Creating a Drill Task
You can simulate software or hardware faults to test the system's fault rectification capability by using a drill task. You can manage chaos drill tasks, view drill records, and create drill tasks. You can set basic information, add attack task groups, and select attack tasks and attack scenarios for a drill task. In addition, a drill task involves monitoring task configuration and post-drill review and improvement. This ensures that an excellent optimization policy can be applied when the system is under various pressures.
Operation
Procedure Description
- Create a drill task: To evaluate the system's recovery capability under simulated hardware or software failures, configure relevant fault scenarios, target applications, and monitoring rules based on business requirements—whether ad hoc, custom-tailored, or periodic and standardized—to establish the foundational structure for a chaos drill.
- Start a drill task: Once created, the chaos drill task is formally executed. The system simulates the predefined faults and progresses through the drill workflow, while supporting flexible runtime controls such as termination, retry, or skip in response to real-time conditions (such as anomalies or timeouts).
- Create a drill report: After the drill task is completed, a comprehensive report is produced, summarizing the entire drill process, outcome data (including recovery duration), and identified improvement items. This report is exportable and traceable, providing actionable insights for system optimization and refinement of emergency response strategies.
- View drill history: You can retrieve key details of completed chaos drills, including baseline configuration, execution status, fault injection specifics, and monitoring metrics, enabling full visibility into drill implementation and the system's actual performance during failure scenarios.
Automatic Task Termination Mechanism
- Automatic termination upon timeout: If a drill task fails and you do not manually close the task within 48 hours, the system automatically terminates it.
- Automatic termination upon exceptions: During the drill execution, if a pod exception (for example, the pod has been deleted) is detected or a resource O&M ticket is manually closed, the system automatically terminates the current task immediately.
You can create a drill task either directly or using a template. Based on your service scenario, drill complexity, and standardization needs, you can flexibly choose the most suitable approach to ensure efficient implementation of drill tasks and enhance both the standardization and execution efficiency of emergency drills.
Create a drill task directly: This approach is suitable for ad hoc drill requirements, customized scenarios, or first-time drills where no existing template is available—for example, targeted emergency drills in response to an unexpected fault or temporary service process validation exercises.
Create a drill task using a template: This approach is suitable for periodic, repeatable drills, standardized process exercises, or scenarios requiring consistent practices across multiple teams—for example, monthly DR switchover drills, quarterly security incident response drills, and routine cross-departmental process drills.
- Log in to COC.
- In the navigation pane, choose Resilience Center > Chaos Drills.
- Click Drill Tasks.
- On the displayed page, click Create Task.
You can also use the drill plan ticket accepting function to access the page for creating a drill task. For details, see Managing Drill Plans.
- Set the basic information.
Table 1 Basic information parameters Parameter
Example Value
Drill Task
Name of the drill task. Set it according to the naming rules.
The name can contain a maximum of 64 characters, including letters, digits, hyphens (-), underscores (_), and spaces. It cannot start or end with a space.
test-drill
Expected Recovery Duration (Minutes)
Expected time from the fault occurrence to the fault rectification, in minutes.
Expected time for the application to recover to the normal state after fault injection or when the contingency plan is executed. This time does not affect the drill task.
3
- Click Create Attack Task. By default, there is one attack task group. You can click Create Task Group to add a task group. Then, click Create Attack Task to add another attack task.
- Tasks in different task groups are executed in serial mode, and tasks in the same task group are executed in parallel mode.
- Currently, multiple fault injection operations on the same resource in a task group are not supported.
- To add an existing task, click Select from Existing, select the existing task, and click OK.
- To add a new attack task, perform the following steps.
- Set the attack target by referring to Table 2.
Table 2 Parameters for adding an attack task Parameter
Example Value
Cloud Service Vendor
Select a cloud service vendor type.
You can choose Huawei Cloud, On-premises IDCs, or Alibaba Cloud.
Huawei Cloud
Source of Attack Target
Select the source of the target instance.
Elastic Cloud Server (ECS)
Attack Task
Customize the name of the attack task based on the naming rule.
