- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
What Is the Process of Generating an Incident?
There are three methods available: manual incident creation, converting alarms to incidents, or automatically generate an incident based on an incident forwarding rule. The detailed processes of the three operation methods are as follows.
Manually Creating an Incident
Choose Fault Management > Incidents and click Create to create an incident ticket. For details, see Creating an Incident.
Converting an Alarm to an Incident
Choose Fault Management > Incidents to create an incident ticket. For details, see section "Converting an Alarm to an Incident".
Automatically Generating Incidents Based on Forwarding Rules
To automatically generate an incident based on a forwarding rule, perform the following operations:
- Log in to COC.
- Synchronize personnel. For details, see O&M Engineer Management Overview.
- Set shift scheduling and add agents to the shift scheduling. For details, see Overview.
- Integrate with the monitoring system to automatically report alarms. For details, see Monitoring System Integration Management.
- Configure transition rules and generate incidents based on the rules. For details, see Forwarding rules.
- To receive incident notifications after an incident is generated, configure the automated notification feature. For details, see Notification Management.
