LoadBalancer Service Annotations
You can add annotations to a YAML file to enable advanced CCE functions. This section describes the available annotations when a LoadBalancer Service is created.
Indexes
Interconnection with ELB
| Parameter | Type | Description | Supported Cluster Version |
| kubernetes.io/elb.class | String | Select a proper load balancer type. This parameter cannot be modified after the Service is created. Options:
The default value is union. | v1.9 or later |
| kubernetes.io/elb.id | String | Mandatory when an existing load balancer is associated. This parameter cannot be modified after the Service is created. ID of a load balancer. How to obtain: Log in to the ELB console and click the load balancer name. On the Summary tab of the load balancer details page, find the ID field and copy it. NOTE: The system preferentially uses the kubernetes.io/elb.id annotation to associate the Service with a load balancer. If this annotation is not specified, it falls back to the spec.loadBalancerIP field. spec.loadBalancerIP may be deprecated in future Kubernetes versions. Therefore, using annotations is recommended. For details, see Deprecation. | v1.9 or later |
| kubernetes.io/elb.autocreate | Mandatory when load balancers are automatically created. This parameter cannot be modified after the Service is created. CAUTION: kubernetes.io/elb.id and kubernetes.io/elb.autocreate cannot be specified concurrently. If both annotations are specified in a Service, CCE will use an existing load balancer instead of automatically creating one. If this Service is deleted, the existing load balancer is considered as an automatically created one. If no other resources are associated with the load balancer, the load balancer will also be deleted. Example:
| v1.9 or later | |
| kubernetes.io/elb.enterpriseID | String | Optional when load balancers are automatically created. This parameter is available in clusters v1.15 or later. In clusters earlier than v1.15, load balancers are created in the default project by default. This parameter indicates the ID of the enterprise project in which the ELB load balancer will be created. If this parameter is not specified or is set to 0, resources will be bound to the default enterprise project. How to obtain: Log in to the EPS console, click the name of the target enterprise project. On the enterprise project details page, find the ID field and copy the ID. | v1.15 or later |
| kubernetes.io/elb.subnet-id | String | Optional when load balancers are automatically created. ID of the subnet where the cluster is located. The value can contain 1 to 100 characters.
| Mandatory for clusters of a version earlier than v1.11.7-r0 Discarded in clusters of a version later than v1.11.7-r0 |
| kubernetes.io/elb.lb-algorithm | String | Specifies the load balancing algorithm of the backend server group. The default value is ROUND_ROBIN. Options:
NOTE: If this parameter is set to SOURCE_IP, the weight setting (weight field) of backend servers bound to the backend server group is invalid, and sticky session cannot be enabled. | v1.9 or later |
The following shows how to use the preceding annotations:
- Associate an existing load balancer. For details, see Using kubectl to Create a Service (Using an Existing Load Balancer).
apiVersion: v1 kind: Service metadata: name: nginx annotations: kubernetes.io/elb.id: <your_elb_id> # Load balancer ID. Replace it with the actual value. kubernetes.io/elb.class: performance # Load balancer type kubernetes.io/elb.lb-algorithm: ROUND_ROBIN # Load balancer algorithm spec: selector: app: nginx ports: - name: service0 port: 80 protocol: TCP targetPort: 80 type: LoadBalancer - Automatically create a load balancer. For details, see Using kubectl to Create a Service (Automatically Creating a Load Balancer). Shared load balancer:
apiVersion: v1 kind: Service metadata: annotations: kubernetes.io/elb.class: union kubernetes.io/elb.autocreate: '{ "type": "public", "bandwidth_name": "cce-bandwidth-1551163379627", "bandwidth_chargemode": "bandwidth", "bandwidth_size": 5, "bandwidth_sharetype": "PER", "eip_type": "5_bgp" }' kubernetes.io/elb.enterpriseID: '0' # ID of the enterprise project to which the load balancer belongs kubernetes.io/elb.lb-algorithm: ROUND_ROBIN # Load balancer algorithm labels: app: nginx name: nginx spec: ports: - name: service0 port: 80 protocol: TCP targetPort: 80 selector: app: nginx type: LoadBalancerDedicated load balancer:apiVersion: v1 kind: Service metadata: name: nginx labels: app: nginx namespace: default annotations: kubernetes.io/elb.class: performance kubernetes.io/elb.autocreate: '{ "type": "public", "bandwidth_name": "cce-bandwidth-1626694478577", "bandwidth_chargemode": "bandwidth", "bandwidth_size": 5, "bandwidth_sharetype": "PER", "eip_type": "5_bgp", "available_zone": [ "" ], "l4_flavor_name": "L4_flavor.elb.s1.small" }' kubernetes.io/elb.enterpriseID: '0' # ID of the enterprise project to which the load balancer belongs kubernetes.io/elb.lb-algorithm: ROUND_ROBIN # Load balancer algorithm spec: selector: app: nginx ports: - name: cce-service-0 targetPort: 80 nodePort: 0 port: 80 protocol: TCP type: LoadBalancer
Sticky Session
| kubernetes.io/elb.session-affinity-mode | String | Source IP address-based sticky session means that access requests from the same IP address are forwarded to the same backend server.
