Creating a Contingency Plan
COC provides a set of standardized public contingency plans tailored to typical operational scenarios, covering the majority of routine fault-handling needs and fulfilling general emergency response requirements. However, if your business has unique operational policies, specialized failure scenarios, or finds that the processes, procedures, or role assignments in the public contingency plans do not align with your fault-handling needs, you can create custom contingency plans on COC. These custom contingency plans should be based on your specific application architecture, operational framework, and potential system failure risks. You may flexibly configure core elements of a plan—including fault description, fault-handling workflow, detailed operational steps, assigned responsibilities, and post-resolution validation criteria—according to the anticipated fault type, impact scope, and handling priority. Once created and saved, these custom contingency plans become immediately available for execution. When a matching fault occurs, O&M personnel can quickly retrieve the relevant custom contingency plan and follow its standardized procedures to perform rapid fault localization, mitigation, and recovery. This effectively standardizes fault-handling actions, improves fault-handling efficiency, minimizes business impact, and ensures the continuous and stable operation of critical systems.
You have enabled the Fault Drills (Professional Edition) package. For details about billing, see Billing Items.
- Log in to COC.
- In the navigation pane, choose Resilience Center > Contingency Plans.
- On the Custom Plans tab page, click Create.
- On the displayed page, set basic information.
Table 1 Basic information parameters Parameter
Contingency Plan
Enter a contingency plan name.
Enterprise Project
Select the enterprise project to which the contingency plan belongs.
Application
Select the application to which the contingency plan belongs.
Recovery Duration
Enter the expected fault rectification duration, in minutes.
Version
Enter the contingency plan version number.
Summary
Enter the main information about the contingency plan.
The value can contain a maximum of 1,024 characters.
- Set parameters for troubleshooting.
Table 2 Troubleshooting parameters Parameter
Contingency Plan Type
You can choose an automatic plan or a document plan.- If you choose an automatic plan, you can use scripts or jobs to rectify faults.
- If you choose a document plan, you need to manually perform recovery actions step by step to rectify faults.
Handling Method
The value can be Scripts or Jobs. For a document plan, you can also select N/A.- Scripts: Select a script. You can select a custom script or public script.
- Jobs: Select a job. You can select a custom job or public job.
- N/A: This option can be selected only for a document plan.
Step Name
Step Name: It is mandatory only for a document plan. If you set Handling Method to Scripts or Jobs, the script or job name will be used automatically.
Step Description
Enter the step description. It is mandatory only for a document plan. The description cannot exceed 3 MB.
- Click OK.
Helpful Links
Custom and public contingency plans are frequently used in routine O&M. The following lists typical scenarios:
