compliance purposes, when you use an object access domain name to access objects (such as videos, images, and web pages) in a bucket through a browser, the object content will not be displayed. Instead, the content is downloaded as an attachment. To preview objects online, see How Do I Preview OBS Objects in My Web Browser?
    1. Go to the bucket list page. Then, click the target bucket name to open its object list.
    2. Click the required object name to open the object details page.
    3. Copy the object URL.
    4. Paste the object URL into your browser to access the object.
  • Using obsutil
    The following example shows how to download objects using obsutil. You can use bucket-cname to specify the user-defined domain name bound to the bucket and e to specify the endpoint.
    obsutil cp obs://bucket/key file_or_folder_url [-bucket-cname=xxx] [-e=xxx] [-i=xxx] [-k=xxx] [-t=xxx]
    The following table describes the parameter settings for different domain name types.
    Table 9 Parameter settings for different domain name types
    Domain Name Type
    Parameter Configuration
    Set e to the endpoint of the region where the bucket is located. Example: -e=obs.cn-north-4.myhuaweicloud.com
    Set bucket-cname to the user-defined domain name bound to the bucket. Example: -bucket-cname=www.example.com
    bucket-cname is supported only in obsutil 5.7.9 and later.
Protocols and Ports
Endpoints and bucket access domain names in all regions support both HTTP and HTTPS. To ensure secure access to OBS data, you are advised to use HTTPS.
The following table lists the protocols and ports supported by OBS.
Table 10 Protocols and ports supported by OBS
Protocol
Port
HTTPS
443
HTTPS uses port 443 by default when no port is specified.
HTTP
80
HTTP uses port 80 by default when no port is specified.
Accessing OBS over the Internet or Intranet
Accessing OBS over a public network generates inbound traffic for write operations (for example, uploading data) and outbound traffic for read operations (for example, downloading data). Inbound traffic is free, while outbound traffic is billed.
For pricing of outbound Internet traffic, see Product Pricing Details.
If you access OBS over a public network, you can use a URL to specify resources in OBS. An OBS URL is formatted as follows:
Protocol://[BucketName].Endpoint[:Port][/Object][?Param]
Table 11 Parameters in an OBS URL
Mandatory (Yes/No)
Protocol
The protocol used to send requests, either HTTP or HTTPS. HTTPS ensures secure access to resources.
Yes
BucketName
The name of the requested bucket, which uniquely identifies a bucket in OBS
Yes under certain conditions
All API requests except the one for listing buckets must include BucketName.
Endpoint
The domain name (endpoint) of the region where the OBS bucket resides
Yes
Port
The port used for sending requests. The actual port depends on the software server's deployment. If no port is specified, the protocol uses its default port. Each protocol has a predefined default port.
In OBS, the default HTTP port is 80 and the default HTTPS port is 443.
No
Object
The path of the OBS object to access
No
Param
The specific resource. By default, it is the requested bucket or object itself.
No
Example: You have a bucket named mybucket in the CN-Hong Kong (ap-southeast-1) region. The bucket contains an object named myfolder/myfile.txt. The URL for accessing the object over the public network is as follows:
https://mybucket.obs.ap-southeast-1.myhuaweicloud.com/myfolder/myfile.txt
All API requests except the one for listing buckets must include BucketName. To ensure DNS resolution performance and reliability, OBS requires the bucket name to precede the endpoint when constructing a request that includes a bucket name. This produces a three-level domain name, also known as a virtual-hosted-style access domain name.
Accessing OBS over the intranet refers to accessing OBS through the internal communication network between cloud services. Both inbound traffic for write operations (such as uploading data) and outbound traffic for read operations (such as downloading data) are free of charge.
For example, you can access OBS from an Elastic Cloud Server (ECS) over a private network. This type of access is not affected by public network quality issues and reduces costs.
OBS provides a best practice for configuring intranet access. For details, see Accessing OBS from an ECS over the Intranet.
References
