Overview
COC fault management provides capabilities for quick fault demarcation, locating, and rectification. It supports ingestion of alarms from multiple data sources. COC aggregates raw alarms for alarm noise reduction and then converts corresponding alarms into incidents and leaves others as aggregated alarms. Faults reported by the alarms or incidents can be quickly demarcated through the application topology diagnosis tool or war rooms, and then be swiftly rectified based on online response plans with the MTTR shortened. All faults and their handling processes are reviewed for service improvement. In addition, with this feature, COC continuously accumulates the fault management O&M knowledge base and improves the risk resistance capability.
Fault Management Introduction
Core Features
- Integrating a Monitoring System: COC centrally manages raw alarms from multiple monitoring platforms, including Huawei Cloud Eye, AOM, APM, LTS, Alibaba Cloud Monitor, Alibaba Simple Log Service (SLS), Prometheus, Grafana, Zabbix, and custom service monitoring systems connected through open APIs.
- Creating an Alarm Conversion Rule: After alarm data sources are integrated, this module enables you to define trigger conditions and rules to convert raw alarms into aggregated alarms or incident tickets in COC. You can also assign owners and preset response plans for aggregated alarms or incident tickets.
- Handling an Aggregated Alarm: This module displays raw alarms and aggregated alarms. For aggregated alarms, you can perform operations such as alarm clearance, alarm-to-incident operations, and response plan execution.
- Creating an Incident Ticket: This module manages incident tickets throughout the lifecycle, including incident ticket creation, acceptance, rejection, forwarding, processing, escalation, de-escalation, and war room initiation.
- Handling an Incident Ticket Through a War Room: This module applies when major faults occur and different roles need to be quickly gathered to locate and rectify the faults. It provides a unified view of affected applications, related alarms, incidents, change information, and rectification progress notifications. You can execute response plans, diagnose applications, and start communication groups using mainstream third-party OA software.
- Creating an Issue Ticket: This module displays issues detected, recorded, and resolved during the use of software products, such as functional defects and poor performance.
- Managing Improvement Tickets: This module displays issues identified during troubleshooting, such as product, O&M, or management improvement issues, which are tracked and closed online.