The preset name is the attack target type plus the creation timestamp. For example, if the attack target source is ECS and the creation time is 14:36:08 on December 18, 2025, the name is automatically generated as ECS_20251218143608.
test-attacktask
Attack Target
Select the target instance.
You can filter attack targets by application.
You can select attack targets by selecting instances, pods, or a specified number of targets if CCE instances are used.
- Click Next and select an attack scenario. For details about attack scenarios, see Appendix: Attack Scenarios.
Table 3 Parameters for selecting an attack scenario Parameter
Example Value
Attack Type
Select an attack type based on the attack scenario.
Host resources
Attack Scenario
Select an attack scenario.
CPU usage increase
Attack Parameters
Configure attack parameters based on attack scenarios.
- CPU usage (%): 80
- Fault duration (s): 60
- Click Next.
- (Optional) Set Configure Monitoring Tasks.
Table 4 Parameters for configuring a monitoring task Parameter
Steady-State Metrics
Select the target resource, performance metric, lower limit, and upper limit from the drop-down lists one by one.
If a service can perform well and stably when a performance monitoring metric is set to a certain value range, this metric is called a steady-state metric. If this metric value is not within that value range before the drill execution, the drill will be canceled.
Metric
Select the target resource, monitoring metric, lower limit, and upper limit from the drop-down lists one by one.
These service metrics monitor the corresponding service data during fault drills. If the value of such a metric is within the allowed value range, the service is normal. Otherwise, you can determine whether to stop a drill.
Automatic Rollback
Select whether to enable automatic rollback.
Fault injection is automatically rolled back and restored to the status before fault injection. Automatic rollback cannot be configured for some disruptors in fault drills that do not support fault termination.
If the value of a steady-state metric is not within the stable value range during a drill, the corresponding fault injection automatically stops after automatic rollback is enabled.
For details about the metrics supported by each instance, see Cloud Product Metrics.
- Click Finish.
- Click OK. The drill task is created and the task status is to be drilled.
If you click Save as Draft, the task status is draft, which does not allow you to start the drill task.
- Log in to COC.
- In the navigation pane, choose Resilience Center > Drill Templates.
- Create a drill task in either of the following ways:
- Select the required template based on Drill Template Description and click Create Task on the template card.
- Select the required template based on Drill Template Description, click the template card to go to the Template Details page, and click Create Task.
Table 5 Basic information parameters Parameter
Example Value
Drill Task
test-drill
3
- In the task group that contains scenario and parameters, locate the scenario and add an attack target for the task.
- Click Select under Attack Target.
- Cloud Service Provider and Source of Attack Target are selected based on the preset value of the scenario.
- In the Attack Target table, the instances that do not support the current disruptor are dimmed. After you select an existing task, change the cloud server provider, or change the source of the attack target, the preset disruptor information will be cleared. For details, see Creating a Drill Task Directly.
- After you select an attack target and click Next, the corresponding disruptor is selected based on the target scenario. The preset value of the attack parameter is the data in the template.
Table 6 Parameters for configuring a monitoring task Parameter
If a service can perform well and stably when a performance monitoring metric is set to a certain value range, this metric is called a steady-state metric. If this metric value is not within that value range before the drill execution, the drill will be canceled. If the value of a steady-state metric is not within the stable value range during a drill, the corresponding fault injection automatically stops after automatic rollback is enabled.
Metric
Automatic Rollback
- Click Finish.
- (Optional) Click Create Attack Task. Attack tasks are preset in the template. You can add an attack task as required. Click Create Task Group. Then, click Create Attack Task to add another attack task.
- Set the attack target.
Table 7 Parameters for adding an attack task Parameter
Example Value
Huawei Cloud
Attack Task
test-attacktask
Attack Target
- Click Next.
- Set parameters for selecting an attack scenario. For details, see Appendix: Attack Scenarios.
Table 8 Parameters for selecting an attack scenario Parameter
Example Value
Attack Type
Host resources
Attack Scenario
CPU usage increase
Attack Parameters
- CPU usage (%): 80
- Click Next.