NOTE: When kubernetes.io/elb.lb-algorithm is set to SOURCE_IP (source IP hash), sticky session cannot be enabled. | v1.9 or later |
| kubernetes.io/elb.session-affinity-option | Sticky session timeout. | v1.9 or later |
apiVersion: v1
kind: Service
annotations:
kubernetes.io/elb.session-affinity-mode: SOURCE_IP # The sticky session type is source IP address.
kubernetes.io/elb.session-affinity-option: '{"persistence_timeout": "30"}' # Stickiness duration, which is measured in minutes
selector:
app: nginx
ports:
- name: service0
port: 80
protocol: TCP
targetPort: 80
type: LoadBalancer Health Check
| kubernetes.io/elb.health-check-flag | String | Whether to enable the ELB health check. If this annotation is not added, the health check is enabled by default.
If this function is enabled, you must set kubernetes.io/elb.health-check-option or kubernetes.io/elb.health-check-options. Otherwise, ELB health checks will fail. | v1.9 or later |
| kubernetes.io/elb.health-check-option | ELB health check configuration option. | v1.9 or later | |
| kubernetes.io/elb.health-check-options | ELB health check configuration options. Each Service port can be configured separately, and you can configure only some ports. NOTE: Either kubernetes.io/elb.health-check-option or kubernetes.io/elb.health-check-options can be configured. | v1.19.16-r5 or later v1.21.8-r0 or later v1.23.6-r0 or later v1.25.2-r0 or later |
- The following shows how to use kubernetes.io/elb.health-check-option:
apiVersion: v1 kind: Service metadata: name: nginx annotations: kubernetes.io/elb.id: <your_elb_id> # Load balancer ID. Replace it with the actual value. kubernetes.io/elb.class: performance # Load balancer type kubernetes.io/elb.health-check-flag: 'on' # Enable ELB health check. kubernetes.io/elb.health-check-option: '{ "protocol":"TCP", "delay":"5", "timeout":"10", "max_retries":"3" }' spec: selector: app: nginx ports: - name: service0 port: 80 protocol: TCP targetPort: 80 type: LoadBalancer - For details about how to use kubernetes.io/elb.health-check-options, see Configuring Health Check on Multiple LoadBalancer Service Ports.
Passthrough Capability
| kubernetes.io/elb.pass-through | String | Whether the access requests from within the cluster to the Service pass through the ELB load balancer. | v1.19 or later |
For details about applications and use cases, see Configuring Passthrough Networking for a LoadBalancer Service.
Resource Tags
| kubernetes.io/elb.tags | String | Add resource tags to a load balancer. This parameter can be configured only when a load balancer is automatically created. A tag is in the format of "key=value". Use commas (,) to separate multiple tags. | v1.23.11-r0, v1.25.6-r0, v1.27.3-r0, v1.23.8-r1, v1.25.3-r1, or later |
For details about applications and use cases, see Using kubectl to Create a Service (Automatically Creating a Load Balancer).
Changing a Custom EIP
| kubernetes.io/elb.custom-eip-id | String | ID of the custom EIP, which can be seen on the EIP console. The EIP must not already be bound. | v1.23.18-r0, v1.25.13-r0, v1.27.10-r0, v1.28.8-r0, v1.29.4-r0, v1.30.1-r0, or later |
For details about applications and use cases, see Changing a Custom EIP for a LoadBalancer Service.
