Cluster Secrets
By default, CCE Autopilot creates the following secrets in each namespace:
- default-secret
- paas.elb
The functions of these secrets are described in detail.
default-secret
The type of default-secret is kubernetes.io/dockerconfigjson. The data is the credential for logging in to the SWR image repository and is used to pull images from SWR. To pull an image from SWR when creating a workload on CCE Autopilot, set imagePullSecrets to default-secret.
apiVersion: v1
kind: Pod
containers:
- image: nginx:alpine
resources:
limits:
cpu: 100m
memory: 200Mi
requests:
cpu: 100m
memory: 200Mi
imagePullSecrets:
- name: default-secret The default-secret data is updated periodically, and the current data will expire after a certain period of time. You can run the describe command to view the expiration time in default-secret.
Use default-secret directly instead of copying the secret content to create a new one. The credential in the copied secret will expire and the image cannot be pulled.
$ kubectl describe secret default-secret Name: default-secret Namespace: default Labels: secret-generated-by=cce Annotations: swr-auth-may-expires-at: 2021-11-26 20:55:31.380909 +0000 UTC Type: kubernetes.io/dockerconfigjson Data ==== .dockerconfigjson: 347 bytes
paas.elb
paas.elb stores a pair of temporary AK and SK that are used when a pod is created or a load balancer is automatically created. The paas.elb data is updated periodically and has a specific time limit before it expires.
In practice, you will not directly use paas.elb. Do not delete it, as doing so will result in the failure of creating a pod or load balancer.
