Creating a Deployment
A Deployment is a Kubernetes application that does not retain data or state while running. Each pod of the same Deployment is identical, allowing for seamless creation, deletion, and replacement without impacting the application functionality. Deployments are ideal for stateless applications, such as web frontend servers and microservices, which do not require data storage. They enable easy lifecycle management of applications, such as updates, rollbacks, and scaling.
- You already have an available cluster before you create a workload. For details about how to create a cluster, see Buying a CCE Autopilot Cluster.
- You have configured the VPC endpoints for accessing the image center and OBS. When you create a cluster, the system automatically creates VPC endpoints. You can go to the Overview page of the cluster and check whether VPC endpoints have been configured for Image Access in the Networking Configuration area. If no VPC endpoints are configured for the cluster, configure them by following the instructions in Configuring VPC Endpoints for Accessing the Image Center.
You can create Deployments on the console or kubectl.
- Log in to the CCE console.
- Click the cluster name to go to the cluster console, choose Workloads in the navigation pane, and then click Create Workload in the upper right corner.
- Configure the basic information about the workload.
Table 1 Basic information about the workload Parameter
Workload Type
Select Deployment. For details about different workload types, see Workload Overview.
Workload Name
Enter a name for the workload. Enter 1 to 63 characters starting with a lowercase letter and ending with a lowercase letter or digit. Only lowercase letters, digits, and hyphens (-) are allowed.
Namespace
Select a namespace for the workload. The default value is default. You can also click Create Namespace to create one. For details, see Creating a Namespace.
Instance Type
Select the pod type for the workload. The default value is General-computing. For details about pod types, see Specifying the Pod Type.
Pods
Enter the number of workload pods.
- Configure the container settings for the workload.
- Image Cache This parameter is optional. If you have created image caches, you can choose to automatically allocate or specify an image cache. For details about the parameters, see Table 2. Image caches accelerate image download and workload startup. For details, see Image Cache Overview. Image caches are supported when the cluster version is v1.28.8, v1.31.4, or later.
Image caches are supported in some regions. View the regions where image caches are supported on the console.
Table 2 Image cache parameters Option
Example Value
Do not use
No image cache will be used. The images will be downloaded based on the configuration in Container Settings.
Auto allocate
The optimal images will be selected from all available image caches based on:- How much the images match the image caches: The images in the most matched image caches will be used.
- Time when the image caches were created: The images in the latest image cache will be used.
If no images are matched, no image caches will be used.
Specify
autopilot-test
Select an existing image cache. The image cache must be in the Available state. To create an image cache, click Create Image Cache. For details about the parameters, see Creating an Image Cache.
- Container Information: Click Add Container on the right to configure multiple containers for the pod.
- Basic Info: Configure basic information about each container.
Table 3 Basic container information Parameter
Container Name
Enter a name for the container.
Pull Policy
Image update or pull policy. If you select Always, the image is pulled from the image repository each time. If you do not select Always, an existing local image is preferentially used. If there is no existing image, an image will be pulled from the image repository.
If an image cache is used, you are advised not to select Always to avoid repeatedly pulling images from the original image repository.
Image Name
Click Select Image and select the image used by the container. To use a third-party image, see Using Third-Party Images.
If you choose to use an image cache, you need to enter the following information:
- If you select Auto allocate, you can configure Image Name (Container Information > Basic Info > Image Name). The images are matched based on the matching rules in Table 2. If no images are matched in the image cache, the image cache is no longer used. In this case, the images in the SWR image repository and open-source images are matched in sequence based on the specified image name. If no images are matched, a message is returned indicating that images fail to be pulled.
- If you select Specify, you need to enter the address of the image to be used in the image cache (Container Information > Basic Info > Image Name).
To obtain the image path, move the cursor to the specified image cache and view Image in the displayed tip.
Image Tag
Select the image tag to be deployed.
CPU Quota
CPU limit, which is the maximum CPU available for the container to prevent excessive resource usage.