Configuring a Reclaim Policy for an Auto-created Load Balancer
| kubernetes.io/elb.instance-reclaim-policy | String | Optional when load balancers are automatically created. Configure a reclaim policy for an auto-created load balancer. The options are as follows:
| v1.28.15-r60, v1.29.15-r20, v1.30.14-r20, v1.31.10-r20, v1.32.6-r20, v1.33.5-r10, or later |
The following shows how to use the preceding annotation:
apiVersion: v1
kind: Service
labels:
app: test
version: v1
namespace: default
annotations:
kubernetes.io/elb.autocreate: '{"type":"inner","available_zone":["******"],"elb_virsubnet_ids":["******"],"ipv6_vip_virsubnet_id":"******","l7_flavor_name":"","l4_flavor_name":"L4_flavor.elb.pro.max","vip_subnet_cidr_id":"******"}'
kubernetes.io/elb.health-check-option: '{"protocol":"TCP","delay":"5","timeout":"10","max_retries":"3"}'
kubernetes.io/elb.instance-reclaim-policy: retain # Configure a reclaim policy for an auto-created load balancer.
selector:
app: nginx
version: v1
externalTrafficPolicy: Cluster
ports:
targetPort: 80
nodePort: 0
port: 80
protocol: TCP
type: LoadBalancer
loadBalancerIP: '' HTTP/HTTPS/QUIC
| kubernetes.io/elb.protocol-port | String | If a Service is HTTP/HTTPS/QUIC-compliant, configure the protocol and port in the format of protocol:port. where,
| v1.19.16 or later v1.28.15-r80, v1.29.15-r40, v1.30.14-r40, v1.31.14-r0, v1.32.9-r0, v1.33.7-r0, v1.34.2-r0, or later (if QUIC is used) |
| kubernetes.io/elb.cert-id | String | ID of an ELB certificate, which is used as the HTTPS server certificate. How to obtain: Log in to the ELB console and choose Certificates. In the certificate list, copy the ID under the target certificate name. | v1.19.16 or later |
For details about applications and use cases, see Configuring HTTP/HTTPS for LoadBalancer Services and Configuring a QUIC Listener for a LoadBalancer Service.
SNI
| kubernetes.io/elb.tls-certificate-ids | String | In ELB, the IDs of SNI certificates that must contain a domain name are separated by commas (,). How to obtain: Log in to the ELB console and choose Certificates. In the certificate list, copy the ID under the target certificate name. | v1.23.13-r0, v1.25.8-r0, v1.27.5-r0, v1.28.3-r0, or later |
HTTPS must be enabled. For details, see Configuring SNI for a LoadBalancer Service.
HTTP/2
| kubernetes.io/elb.http2-enable | String | Whether HTTP/2 is enabled. Request forwarding using HTTP/2 improves access performance between your application and the load balancer. However, the load balancer still uses HTTP/1.x to forward requests to the backend server. Options:
Note: HTTP/2 can be enabled or disabled only when the listener uses HTTPS. This parameter is invalid and defaults to false when the listener protocol is HTTP. | v1.23.13-r0, v1.25.8-r0, v1.27.5-r0, v1.28.3-r0, or later |
For details about applications and use cases, see Configuring HTTP/2 for LoadBalancer Services.
Configuring Mutual Authentication
| kubernetes.io/elb.client-ca-cert-id | String | Required only for mutual authentication. The ELB certificate ID serves as the CA certificate. How to obtain: Log in to the ELB console and choose Certificates. In the certificate list, copy the ID under the target certificate name. | Dedicated load balancers are available in clusters v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later. Shared load balancers are available in clusters v1.28.15-r60, v1.29.15-r20, v1.30.14-r20, v1.31.10-r20, v1.32.6-r20, v1.33.5-r10, or later. |
apiVersion: v1
kind: Service
labels:
app: test
namespace: default
annotations:
kubernetes.io/elb.id: *****
kubernetes.io/elb.protocol-port: https:443
kubernetes.io/elb.cert-id: *****
kubernetes.io/elb.client-ca-cert-id: ***** # Configure mutual authentication.
