Help Center/ Cloud Container Engine/ Best Practices/ Checklist for Deploying Containerized Applications in the Cloud
Updated on 2026-03-26 GMT+08:00
Overview
Security, efficiency, stability, and availability are common requirements on all cloud services. To meet these requirements, the system availability, data reliability, and O&M stability must be coordinated. This checklist describes the check items for deploying containerized applications on the cloud to help you efficiently migrate services to CCE, reducing potential cluster or application exceptions caused by improper use.
Check Items
Table 1 System availability
Category
Check Item
Type
Impact
FAQ & Example
Cluster
Before creating a cluster, properly plan the node network and container network based on service requirements to allow subsequent service expansion.
Network planning
If the subnet or pod CIDR block where the cluster resides is small, the number of available nodes supported by the cluster may be less than required.
Before creating a cluster, properly plan CIDR blocks for the related Direct Connect, peering connection, container network, service network, and subnet to avoid IP address conflicts.
Network planning
If CIDR blocks are not properly set and IP address conflicts occur, service access will be affected.
When a cluster is created, the default security group is automatically created and bound to the cluster. You can set custom security group rules based on service requirements.
Deployment
Security groups are key to security isolation. Improper security policy configuration may cause security risks and service connectivity problems.
Enable the multi-master node mode by setting the number of master nodes to 3 when creating a cluster.
Reliability
After the multi-master node mode is enabled, three master nodes will be created. If a master node is faulty, the cluster can still be available without affecting service functions. In commercial scenarios, it is advised to enable the multi-master node mode.
How Do I Check Whether a Cluster Is in Multi-Master Mode?
Once a cluster is created, the number of master nodes cannot be changed. Exercise caution when setting the number of master nodes.
When creating a cluster, select a proper network model as needed.
  • Select VPC network or Tunnel network for your CCE standard cluster.
  • Select Cloud Native Network 2.0 for your CCE Turbo cluster.
Deployment
After a cluster is created, the type of network cannot be changed.
Network Model Comparison
Workload
When creating a workload, set the CPU and memory limits to improve service robustness.
Deployment
When multiple applications are deployed on the same node, if the upper and lower resource limits are not set for an application, resource leakage occurs. As a result, resources cannot be allocated to other applications, and the application monitoring information will be inaccurate.
None
When creating a workload, you can set probes for container health check, including liveness probe and readiness probe.
Reliability
If the health check function is not configured, a pod cannot detect service exceptions or automatically restart the service to restore it. This results in a situation where the pod status is normal but the service in the pod is abnormal.
When creating a workload, do not set the number of pods to 1 and configure node scheduling policies based on your service requirements.
Reliability
If there is only one workload pod, the service will be abnormal when the node or pod is abnormal. To ensure that your pods can be successfully scheduled, ensure that the node has idle resources after you set the scheduling rule.
None
Properly set affinity and anti-affinity.
Reliability
For an application that provides external services, if both affinity and anti-affinity rules are configured with a logical disjunction, there is a risk that the service may become inaccessible after the application is upgraded or restarted.
Scheduling Policy (Affinity/Anti-affinity)
Negative example:
For application A, nodes 1 and 2 are set as affinity nodes, and nodes 3 and 4 are set as anti-affinity nodes. Application A exposes a Service through the ELB, and the ELB listens to node 1 and node 2. When application A is upgraded, it may be scheduled to a node other than nodes 1, 2, 3, and 4, and it cannot be accessed through the Service.
Cause:
Scheduling of application A does not need to meet both affinity and anti-affinity rules. A node will be selected for application A according to either of the rules. In this example, the node selection is based on the anti-affinity rule.
When creating a workload, set the pre-stop processing command (Lifecycle > Pre-Stop) to ensure that the services running in the pods can be completed in advance in the case of application upgrade or pod deletion.
Reliability
If the pre-stop processing command is not configured, the pod will be directly killed and services will be interrupted during application upgrade.
When creating a workload, select a proper Service. The following types of Services are supported: ClusterIP, NodePort, DNAT, and LoadBalancer.
Deployment
Improper Service configuration may cause logic confusion for internal and external access and resource waste.
When creating a LoadBalancer Service or ingress, configure health checks to ensure service reliability.
Reliability
If a health check is not configured, the services in a pod might not be working properly, but traffic will still be directed to that pod.
Table 2 Data reliability
Category
Check Item
Type
Impact
FAQ & Example
Container data persistency
Select a proper data volume type based on service requirements.
Reliability
When a node is faulty and cannot be recovered, data in the local disk cannot be recovered. Therefore, you are advised to use cloud storage volumes to ensure data reliability.
Backup
Back up application data.
Reliability
Lost data cannot be restored.
What Are the Differences Among CCE Storage Classes in Terms of Persistent Storage and Multi-node Mounting?
Table 3 O&M reliability
Category
Check Item
Type
Impact
FAQ & Example
Project
The quotas of ECS, VPC, subnet, EIP, and EVS resources must meet customer requirements.
Deployment
If the quota is insufficient, resources will fail to be created. Specifically, users who have configured auto scaling must have sufficient resource quotas.
You are not advised to modify kernel parameters, system configurations, cluster core component versions, security groups, and ELB-related parameters on cluster nodes, or install software that has not been verified.
Deployment
Exceptions may occur on CCE clusters or Kubernetes components on the node, making the node unavailable.
For details, see High-Risk Operations and Solutions.
Negative example:
  1. The container network is interrupted after the node kernel is upgraded.
  2. The container network is interrupted after an open-source Kubernetes network add-on is installed on a node.
  3. The /var/paas or /mnt/paas/kubernetes directory is deleted from a node, which causes exceptions on the node.
Do not modify information about resources created by CCE, such as security groups and EVS disks. Resources created by CCE are labeled cce.
Deployment
CCE cluster functions may be abnormal.
Negative example:
  1. On the ELB console, a user changes the name of the listener created by CCE.
  2. On the VPC console, a user modifies the security group created by CCE.
  3. On the EVS console, a user deletes or removes data disks attached to CCE cluster nodes.
  4. On the IAM console, a user deletes cce_admin_trust.
All the preceding actions will cause CCE cluster functions to be abnormal.
Proactive O&M
CCE provides multi-dimensional monitoring and alarm reporting functions, allowing you to locate and rectify faults as soon as possible.
  • Application Operations Management (AOM): the default basic resource monitoring of CCE. It covers detailed container-related metrics and provides alarm reporting functions.
  • Open-source Prometheus: a monitoring tool for cloud native applications. It integrates an independent alarm system for more flexible monitoring and alarm reporting functions.
Monitoring
If alarms are not configured, the standard of container cluster performance cannot be established. When an exception occurs, you cannot receive alarms and will need to manually locate the fault.