Table 9 Parameters for configuring a monitoring task Parameter
Metric
Automatic Rollback
- Click Finish.
- If a preset scenario in the template is not required, click Delete next to the task. This step is optional.
- Click OK.
After a drill task is created, you can view the drill task and start the drill on the Resilience Center > Chaos Drills > Drill Tasks page.
- Log in to COC.
- Locate the drill task you want to start and click Start in the Operation column.
- Click OK.
On the drill details page, you can view the attack progress, including probe installation, drill execution, and environment clearance. The system automatically performs the three steps. The execution time depends on the attack time of the disruptor.
For probe installation, a probe will be installed on the target server. The probe runs in the system to receive disruptor commands for attack, query, and clearance. For environment clearance, all operations in the system are stopped and removed after the drill is complete or terminated.
- Perform the following operations on a drill execution ticket.
- Terminate: During a drill, click Terminate to stop the task to be executed or the task that is abnormal.
- Forcible termination: You are advised to use the termination function first. If the termination function fails, you can use the forcible termination function after 5 to 10 minutes. Note that the forcible termination function only closes the current drill ticket and does not automatically clear data in the environment. You need to manually clear data in the environment. For details, see Manually Clearing Data.
- Retry: If some or all attack tasks fail to check instances, install probes, clear environments, or perform steady-state detection, or if the drill times out, expand the failed attack task and click Retry to retry the task.
- Skip: If some or all attack tasks fail to be executed during the drill, expand a failed attack task and click Skip to skip the task and execute the next task.
- View details: Expand an attack task and click Details to view the attack details.
Creating a Drill Report
After a drill task is complete, you can directly create a report if necessary. After a report is created, you can export the report as a PDF file and send it to related personnel. The entire process is flexible and efficient, meeting the requirements of the entire process from production to format fixing.
You can modify the actual fault rectification duration, create improvement tickets, and view fault-handling records in a drill report so that you can comprehensively record and manage drill activities and results.
- Log in to COC.
- Locate the target drill task and click Drill Record in the Operation column.
- Locate the drill record to be operated and click Generate Report in the Operation column.
The drill report consists of the following modules:
- Recovery capability scoring module: You can modify the actual recovery duration. The system automatically generates a recovery capability score.
- Basic information module: displays basic information about a drill task, including the drill task name, drill report ID, drill start time, end time, drill executor, drill duration, and expected fault recovery duration (minutes).
- Drill process module: displays drill task cards.
- Attack task group module: displays attack task details, including attack targets, steady-state metrics, and monitoring metrics.
The list of selected instances is displayed for attack targets. Line charts are displayed for steady-state metrics and monitoring metrics. If no data is available, No data available is displayed.
- Improvement item module: You can create improvement tickets. The improvement details are displayed by default, including the processing and verification information.
- Click Edit Duration to change the actual recovery duration.
Actual recovery duration: indicates the actual time required for an application to automatically recover to the normal state or achieve recovery through the execution of a contingency plan after a fault is injected.
Figure 2 Modifying the actual recovery duration
Table 10 Parameters for modifying the actual recovery duration Parameter
Fault Detection Duration (Minutes)
Enter the fault detection duration.
Duration from the time when the fault injection is complete until the time when the fault alarm is received.
Fault Demarcation Duration (Minutes)
Enter the fault demarcation duration.
Duration from the time when an alarm is reported until the time when the fault demarcation is complete
Fault Rectification Duration (Minutes)
Enter the fault rectification duration.
Time from fault demarcation until fault rectification.
- Click OK.
After the actual recovery duration is changed, the system automatically generates a recovery capability score.
- Click Create Improvement Ticket. In the displayed dialog box, set the improvement ticket information. Figure 3 Creating an improvement ticket
Table 11 Parameters for creating an improvement ticket Parameter
Improvement Ticket
Name of an improvement ticket.
Application
Select an application for which the improvement is performed.
Type
Select an improvement type. You can choose to improve products, O&M, management, or monitoring & alarming.
