Help Center/ Cloud Container Engine_Autopilot/ User Guide/ Workloads/ Configuring VPC Endpoints for Accessing the Image Center
Updated on 2026-09-18 GMT+08:00
You need to configure VPC endpoints for accessing SWR and OBS so that images can be pulled from Image Center when you are creating workloads in a CCE Autopilot cluster. If the cluster version is v1.27.4-r0 or v1.28.2-r0 or later, the required VPC endpoints are created by default. If the cluster does not have the VPC endpoints configured, you can create them by referring to this section.
Check whether the VPC endpoints have been configured: Go to the Overview page of the target cluster. In the Image Access of the Networking Configuration area, check whether the VPC endpoints are configured.
For details about VPC Endpoint, see What Is VPC Endpoint?
Figure 1 A CCE Autopilot cluster accessing SWR and OBS
Configuring a VPC Endpoint for Accessing SWR
  1. Log in to the VPC Endpoint console.
  2. On the displayed page, click Buy VPC Endpoint.
  3. Configure mandatory parameters as prompted. For details about more parameters, see Buying a VPC Endpoint.
    Table 1 Parameters for creating a VPC endpoint
    Region
    Select the region where the VPC endpoint is located. The VPC endpoint must be in the same region as the CCE Autopilot cluster.
    Billing Mode
    Specifies the billing mode of the VPC endpoint. Only pay-per-use billing is supported. You can create or delete a VPC endpoint at any time.
    Service Category
    Select Find a service by name.
    VPC Endpoint Service Name
    Enter a service name based on Table 2 and click Verify.
    Create a Private Domain Name
    Select this parameter.
    After the endpoint is created, you can access the endpoint using the private domain name.
    VPC
    Select the VPC where the CCE Autopilot cluster is running.
    Subnet
    Select a subnet.
    IPv4 Address
    Specifies the IPv4 address of the VPC endpoint. You can select Automatically assign IP address or Manually specify IP address.
    Table 2 VPC endpoint service names for SWR
    Region Name
    CN South-Guangzhou-InvitationOnly
    cn-south-4.SWR.f80386a2-ce16-4f92-9df9-20f7fc01e7a2
    CN Southwest-Guiyang1
    com.myhuaweicloud.cn-southwest-2.swr
    CN South-Guangzhou
    swr.cn-south-1.myhuaweicloud.com
    CN East-Shanghai1
    com.myhuaweicloud.cn-east-3.swr
    CN North-Beijing4
    com.myhuaweicloud.cn-north-4.swr
    CN North-Ulanqab1
    com.myhuaweicloud.cn-north-9.swr
    CN-Hong Kong
    com.myhuaweicloud.ap-southeast-1.swr
    AP-Bangkok
    ap-southeast-2.SWR.ac7067e1-f8d1-4f5c-abe1-0f78960e5d4c
    AP-Singapore
    com.myhuaweicloud.ap-southeast-3.swr
    AP-Jakarta
    com.myhuaweicloud.ap-southeast-4.swr
    AF-Johannesburg
    com.myhuaweicloud.af-south-1.swr
    TR-Istanbul
    com.myhuaweicloud.tr-west-1.swr
    ME-Riyadh
    com.myhuaweicloud.me-east-1.swr
    LA-Sao Paulo1
    com.myhuaweicloud.sa-brazil-1.swr
    Figure 2 Creating a VPC endpoint for SWR
  4. Click Next to confirm the configuration.
    • If the configuration is correct, click Submit.
    • If any parameter is incorrect, click Previous to modify it as needed and then click Submit.
  5. Go back to the VPC endpoint list.
    If the status of the VPC endpoint changes to Accepted, the VPC endpoint is connected to the VPC endpoint service.
Configuring a VPC Endpoint for Accessing OBS
    Table 3 Parameters for creating a VPC endpoint
    Region
    Select the region where the VPC endpoint is located. The VPC endpoint must be in the same region as the cluster.
    Billing Mode
    Only pay-per-use billing is supported. Pay-per-use is a postpaid billing mode. You are billed based on the actual usage duration of the VPC endpoint. VPC endpoints can be created or deleted at any time.
    Service Category
    Enter a service name based on Table 4 and click Verify.
    If you want to access a VPC endpoint using a domain name, select Create a Private Domain Name.
    VPC
    Route Table
    Select a route table.
    OBS provides active/standby buckets in some regions. You need to create multiple VPC endpoints to ensure high availability.
    Table 4 VPC endpoint service names for OBS
    Region Name
    cn-south-4.com.myhuaweicloud.v4.obsv2
    cn-southwest-2.com.myhuaweicloud.v4.obsv2
    cn-southwest-2.com.myhuaweicloud.v6.obsv2
    CN South-Guangzhou
    cn-south-1.com.myhuaweicloud.v4.obsv2
    cn-south-1.com.myhuaweicloud.v4.obsv2.lz09
    CN East-Shanghai1
    cn-east-3.com.myhuaweicloud.v4.global.obsv2
    cn-east-3.myhuaweicloud.v4.obsv2.lz03
    CN North-Beijing4
    cn-north-4.com.myhuaweicloud.v4.obsv2.OBSCluster9
    cn-north-4.myhuaweicloud.v4.obsv2.lz12
    CN North-Ulanqab1
    cn-north-9.com.myhuaweicloud.onedata.v4.obsv2
    cn-north-9.com.myhuaweicloud.v4.obsv2.lz12
    CN-Hong Kong
    ap-southeast-1.com.myhuaweicloud.v4.obsv2
    ap-southeast-1.com.myhuaweicloud.v4.obsv2.lz02
    AP-Bangkok
    ap-southeast-2.myhuaweicloud.v4.obsv2
    ap-southeast-2.com.myhuaweicloud.v4.obsv2.c2
    AP-Singapore
    ap-southeast-3.com.myhuaweicloud.v4.obsv2
    AP-Jakarta
    ap-southeast-4.com.myhuaweicloud.v4.obsv2.lz01
    AF-Johannesburg
    af-south-1.myhuaweicloud.v4.obsv2
    TR-Istanbul
    tr-west-1.com.myhuaweicloud.v4.obsv2.lz01
    ME-Riyadh
    me-east-1.com.myhuaweicloud.v4.obsv2.lz001
    LA-Sao Paulo1
    sa-brazil-1.myhuaweicloud.v4.obsv2
    sa-brazil-1.com.myhuaweicloud.v6.obsv2.lz002
    Figure 3 Creating a VPC endpoint for OBS
