Updated on 2026-09-21 GMT+08:00
Creating an Issue Ticket
If you find any defects or poor performance during the software product operation, you can create an issue ticket to follow up on the issue.
To set notifications for issue tickets, you need to configure notification rules on the notification management page. For details, see Notification Management. Set the notification type to Issue.
  1. Log in to COC.
  2. In the navigation pane, choose Fault Management > Issues.
  3. On the displayed page, click Create Issue Ticket.
  4. Set parameters for creating an issue ticket by referring to Table 1.
    Table 1 Parameters for creating an issue ticket
    Issue Title
    Specify the issue title.
    The title can contain a maximum of 255 characters, including letters, digits, hyphens (-), underscores (_), and spaces. It cannot start or end with a space.
    Issue Description
    Description of the issue symptoms and impacts on the live network. The description cannot exceed 1,000 characters.
    Click Add File to upload issue-related attachments.
    A maximum of 10 files can be uploaded. The supported file types are JPG, PNG, DOCX, TXT, and PDF. The size of a single file cannot exceed 10 MB.
    Region
    (Optional) The preset value is N/A.
    Select one or more regions where the incident occurs.
    Enterprise Project
    Select an enterprise project.
    Issue Source
    (Optional) Select the source of the issue. You can select incident, alarm, WarRoom, or proactive O&M discovery.
    If you select incident, alarm, or WarRoom, the corresponding service ticket must be associated.
    Source Ticket No.
    This parameter needs to be set only when you select incident, alarm, or WarRoom for Issue Source.
    Click Associated Ticket No. and select the corresponding ticket.
    Occurrence Time
    (Optional) Enter the time when the issue occurs.
    Issue Application
    Select the issue application.
    Issue Level
    The value can be Critical, Major, Minor, or Suggestion.
    • Critical: The system or application breaks down, stops, or suspends, causing data loss. Main functions are unavailable, or the module or related modules are abnormal.
    • Major: Some main functions of the system are unavailable, data cannot be saved, and secondary functions of the system are impaired. The fault is limited to the module, causing the module to become nonfunctional or crash unexpectedly.
    • Minor: Secondary functions are partially implemented but remain operational, exhibiting issues such as inaccurate prompts, poor UI/UX, slow performance, or partial module dysfunction.
    • Suggestion: Minor software defects that cause operator inconvenience or annoyance but do not impact the functionality or execution of system operations.
    Issue Type
    Select the issue type.
    Multiple common issue types are preset in the system. If the preset types cannot meet your requirements, you can create an issue type in basic settings.
    Owner
    Select Shift or Individual.
    • Shift: Select a shift scenario and corresponding roles from the drop-down lists based on the configured values. For details about how to configure a shift, see Shift Schedule Management.
    • Individual: Select an owner. For details about how to configure an owner, see Personnel Management.
  5. Click OK.
    After an issue ticket is created, it is in the Unaccepted state.
Helpful Links
On COC, you can handle and query issue tickets as well as check service ticket records by calling APIs. For details, see Issue Ticket Management.
