- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
Show all
Account Baseline
Creating an Account Baseline
- Log in to COC.
- In the navigation pane on the left, choose Resource O&M > Automated O&M. In the Routine O&M area, click Account Management.
- Click the Account Baselines tab on the Change Account Password tab page.
- For hosts that are not bound to components, the system uses the built-in global baseline to manage host accounts by default. You can also click Create Account Baseline (recommended) to define the host accounts to be managed. The prerequisite is that the hosts have been bound to components. For hosts that are not bound to components, you can perform Creating an Application and then Creating a Component on CloudCMDB.
Figure 1 Creating an account baseline
- Set the baseline name, and add baseline accounts based on service requirements. For example, set Account to root and Account Class to Non-read-only account. Then associate the baseline with components. The associated components use the account baseline to manage hosts.
Figure 2 Baseline information
The prerequisites for an account to be successfully managed are as follows:
1. The UniAgent has been installed and is in the running state.
2. The host is in the running state.
3. The account configured in the baseline exists on the host and can be used to log in to the host.
CAUTION:
To ensure that incremental host instances of a component can be automatically managed, you need to enable Password Change Policy for Component Baseline in Component Baseline Dimension on the Change Account Password > Password Change Policies tab page.
- Click Delete or Modify in the Operation column to modify or delete the baseline as needed.
Figure 3 Deleting and modifying a baseline
CAUTION:
Before deleting a baseline, you need to unbind all associated components.