Improvement Owner
Select an owner.
Improvement Acceptor
Select an acceptance user.
Expected Completion Time
Enter the expected completion time (accurate to day). The selected date cannot be earlier than today.
Symptom
Enter the incident-related symptom.
The value can contain a maximum of 1,000 characters.
Improvement Ticket Closure Criteria
Enter the improvement ticket closure criteria.
- Click OK.
After the ticket is created, the improvement item list is expanded by default, including the processing and verification information.
Viewing Drill Records
You can view the records of a drill task. A drill task that has not been executed does not contain a record.
- Log in to COC.
The basic information about the drill task includes the drill task name, drill task ID, attack details, and failure mode. All drill records include the drill record ID, execution status, executor, drill start time, and drill end time.
- Locate the drill record to be viewed and click View Progress in the Operation column.
View the attack progress, attack details, and monitoring details of the current drill task.
- The drill record module displays attack task details, including the progress, task information, and execution time.
- The attack details module displays the attack status of instances in the application of the current task. BMSs, FlexusL (HCSS) instances, and CSS instances are not supported.
- The monitoring details module displays real-time monitoring data of attack targets. You need to configure a drill monitoring task when creating an attack task. The screen can be zoomed in to the horizontal full-screen mode.
Forcibly terminating a drill task only closes the current drill ticket and does not automatically clear data. You need to manually clear the data.
The clearance methods vary from probe to probe. For details, see Table 12.
| Probe Type | Disruptor Type | How to Clear |
| CFE | All | 1. Log in to the console. 2. Go to the /usr/local/cdr_probe and /usr/local/COC-CDR-Probe directories. 3. Run rm -rf /usr/local/cdr_probe/* and rm -rf /usr/local/COC-CDR-Probe/* to delete all files in the directories. |
| CSS | All | No residual data exists. |
| DCS | All | No residual data exists. |
| DDS | All | No residual data exists. |
| Platform | All | No residual data exists. |
| RDS | RDS_FAILOVER (switching over RDS primary and standby nodes) | No residual data exists. |
| RDS_SHUTDOWN (stopping an RDS instance) | Start the DCS instance by referring to Relational Database Service Documentation. | |
| Script | SCRIPT_FAULT (customizing scripts) | 1. Cancel the ticket that is not closed (choose Task Management > Execution Records > Script Tickets). 2. Execute the clean method in the custom script. |
| CCE | All | Delete the namespace and related components from the Kubernetes cluster.
In this section, you will find a standard drill template library covering multiple scenarios, including 12 core template categories, such as incident response, process walkthrough, and hands-on contingency plan exercises.
All templates are designed based on industry best practices and feature structural completeness and content reusability. Each includes a standard framework—such as drill context, workflow steps, and role assignments—and supports rapid customization of scenario parameters, risk factors, and response procedures to meet specific operational needs. The instructions and error-prone prompts can help you customize your drill tasks efficiently using these templates, achieving the goal of "ready-to-use, quick-to-deploy" drill preparation.