Memory Quota
Memory limit, which is the maximum memory available for the container. When the container's memory usage exceeds the memory limit, the container will be terminated.
Init Container
Whether the container will be used as an init container. This parameter is optional. An init container does not support health check.
An init container is a special container that runs before other app containers in a pod are started. Each pod can contain multiple containers. In addition, a pod can contain one or more init containers. Application containers in a pod are started and run only after the running of all init containers completes. For details, see Init Containers.
Run Option
Add run options for the container. This parameter is optional. For details, see Pod. CCE Autopilot supports the following run options:
- stdin: allows containers to receive input from external sources, such as terminals or other input streams.
- tty: allocates a pseudo terminal to containers, allowing you to send commands to them as if you were using a local terminal.
In most cases, tty is enabled along with stdin, indicating that the terminal (tty) is associated with the standard input (stdin) of the container. This allows for interactive operations, similar to the kubectl exec -i -t command. The difference is that this parameter has been configured when the pod is launched.
- Lifecycle: This parameter is optional. Configure operations to be performed in a specific phase of the container lifecycle, such as startup command, PostStart, and PreStop. For details, see Configuring the Container Lifecycle.
- Health Check: This parameter is optional. Set the liveness probe, ready probe, and startup probe as needed. For details, see Configuring Health Checks for Containers.
- Environment Variables: This parameter is optional. Configure variables for the container running environment using key-value pairs. These variables transfer external information to containers running in pods and can be flexibly modified after application deployment. For details, see Configuring Environment Variables.
- Data Storage: This parameter is optional. Mount local storage or cloud storage to the container. The application scenarios and the ways for mounting the volumes vary with the storage type. For details, see Storage.
- Security Context: This parameter is optional. Assign container permissions to protect the system and other containers from being affected. Enter the user ID to assign container permissions and prevent the system and other containers from being affected.
- Image Access Credential: Select the credential used for accessing the image repository. The default value is default-secret. You can use default-secret to access images in SWR. For details about default-secret, see default-secret.
- (Optional) Configure the Service settings for the workload.
A Service provides external access for pods. With a static IP address, a Service forwards the traffic to pods and automatically balances load for these pods.
You can also create a Service after creating a workload. For details about Services of different types, see Services.
- (Optional) Configure advanced settings for the workload.
Table 4 Advanced settings for the workload Parameter
Upgrade
Specify the upgrade mode and parameters of the workload. Rolling upgrade and Replace upgrade are supported. For details, see Upgrading and Rolling Back a Workload.
Labels and Annotations
Add labels or annotations for pods using key-value pairs. After you add a label or annotation, click Add. For details about how to use and configure labels and annotations, see Configuring Labels and Annotations.
DNS
Configure a DNS policy for the workload. For details, see DNS Configuration.
APM Settings
Use APM to provide more accurate problem analysis and locating for Java programs. For details, see Specifying APM Settings.
Network Configuration
- Decide whether to enable the network configuration of a specified container: You can enable the specified container network configuration. The workload is created using the container subnet and security group in the specified container network configuration. For details, see Associating a Subnet and Security Group with a Namespace or Workload Using a Container Network Configuration.
- Specify the container network configuration name: Only the custom container network configuration whose associated resource type is workload can be selected.
- In the Confirm step, confirm the following information:
- Confirm the pod resource specification calculation rules.
- Default configuration: The resource specifications of a pod are based on the CPU and memory quotas needed by all init and regular containers.
- Custom configuration: If you have configured pod-level resource quotas, the configuration is used as the final pod resource specifications (the priority of the pod-level configuration is higher than that of the container-level configuration).
- Ensure that the ephemeral storage of a single pod meets the container requirements. For details, see Increasing the Ephemeral Storage Space of a Pod.
- Confirm the billing specifications.
- The actual billing specifications of a single pod are automatically rounded up to the nearest pod specifications supported by CCE Autopilot. For details about the specifications, see CCE Autopilot Specification Description.
