Updated on 2026-09-08 GMT+08:00
Common Development Methods for DLI Cross-Source Analysis
If DLI needs to access external data sources, you need to establish enhanced datasource connections to enable the network between DLI and the data sources, and then develop different types of jobs to access the data sources. This is the process of DLI cross-source analysis.
This section describes how to develop data sources supported by DLI for cross-source analysis.
Notes
  • Flink jobs can directly access DIS, OBS, and SMN data sources without using datasource connections.
  • You are advised to use enhanced datasource connections to connect DLI to data sources.
Cross-Source Analysis Development Methods
Table 1 lists the data sources supported by DLI and the corresponding development methods.
Table 1 Syntax reference for cross-source analysis
Service
Spark SQL Job
Spark Jar Job
Flink OpenSource SQL Job
Flink Jar Job
CloudTable HBase
CloudTable OpenTSDB
CSS
DCS Redis
Flink job sample
DDS
DMS
DWS
Flink job sample
MRS HBase
Flink job sample
MRS Kafka
MRS OpenTSDB
RDS for MySQL
RDS PostGre
