Logging In to an ECS Without a Password
During routine cloud O&M, O&M personnel often need to log in to different types of Linux ECSs to run commands. However, each login requires a password, which is inefficient and may increase security risks due to frequent password input. To address this challenge, COC supports password-free login to hosts through the account management function. When performing operations, you can select the target account in the password-free login module and directly access the host command execution page without entering the password again. This greatly improves O&M efficiency and security.
Note that the account must meet the following conditions:
- This parameter has been configured in Creating an Account Baseline.
- The current account can be found in the target host system.
- Password-free login is supported only in CN North-Beijing4 and CN North3.
- Currently, this function applies only to Linux hosts of the ECS type.
Precautions
Prerequisites for a successful remote login to a host:
- UniAgent has been installed and is running on the target host. The UniAgent version must be later than or equal to 1.1.6.
- The host is in the running state.
- Accounts configured in the baseline or imported accounts can be found on the target host.
- The account has a home directory. The preset directory is /home/account name.
If an account does not have a home directory, run the following command to create a home directory so that the password-free login function can be used.
Assume that the username is user1.
- Create a directory. (-p ensures that the parent directory is available. If the /home directory cannot be found, it will be automatically created.)
sudo mkdir -p /home/user1
- Copy all default configurations (including hidden files).
sudo cp -r /etc/skel/. /home/user1/
- Use the recursive function to change the owner and group of the /home/user1 directory and all its subdirectories and files to user user1 and group user1.
sudo chown -R user1:user1 /home/user1
- Set the permission to 700, that indicates only the owner has the permission.
sudo chmod 700 /home/user1
- The -d option specifies the new home directory path.
sudo usermod -d /home/user1 user1
- Log in to COC.
- In the navigation pane, choose Resource O&M > Automated O&M.
- In the Routine O&M area, click Account Management. The Account Management page is displayed.
- Access the Accounts > By Resource or Accounts > By Application tab page.
- By Resource applies to all purchased host instances.
- By Application applies to purchased hosts that have been bound to an application. If you select By Application, you need to select the target application or component.
- Select a resource type.
By default, Elastic Cloud Server (ECS) is selected.
- In the account list, locate the target host account and choose More > Login Without Password in the Operation column. Figure 1 Logging In to an ECS Without a Password
- Select the target account from the drop-down list and click OK.
The page for executing commands on the host is displayed.
Figure 2 Selecting a login account
Figure 3 Logging In to an ECS without a password