kubernetes.io/elb.security-pool-protocol: 'off'
kubernetes.io/elb.tls-ciphers-policy: tls-1-2
selector:
app: test
ports:
targetPort: 80
nodePort: 0
port: 443
protocol: TCP
type: LoadBalancer
loadBalancerIP: **.**.**.** Configuring the Backend Routing Policy of a Listener
For details about applications and use cases, see Configuring a UDP listener for the QUIC Protocol for a LoadBalancer Service.
| kubernetes.io/elb.pools-options | String | Backend server group configuration, including the backend protocol, load balancing algorithm, and sticky session. The annotation value is a JSON array. For details, see Table 13. CAUTION: After the kubernetes.io/elb.pools-options annotation is configured, the legacy annotations for load balancing algorithm (kubernetes.io/elb.lb-algorithm), sticky sessions (kubernetes.io/elb.session-affinity-option or kubernetes.io/elb.session-affinity-options), or backend protocol (kubernetes.io/elb.security-pool-protocol) cannot be used. | v1.28.15-r80, v1.29.15-r40, v1.30.14-r40, v1.31.14-r0, v1.32.9-r0, v1.33.7-r0, v1.34.2-r0, or later |
The following is an example of using the preceding annotation:
apiVersion: v1
kind: Service
labels:
app: nginx
namespace: default
annotations:
kubernetes.io/elb.id: 95df847a-dec7-4c7f-8e8b-5422344f6153
kubernetes.io/elb.cert-id: d30be9bc114a40099bc2c8e4d1855eb3
kubernetes.io/elb.pools-options: '[{"protocol":"HTTP","lb_algorithm":"ROUND_ROBIN","target_service_port":"TCP:443"}]'
selector:
app: nginx
ports:
targetPort: 80
nodePort: 0
port: 443
protocol: TCP
type: LoadBalancer
loadBalancerIP: **.**.**.** | Parameter | Mandatory | Type | Description |
| protocol | Yes | String | Definition: Protocol of a backend server. If the frontend protocol and port remain unchanged, the backend protocol cannot be modified. Constraints: The custom configuration must match the protocol of the frontend listener. For details about the matching rules, see Mapping Between Frontend and Backend Protocols for Load Balancing and Configuration Examples. No constraints apply to global configurations. Range: TCP, TLS, UDP, HTTP, HTTPS, or QUIC Default value: N/A |
| target_service_port | No | String | Definition: The backend server group to which the configuration applies. The value is composed of the protocol and port defined in spec.ports. For example, TCP:80 applies the configuration to the backend server group using TCP on port 80. If omitted or set to *, the configuration is treated as global and applies to all backend server groups. Constraints: For global configuration, the array length must be 1. A Service may contain listeners with different frontend protocols, but backend protocol options are limited. If this parameter is set globally and the backend protocol does not match the frontend protocol, the default value will be used. For details about the matching rules, see Mapping Between Frontend and Backend Protocols for Load Balancing and Configuration Examples. Other parameters depend on the backend protocol, so defaults may be applied when mismatches occur. Range: <protocol>:<port> Default value: None (Global configuration is used.) |
| lb_algorithm | Yes | String | Definition: The load balancing algorithm used by a backend server group Constraints:
Range:
Default value: If the backend protocol is QUIC, the value can only be QUIC_CID. The default value is ROUND_ROBIN for other protocols. |
| session_persistence | No | Definition: The sticky session settings Constraints: None Default value: Disabled | |
| quic_cid_hash_strategy | No | Definition: The multi-path forwarding behavior based on destination QUIC connection IDs Constraints: This parameter can be configured only when lb_algorithm is set to QUIC_CID. Default value: N/A |
Dynamically Adjusting the Weight of the Backend Server
| kubernetes.io/elb.adaptive-weight | String | Dynamically adjust the weight of the load balancer backend server based on the number of pods on the server. In this way, the requests received by each pod are more balanced.
| v1.21 or later |
This parameter is invalid in passthrough networking, where dedicated load balancers are used in the CCE Turbo cluster.
