Creating a Scheduled Password Change Task
In routine O&M management, periodically changing passwords is an important measure to ensure system security. However, manually and periodically changing passwords is time-consuming, labor-intensive, and error-prone. Based on service requirements, you can configure the regions where periodic password changes need to be enabled in COC. The default password change period is 0 15 3 ? * *, indicating that the task is executed at 03:15 every day. After the configuration, a periodic password change task is created for each region. You can view and modify the task by referring to Managing Scheduled Tasks. The periodic password change function of COC can automatically execute password change tasks, reducing manual intervention and improving security.
Notes and Constraints
A single scheduled password change task can be executed for a maximum of 999 instances. If the number of instances in the selected region exceeds this limit, the task will fail.
Configuring Password Change Regions
- Log in to COC.
- In the navigation pane on the left, choose Resource O&M > Automated O&M.
- In the Routine O&M area, and click Account Management.
- Choose Account Password Change > Password Change Tasks.
- Set Periodic password change policy.
- Click Select Region, select the region to be configured, click the rightward arrow, and click OK.
- After the configuration is complete, click View Details in the Operation column to view the password change task details.
- You can click Delete in the Operation column to delete unnecessary regions.