| Template | Template Description | Tag | Level | Task Group Name | Attack Scenario |
| Cross-AZ DR | This drill simulates how a DR failover is performed for the target service and its antecedent middleware when an AZ is faulty or the network is abnormal in the DR deployment architecture. | DR | Advanced | Cross-AZ DR | Server disconnection |
| Initial Chaos Drill | This is essential for beginners to experience the chaos drill process. | Node | Basic | Initial Chaos Drill | Qualifying practice |
| High System Resource Usage | This drill specifies the system resource usage to test the service performance in high-pressure scenarios. When host resources are insufficient, you can address the problem in advance. | Node | Medium | Disk Stress | Disk usage increase |
| Memory Stress | Memory usage increase | ||||
| CPU Stress | CPU usage increase | ||||
| HPA Configuration in Kubernetes | In the cloud native architecture, auto scaling is an important feature. This drill simulates scale-up after pod resource usage (such as memory) increases in a short period of time and scale-down after resource usage decreases. | Containers and clusters | Advanced | HPA Configuration in Kubernetes | Pod memory usage increase |
| Data Storage Exception | Generally, service records are stored on the host or middleware where the service is located. Logs are stored on the disk of the host, and data is stored on the middleware such as DDS. This drill simulates the scenario where the ECS disk I/O is high and the primary and secondary switchover is performed. | Services and data | Medium | Data Storage Exception | Disk I/O pressure increase |
| Forcibly promoting a secondary node to primary | |||||
| Automatic Pod Recovery and Scheduling | Kubernetes schedules workloads based on pods. When workloads are generated, the scheduler automatically allocates pods in the workloads. For example, the scheduler distributes pods to nodes that have enough resources. | Cluster | Medium | Automatic Pod Recovery and Scheduling | Memory usage increase |
| Forcibly stopping a pod | |||||
| Network Instability Affecting Service Performance | This drill injects a network delay to the NIC of the service host to simulate the impact on services when the network is unstable. | Network | Medium | Network Instability Affecting Service Performance | Network latency |
| Environment Overload in the Microservice Architecture | Microservices are the mainstream architecture. The core value of microservices is to shorten the service release period and ensure reliable system operation. However, microservices also bring many challenges, such as how to locate and rectify faults in the microservice architecture. This drill simulates overloaded nodes of multiple microservices for your reference. | DR | Medium | Environment Overload in the Microservice Architecture | CPU usage increase |
| Connection exhaustion | |||||
| Process killing | |||||
| Abnormal Server Power-off | This drill simulates whether services can be recovered with no data loss after a server is powered off. In this drill, you can use the corresponding preset contingency plan to recover services after a node is powered off. | Services and data | Medium | Abnormal Server Power-off | Device shutdown |
| Data Loss in Service Middleware Cache | In large-scale concurrent data query scenarios where high data query efficiency is required, Redis has become an essential service for internet applications due to its significant speed advantages over traditional databases. However, it may face issues related to data consistency and reliability. This chaos drill aims to verify whether service operations remain normal after clearing Redis data. | DR | Medium | Data Loss in Service Middleware Cache | DCS instance restart |
| Misoperations in the Host Configuration File | It is a high risk for O&M personnel to directly perform black screen operations on the service host. If the permission of the service configuration file is directly modified, the service process may not be able to read or write the file. This chaos drill uses a custom script to perform operations (modifying or removing permissions) on the host configuration file. You can use the prepared contingency plan to recover the service. | Services and data | Medium | Misoperations in the Host Configuration File | Customizing a script |
| Automatic Workload Switchover | FlexusL instances are next-generation, out-of-the-box, lightweight cloud servers tailored for developers and small- to medium-sized enterprises. You can deploy databases or service applications on FlexusL instances. This drill simulates service workload switchover when processes disappear and database nodes are disconnected. | Network | Advanced | Automatic Workload Switchover | Process killing |
| Network disconnection |
More Operations
After creating a drill task, you can perform the following operations as required.
| Function | Scenario | Operation |
| Modifying a Drill Task | You can modify a created drill task. Note: If the task has been started and a drill record has been generated, the task cannot be modified. | On the drill task page, locate the target drill task and choose More > Modify in the Operation column. |
| Deleting a Drill Task | If a created drill task is no longer needed, you can delete it. Do not delete the drill task in the following scenarios:
| On the drill task page, locate the target drill task and choose More > Delete in the Operation column. |
| Exporting a Report | After a chaos drill is complete, you can export the drill details to a local PC in PDF format for offline access, sharing, and compliance auditing and archiving. | On the drill report page, click Export Report to download the PDF file. |
| Refreshing the Drill Reports Page | After a drill is complete, you can use the refresh function to update the drill report with the latest recovery capability score and improvement items. | On the Drill Reports page, click Refresh in the upper right corner to refresh the current page. |
| Viewing a Drill Report | You can view the drill report to review the execution details, monitoring metric changes, and improvement items throughout the drill process, providing a basis for review and optimization. | On the Drill Records page, locate the row that contains the target drill record and click View Report in the Operation column. |
Helpful Links