This parameter is invalid after cross-cluster ELB access is enabled.
apiVersion: v1
kind: Service
annotations:
kubernetes.io/elb.adaptive-weight: 'true' # Enable dynamic adjustment of the weight of the backend ECS.
selector:
app: nginx
ports:
- name: service0
port: 80
protocol: TCP
targetPort: 80
type: LoadBalancer Cross-cluster Access
| kubernetes.io/elb.multicluster | String | Value true indicates cross-cluster Service access is enabled. | v1.19.16-r0, v1.21.4-r0, v1.23.1-r0, or later |
| kubernetes.io/elb.multivpc | String | Value true indicates cross-cluster access in different VPCs is enabled. This function is available only if kubernetes.io/elb.multicluster is set to true. This parameter cannot be modified after the Service is created. Only dedicated load balancers are supported. | v1.19.16-r4, v1.21.7-r0, v1.23.5-r0, or later |
| kubernetes.io/elb.multicluster-loadbalancer-weight | String | Weight of the traffic received by the cluster Service. The value ranges from 0 to 100. A larger value indicates more traffic distributed. | v1.19.16-r0, v1.21.4-r0, v1.23.1-r0, or later |
| kubernetes.io/elb.multicluster-resource-recycle-policy | String | Policy for deleting ELB resources. The default value of this parameter is member-only.
For details about applications and use cases, see Configuring Multiple Cross-Cluster Backend Servers for a LoadBalancer Service.
Blocklist/Trustlist
| kubernetes.io/elb.acl-id | String |
| v1.23.12-r0, v1.25.7-r0, v1.27.4-r0, v1.28.2-r0, or later |
| kubernetes.io/elb.acl-status | String | This parameter is mandatory when you configure an IP address blocklist or trustlist for a load balancer. Options:
| kubernetes.io/elb.acl-type | String | This parameter is mandatory when you configure an IP address blocklist or trustlist for a load balancer. Options:
apiVersion: v1
kind: Service
annotations:
kubernetes.io/elb.acl-id: <your_acl_id> # ID of an IP address group for accessing a load balancer
kubernetes.io/elb.acl-status: 'on' # Enable access control.
kubernetes.io/elb.acl-type: 'white' # Trustlist for access control
selector:
app: nginx
ports:
- name: service0
port: 80
protocol: TCP
targetPort: 80
type: LoadBalancer For details about applications and use cases, see Configuring a Blocklist/Trustlist Access Policy for a LoadBalancer Service.
Host Network
| kubernetes.io/hws-hostNetwork | String | This annotation can be used by the Service only if the pod uses the host network. After this annotation is used, ELB forwards requests to the host network. Options:
| v1.9 or later |
apiVersion: v1
kind: Service
annotations:
kubernetes.io/hws-hostNetwork: 'true' # The load balancer forwards the request to the host network.
selector:
app: nginx
ports:
- name: service0
port: 80
protocol: TCP
targetPort: 80
type: LoadBalancer Timeout
| kubernetes.io/elb.keepalive_timeout | String | Timeout for client connections. If there are no requests reaching the load balancer during this period, the load balancer will disconnect the connection from the client and establish a new connection when there is a new request. Value:
| Dedicated load balancers: v1.19.16-r30, v1.21.10-r10, v1.23.8-r10, v1.25.3-r10, or later Shared load balancers: v1.23.13-r0, v1.25.8-r0, v1.27.5-r0, v1.28.3-r0, or later |
| kubernetes.io/elb.client_timeout | String | Timeout for waiting for a request from a client. There are two cases:
The value ranges from 1 to 300 (in seconds). The default value is 60. | v1.23.13-r0, v1.25.8-r0, v1.27.5-r0, v1.28.3-r0, or later |
| kubernetes.io/elb.member_timeout | String | Timeout for backend server response. After a request is forwarded to the backend server, if the backend server does not respond within the duration specified by member_timeout, the load balancer will stop waiting and return HTTP 504 Gateway Timeout. The value ranges from 1 to 300 (in seconds). The default value is 60. | v1.23.13-r0, v1.25.8-r0, v1.27.5-r0, v1.28.3-r0, or later |
For details about applications and use cases, see Configuring Timeout for a LoadBalancer Service.