- If the requested pod resources are lower than the billed amount, you are advised to use the one-click upgrade function to upgrade the specifications and prevent resource waste.
- Confirm the information and select I have read and agree to the pricing policy.
- In the lower right corner, click Create Workload. After a period of time, the workload enters the Running state.
Nginx is used as an example here to describe how to create a workload using kubectl.
Node affinity and anti-affinity are not available for CCE Autopilot clusters. When you use kubectl to create a workload, do not configure the affinity field to prevent pod creation failures.
- Use kubectl to access the cluster. For details, see Accessing a Cluster Using kubectl.
- Create and edit the nginx-deployment.yaml file. nginx-deployment.yaml is an example file name. You can rename it as needed.
vi nginx-deployment.yaml
The following is an example YAML file. For more information about Deployments, see Kubernetes documentation.
apiVersion: apps/v1 kind: Deployment metadata: name: nginx spec: replicas: 1 selector: matchLabels: app: nginx strategy: type: RollingUpdate template: metadata: labels: app: nginx spec: containers: - image: nginx:latest # If you use an image from an open-source image registry, enter the image name. If you use an image in My Images, obtain the image path from SWR. imagePullPolicy: Always name: nginx imagePullSecrets: - name: default-secretFor details about the parameters, see Table 5.
Table 5 Deployment YAML parameters Parameter
Mandatory
apiVersion
API version.
NOTE:Set this parameter based on the cluster version.
- For clusters v1.17 or later, the apiVersion format of Deployments is apps/v1.
- For clusters v1.15 or earlier, the apiVersion format of Deployments is extensions/v1beta1.
Yes
kind
Type of a created object.
Yes
metadata
Metadata of a resource object.
Yes
name
Name of the Deployment.
Yes
spec
Detailed description of the Deployment.
Yes
replicas
Number of pods.
Yes
selector
Determines container pods that can be managed by the Deployment.
Yes
strategy
Upgrade mode. Possible values:
- RollingUpdate
- ReplaceUpdate
By default, RollingUpdate is used.
No
template
Detailed description of a created container pod.
Yes
metadata
Metadata.
Yes
labels
metadata.labels: Container labels.
No
containers
- image (mandatory): Name of a container image.
- imagePullPolicy (optional): Policy for obtaining an image. The options include Always (attempting to download images each time), Never (only using local images), and IfNotPresent (using local images if they are available; downloading images if local images are unavailable). The default value is Always.
- name (mandatory): Container name.
Yes
imagePullSecrets
Name of the secret used during image pulling. If a private image is used, this parameter is mandatory.
- To pull an image from the Software Repository for Container (SWR), set this parameter to default-secret.
- To pull an image from a third-party image repository, set this parameter to the name of the created secret.
No
- Create a Deployment.
kubectl create -f nginx-deployment.yaml
If information similar to the following is displayed, the Deployment is being created:
deployment "nginx" created
- Query the Deployment status.
kubectl get deployment
If the following information is displayed, the Deployment is running.
NAME READY UP-TO-DATE AVAILABLE AGE nginx 1/1 1 1 4m5s
Parameter description
- NAME: Name of the application running in the pod.
- READY: indicates the number of available workloads. The value is displayed as "the number of available pods/the number of expected pods".
- UP-TO-DATE: indicates the number of replicas that have been updated.
- AVAILABLE: indicates the number of available pods.
- AGE: the period during which the Deployment keeps running
- If the Deployment will be accessed through a ClusterIP or NodePort Service, add the corresponding Service. For details, see Services.
Helpful Links
- For containerized applications that require persistent data storage, such as databases, you are advised to use StatefulSets. For details, see Creating a StatefulSet.
- If a fault occurs during workload creation, you can rectify it by referring to How Can I Locate the Root Cause If a Workload Is Abnormal?
- To perform more operations on a workload after the workload creation, see Managing Workloads.
