Overview
Monitoring Center is a next-generation O&M platform built by Huawei Cloud for cloud native containers. It monitors applications and resources in real time, collects metrics and events to analyze application health statuses, and visualizes multi-dimensional data. Compatible with mainstream open-source components, Monitoring Center supports quick fault locating.
Functions
- Multi-dimensional data insights: comprehensively monitor Kubernetes native containers and display the metrics of clusters, nodes, workloads, events, and pods for the health status and load of clusters.
- Dashboard: shows various graphs such as line graphs and digit graphs on the same screen for comprehensive data display.
Advantages
- Monitoring Center is deeply integrated with Prometheus, a mature monitoring project of the Cloud Native Computing Foundation (CNCF). It brings in observability for your cloud native applications by collecting, storing, and visually presenting O&M data, such as key metrics and events.
- Monitoring Center provides full-stack monitoring from cloud native infrastructure resources to application workloads, enabling you to clearly perceive the infrastructure and application load status anytime anywhere.
- Monitoring Center monitors Kubernetes clusters, nodes, and pods, enables end-to-end tracing and visualization for services, and provides cluster health diagnosis, greatly speeding up fault analysis and locating.
- Monitoring Center provides ready-to-use add-ons, data collection, and cloud native cluster monitoring. Compared with monitoring developed based on open-source components, it is more competitive in reliability, availability, and deployment.
- Monitoring Center provides lightweight add-ons for metric collection. Compared with Prometheus, it greatly reduces resource usage and facilitates deployment.
Monitoring Center Architecture
The cloud native cluster monitoring add-on collects metrics exposed by exporters in CCE clusters and writes the data to the AOM instance in Prometheus RemoteWrite mode.
Monitoring Center provides multi-dimensional data insights and dashboard based on the metrics stored in the AOM instance.
Based on the RemoteWrite feature, the cloud native cluster monitoring add-on reports monitoring metrics in a cluster to the third-party monitoring platform through Bearer Token authentication.
Prometheus Monitoring
Prometheus has become the most common tool for cloud native observability. Its powerful monitoring capabilities and active community ecosystem make it become one of the most active hosting projects of CNCF. Currently, the CCE add-on page provides an add-on (Cloud Native Cluster Monitoring) for monitoring Kubernetes clusters.
Based on the Prometheus monitoring ecosystem, Huawei Cloud AOM provides hosted Prometheus instances for CCE, which are suitable for monitoring CCE clusters and applications running on them. By default, AOM instances integrate the cloud-native monitoring add-ons of CCE clusters. After Monitoring Center is enabled, metrics are automatically reported to the specified AOM instances.
AOM ICAgent Monitoring
As the collector of Huawei Cloud AOM, ICAgent runs on hosts to collect metrics, logs, and application performance data in real time. For hosts bought on the ECS or BMS console, install the ICAgent manually. For cluster nodes, ICAgent is automatically installed.