Configuring an HTTP/HTTPS Header
| kubernetes.io/elb.x-forwarded-port | String | Enables the load balancer to pass the listener port to backend servers via the X-Forwarded-Port header field in forwarded requests.
| kubernetes.io/elb.x-forwarded-for-port | String | Enables the load balancer to pass the client port to backend servers via the X-Forwarded-For-Port header field in forwarded requests.
| kubernetes.io/elb.x-forwarded-host | String |
| kubernetes.io/elb.x-real-ip | String |
| v1.25.16-r30, v1.27.16-r30, v1.28.15-r20, v1.29.13-r0, v1.30.10-r0, v1.31.6-r0, v1.32.1-r0, or later |
For details about applications and use cases, see Configuring an HTTP/HTTPS Header for a LoadBalancer Service.
Enabling GZIP
| kubernetes.io/elb.gzip-enabled | String | LoadBalancer Services support data compression, which reduces the size of files to be transferred, improves file transfer efficiency, and reduces the bandwidth needed for the transmission. If this function is enabled, specific files will be compressed. If it is not enabled, files will not be compressed. By default, data compression is disabled. The files in the following format can be compressed:
This function is available only for HTTP/HTTPS listeners of dedicated load balancers. Deleting the advanced configuration for data compression or the target annotations will not modify the existing ELB settings. | v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later |
For details about applications and use cases, see Configuring GZIP Data Compression for a LoadBalancer Service.
Configuring Graceful Exit for the Load Balancer Backend
You can configure the graceful exit time for the backend servers of load balancers associated with TCP- or UDP-compliant Services. Graceful exit is set to 300s by default.
ELB does not offer this feature to everyone. This feature is only supported by dedicated load balancers. To use this feature, submit a service ticket to ELB.
| kubernetes.io/elb.connection-drain-enable | String | Whether to enable graceful exit for the load balancer backend.
| kubernetes.io/elb.connection-drain-timeout | String | Graceful exit time of the load balancer backend. The value ranges from 10 to 4000 (in seconds). The default value is 300. |
Obtaining Client IP Addresses
| kubernetes.io/elb.transparent-client-ip | String | This parameter is available only when a shared load balancer is used to create a LoadBalancer Service that is TCP/UDP-compliant.
| v1.23.17-r0, v1.25.12-r0, v1.27.9-r0, v1.28.7-r0, v1.29.3-r0, or later |
For details about applications and use cases, see Enabling a LoadBalancer Service to Obtain the Client IP Address.
Configuring Port Ranges for a Listener
| kubernetes.io/elb.port-ranges | String | When using a dedicated load balancer with TCP, UDP, or TLS selected, you can create listeners that monitor ports within a range from 1 to 65535. Each listener supports a maximum of 10 non-overlapping port ranges. The parameter value is in the following format, where ports_name and port must be unique: '{"<ports_name_1>":["<port_1>,<port_2>","<port_3>,<port_4>"], "<ports_name_2>":["<port_5>,<port_6>","<port_7>,<port_8>"]}' For example, the port names are cce-service-0 and cce-service-1, and the listener listens to ports 100–200 and 300–400, and 500–600 and 700–800, respectively. '{"cce-service-0":["100,200", "300,400"], "cce-service-1":["500,600", "700,800"]}' NOTE: This function requires ELB. Before using this function, check whether ELB supports full-port listening and forwarding for layer-4 protocols in the current region. | v1.23.18-r0, v1.25.13-r0, v1.27.10-r0, v1.28.8-r0, v1.29.4-r0, v1.30.1-r0, or later |
For details about applications and use cases, see Configuring a Range of Listening Ports for LoadBalancer Services.
Configuring IP Addresses as Backend Servers
| kubernetes.io/elb.ip-target-enabled | String | Enable IP addresses as backend servers for a load balancer. After this function is enabled, the backend IP addresses added to the associated Service or ingress are all IP addresses in VPC subnets. For a CCE Turbo cluster, the backend is <pod-IP-address>:<target-port>. For a CCE standard cluster, the backend is <node-IP-address>:<NodePort>.
CAUTION:
For details about applications and use cases, see Configuring IP Addresses as Backend Servers for a LoadBalancer Service.
Configuring the Weight of StatefulSet Backend Pods
| kubernetes.io/elb.custom-backend-weights | String | The weight of StatefulSet backend pods. This function is supported only by CCE Turbo clusters and dedicated load balancers. | v1.29.15-r60, v1.30.14-r60, v1.31.14-r20, v1.32.9-r20, v1.33.7-r20, v1.34.3-r10, v1.35.1-r0, or later |
For details about applications and use cases, see Configuring Weights for StatefulSet Backend Pods in a LoadBalancer Service.
