Managing Scheduled Tasks
You can approve, enable, disable, modify, and delete scheduled tasks.
Approving scheduled tasks: If the enterprise administrator configures manual review for scheduled tasks, the tasks can be enabled, disabled, or modified only after being approved by the reviewer.
Enabling/Disabling scheduled tasks: Scheduled tasks in the disabled state do not take effect but can be enabled. Scheduled tasks in the enabled state can be disabled.
Modifying scheduled tasks: You can modify the name, version number, and task type of a scheduled task as needed.
Deleting scheduled tasks: If a scheduled task is no longer needed, you can delete it.
Enabling and Disabling a Scheduled Task
- You can enable or disable only the scheduled tasks created by yourself. You can view scheduled tasks created by other users under the current tenant account.
- A task takes effect after it is enabled. When the execution time is reached, the task is executed. After a scheduled task is disabled, it can be deleted and cannot be executed.
- Log in to COC.
- In the navigation pane on the left, choose Resource O&M > Automated O&M.
- In the Routine O&M area, click Scheduled O&M.
- Locate the target task and click Enable or Disable in the Operation column.
The scheduled task is enabled or disabled.
Modifying a Scheduled Task
- Only scheduled tasks in the pending review or disabled state can be modified.
- After a scheduled task is modified and enabled again, it will be executed at the new execution time.
- Log in to COC.
- Locate the task to be modified and click Modify in the Operation column.
- Set parameters on the displayed page. The parameters are the same as those for creating a schedule task. For details, see Creating Scheduled Tasks.
- Click OK.
The scheduled task is modified.
Deleting a Scheduled Task
Only disabled scheduled tasks can be deleted.
- Log in to COC.
- Locate the task to be deleted and choose More > Delete in the Operation column.
- Click OK.
The scheduled task is deleted.
Approving a Scheduled Task
Only the task whose reviewer is the current login account can be reviewed. Only approved scheduled tasks can be enabled.
- Log in to COC.
- Locate the task to be approved and click the task name.
- Click Approve.
- Set Review Comment.
- Passed or Not: Passed or Not Passed.
- Review Comment: Enter review comments.
- Click OK.
The scheduled task is approved.