Disabling Listener Hosting for an Associated LoadBalancer Service
| kubernetes.io/elb.skip-managed-listener | String | Disables listener hosting. Once disabled, CCE no longer manages the listener associated with this Service.
| v1.29.15-r90, v1.30.14-r90, v1.31.14-r50, v1.32.13-r20, v1.33.12-r0, v1.34.8-r0, v1.35.5-r0, v1.36.1-r10, or later |
For details about applications and use cases, see Disabling Listener Hosting for LoadBalancer Services.
Configuring Rate Limiting for New and Concurrent Connections
| kubernetes.io/elb.cps | Integer | Definition: The maximum number of new connections that a listener can handle per second. Constraints: If this value exceeds the limit defined in the load balancer, the load balancer's limit takes precedence. Range: 0 to 1000000 Default value: 0, indicating no limit. | v1.30.14-r100, v1.31.14-r60, v1.32.13-r30, v1.33.12-r10, v1.34.8-r10, v1.35.5-r10, v1.36.2-r0, or later |
| kubernetes.io/elb.connection | Integer | Definition: The maximum number of concurrent connections that a listener can handle. Constraints: If this value exceeds the limit defined in the load balancer, the load balancer's limit takes precedence. Range: 0 to 1000000 Default value: 0, indicating no limit. |
For details about applications and use cases, see Configuring Rate Limiting on a LoadBalancer Service for New and Concurrent Connections.
Parameters for Automatically Creating a Load Balancer
| name | No | String | Name of the automatically created load balancer. The value can contain 1 to 64 characters. Only letters, digits, underscores (_), hyphens (-), and periods (.) are allowed. Default: cce-lb+service.UID |
| type | No | String | Network type of the load balancer.
Default: inner |
| bandwidth_id | No | String | Shared bandwidth ID, which must be specified when you use an existing shared bandwidth. The cluster version must be v1.30.14-r100, v1.31.14-r60, v1.32.13-r30, v1.33.12-r10, v1.34.8-r10, v1.35.5-r10, v1.36.2-r0, or later. |
| bandwidth_name | Yes for public network load balancers when no shared bandwidth ID is provided | String | Bandwidth name. The default value is cce-bandwidth-******. The value can contain 1 to 64 characters. Only letters, digits, underscores (_), hyphens (-), and periods (.) are allowed. |
| bandwidth_chargemode | Yes for public network load balancers when no shared bandwidth ID is provided | String | Bandwidth billing mode.
| bandwidth_size | Yes for public network load balancers when no shared bandwidth ID is provided | Integer | Bandwidth size. The value ranges from 1 Mbit/s to 2000 Mbit/s by default. Configure this parameter based on the bandwidth range allowed in your region. The minimum increment for bandwidth adjustment varies depending on the bandwidth range.
| bandwidth_sharetype | Yes for public network load balancers when no shared bandwidth ID is provided | String | Bandwidth sharing mode.
| eip_type | Yes for public network load balancers | String | EIP type.
The types vary by region. For details, see the EIP console. |
| vip_subnet_cidr_id | No | String | The ID of the IPv4 subnet where the load balancer resides. This subnet is used to allocate IP addresses for the load balancer to provide external services. The IPv4 subnet must belong to the cluster's VPC. If this parameter is not specified, the load balancer and the cluster will be in the same subnet by default. This field can be specified only for clusters v1.21 or later. How to obtain: Log in to the VPC console. In the navigation pane, choose Subnets. Filter the target subnet by the cluster's VPC name, click the subnet name, and copy the IPv4 Subnet ID on the Summary tab. |
| ipv6_vip_virsubnet_id | No | String | The ID of the IPv6 subnet where the load balancer is deployed. IPv6 must be enabled for the subnet. This parameter is available only for dedicated load balancers. How to obtain: Log in to the VPC console. In the navigation pane, choose Subnets. Filter the target subnet by the cluster's VPC name, click the subnet name, and copy the Network ID on the Summary tab. |
| elb_virsubnet_ids | No | Array of strings | The network ID of the subnet where the load balancer is located. This subnet is used to allocate IP addresses for accessing the backend server. If this parameter is not specified, the subnet specified by vip_subnet_cidr_id will be used by default. Load balancers occupy varying numbers of subnet IP addresses based on their specifications. Do not use the subnet CIDR blocks of other resources (such as clusters or nodes) as the load balancer's CIDR block. This parameter is available only for dedicated load balancers. Example: "elb_virsubnet_ids": [ "14567f27-8ae4-42b8-ae47-9f847a4690dd" ] How to obtain: Log in to the VPC console. In the navigation pane, choose Subnets. Filter the target subnet by the cluster's VPC name, click the subnet name, and copy the Network ID on the Summary tab. |
| vip_address | No | String | Private IP address of the load balancer. Only IPv4 addresses are supported. The IP address must be in the ELB CIDR block. If this parameter is not specified, an IP address will be automatically assigned from the ELB CIDR block. This parameter is only available in clusters v1.23.11-r0, v1.25.6-r0, v1.27.3-r0, or later versions. |
| available_zone | Yes | Array of strings | AZ where the load balancer is located. You can obtain all supported AZs by getting the AZ list. This parameter is available only for dedicated load balancers. |
| l4_flavor_name | No | String | Flavor name of the Layer 4 load balancer. This parameter is mandatory when TCP, TLS, or UDP is used. You can obtain all supported types by getting the flavor list. This parameter is available only for dedicated load balancers. |
| l7_flavor_name | No | String | Flavor name of the Layer 7 load balancer. This parameter is mandatory when HTTP or HTTPS is used. You can obtain all supported types by getting the flavor list. This parameter is available only for dedicated load balancers. Its value must match that of l4_flavor_name, both of which must be either elastic or fixed. |
| delay | No | String | Health check interval (s) Value range: 1 to 50. Default value: 5 |
| timeout | No | String | Health check timeout, in seconds. Value range: 1 to 50. Default value: 10 |
| max_retries | No | String | Maximum number of health check retries. Value range: 1 to 10. Default value: 3 |
| protocol | No | String | Health check protocol. Value options: HTTPS, TLS, gRPC, TCP, UDP, and HTTP To use HTTPS, TLS, or gRPC, you need to use a dedicated load balancer, and the cluster version must be v1.28.15-r90, v1.29.15-r50, v1.30.14-r50, v1.31.14-r10, v1.32.9-r10, v1.33.7-r10, v1.34.3-r0, or later. gRPC and TLS depend on the ELB capabilities. Before using this function, submit a service ticket to enable the required ELB capabilities.
CAUTION: To change the health check protocol (including the switchover between global check and custom check), disable the health check, enable it again, and change the protocol. |
| path | No | String | Health check URL. This parameter needs to be configured when the protocol is HTTP, HTTPS, or gRPC. Default value: / Value range: 1-80 characters |
| target_service_port | Yes | String | Port for health check specified by spec.ports. The value consists of the protocol and port number, for example, TCP:80. |
| monitor_port | No | String | Re-specified port for health check. If this parameter is not specified, the service port is used by default. NOTE: Ensure that the port is in the listening state on the node where the pod is located. Otherwise, the health check result will be affected. |
| protocol | No | String | Health check protocol. Default value: protocol of the associated Service Value options: HTTPS, TLS, gRPC, TCP, UDP, and HTTP To use HTTPS, TLS, or gRPC, you need to use a dedicated load balancer, and the cluster version must be v1.28.15-r90, v1.29.15-r50, v1.30.14-r50, v1.31.14-r10, v1.32.9-r10, v1.33.7-r10, v1.34.3-r0, or later. gRPC and TLS depend on the ELB capabilities. Before using this function, submit a service ticket to enable the required ELB capabilities.
| expected_codes | No | String | Expected response status code. This parameter is supported only by clusters v1.19.16-r50, v1.21.11-r10, v1.23.9-r10, v1.25.4-r10, v1.27.1-r10, or later. Value:
Default value: 200. The status code ranges from 200 to 599. For gRPC health checks, the default value is 0, and the status code ranges from 0 to 99. This parameter is available only for HTTP, HTTPS, or gRPC. It has no effect on other protocols. |
