What's New
The tables below describe the functions released in each Object Storage Service version and corresponding documentation updates. New features will be successively launched in each region.
February 2024
No. |
Feature |
Description |
Phase |
Document |
1 |
Deep Archive (under limited beta testing) is available. |
The Deep Archive storage class is suitable for storing data that is barely accessed (once every few years). This storage class costs less than the Archive storage class, but takes longer time (usually several hours) to restore data. Deep Archive is now only supported in the TR-Istanbul region. |
Open beta testing |
October 2023
No. |
Feature |
Description |
Phase |
Document |
1 |
Permission configuration on OBS Console is optimized. |
Experience in configuring permissions is improved:
Commercial use |
2 |
Object/file search is improved. |
You can search for objects or files by storage class, last modification time, or object/file name prefix and sort them by size or last modification time. The first 1,000 objects or files can be sorted by last modification time. If there are over 5,000 objects or files, they will be sorted in alphabetical order and can only be searched by object or file name prefix. |
Commercial use |
3 |
Bucket's overview page is improved. |
The layout of a bucket's overview page is re-organized. There are a range of modules added, including usage statistics, alarm monitoring, process flows for common scenarios, domain name details, FAQs, and learn more. |
Commercial use |
September 2023
No. |
Feature |
Description |
Phase |
Document |
1 |
Online decompression is put into commercial use. |
You can compress multiple files into a ZIP package and upload it to OBS. The package is automatically decompressed after being uploaded. |
Commercial use |
July 2023
No. |
Feature |
Description |
Phase |
Document |
1 |
SSE-OBS is supported. |
You can use the keys managed by OBS to encrypt data on the server side. Server-side encryption with OBS managed keys (SSE-OBS) is now available in the AP-Bangkok region only. |
Commercial use |
May 2023
No. |
Feature |
Description |
Phase |
Document |
1 |
Folder sharing by URL is supported. |
You can specify a validity period and then share the URL generated for a folder with others, so they can use a signature to access all objects in the shared folder. |
Commercial use |
April 2023
No. |
Feature |
Description |
Phase |
Document |
1 |
WORM is supported. |
You can configure write-once-read-many (WORM) policies to prevent objects from being deleted or tampered with during a particular period of time. |
Commercial use |
July 2022
No. |
Feature |
Description |
Phase |
Document |
1 |
Back to source is under open beta testing. |
With back to source, the requested data will be automatically fetched for users from its source site if it is not found in OBS. |
Open beta testing |
2 |
Online decompression is supported. |
Open beta testing |
June 2021
No. |
Feature |
Description |
Phase |
Document |
1 |
Command output for the obsutil ls command is optimized. |
Parameter -format is added to the obsutil ls command so that the listing result is printed in one line to prevent display disorders. |
Commercial use |
May 2021
No. |
Feature |
Description |
Phase |
Document |
1 |
Access control on OBS Console is optimized. |
The configuration of OBS bucket policies is simplified and easier. Bucket policy templates are provided for typical scenarios. |
Commercial use |
November 2020
No. |
Feature |
Description |
Phase |
Document |
1 |
OBS Administrator system policy is now available. |
OBS Administrator is added as a system policy in IAM. A user with this permission is an OBS administrator and can perform any operations on all OBS resources under the account. |
Commercial use |
October 2020
No. |
Feature |
Description |
Phase |
Document |
1 |
OBS Browser+ supports account login. |
You can now log in to OBS Browser+ using an account (or an IAM user under the account) and its password, which relieves you from recording complex access keys. |
Commercial use |
2 |
OBS Browser+ supports sharing folders through QR codes. |
OBS Browser+ can generate QR codes that you can use to share folders with others. |
Commercial use |
September 2020
No. |
Feature |
Description |
Phase |
Document |
1 |
The best practice case for accessing OBS through an NGINX reverse proxy is released. |
In some cases, you may need to set a blacklist and a whitelist of external IP addresses to control external access, so you need to provide a fixed IP address for users to access OBS. Also for security purposes, an OBS bucket does not have a fixed IP address, because the DNS service of Huawei Cloud resolves the bucket access domain name to different IP addresses. In this case, you can set up an NGINX reverse proxy server on an ECS to allow users to access OBS through a fixed IP address. |
Commercial use |
August 2020
No. |
Feature |
Description |
Phase |
Document |
1 |
Lightweight OBS Browser+ is released. |
OBS Browser+ is downsized from over 70 MB to only 50 MB. |
Commercial use |
July 2020
No. |
Feature |
Description |
Phase |
Document |
1 |
Lifecycle management is available for parallel file systems. |
You can configure lifecycle management rules for a parallel file system to periodically delete files or transition files from one storage class to another, which is the same as the lifecycle management for buckets. |
Commercial use |
2 |
OBS Browser+ extends the validity period of shared folders. |
The URL generated by OBS Browser+ for a shared folder can be valid for a maximum of one year. |
Commercial use |
3 |
OBS Browser+ supports MD5 verification. |
You can now enable MD5 verification in advanced settings on OBS Browser+ to verify data consistency. |
Commercial use |
4 |
OBS GO SDK supports resumable data upload. |
Uploading large files often fails due to poor network conditions or program breakdowns. It is a waste of resources to restart the upload process upon an upload failure, and the restarted upload process may still suffer from the unstable network. The API for resumable data upload effectively solves this problem. |
Commercial use |
5 |
OBS Browser+ supports flow control. |
OBS Browser+ now provides advanced settings for you to enable QoS flow control. |
Commercial use |
6 |
Large file uploading progress is visible on OBS Console. |
You can now view the progress when uploading large files on OBS Console. |
Commercial use |
June 2020
No. |
Feature |
Description |
Phase |
Document |
1 |
OBS Browser+ supports scheduled upload. |
You can schedule a specific upload time on OBS Browser+ to automatically upload files from local disks or directories to OBS. Upload tasks can be executed daily, weekly, monthly, or at a custom time. |
Commercial use |
May 2020
No. |
Feature |
Description |
Phase |
Document |
1 |
The OBS Browser+ version for macOS is released. |
OBS Browser+ is now compatible with macOS. |
Commercial use |
April 2020
No. |
Feature |
Description |
Phase |
Document |
1 |
Fine-grained authorization is released. |
With this function, you can grant fine-grained OBS policies to IAM user groups, so that IAM users in the groups have the specified operation permissions. Such policies can take effect on OBS as a whole or on a specific bucket or object. |
Commercial use |
2 |
OBS Browser is abandoned. |
OBS Browser has been abandoned since April 15, 2020. Its functions are inherited by the new client tool OBS Browser+ that provides you with better user experience. Download the latest OBS Browser+. |
Commercial use |
March 2020
No. |
Feature |
Description |
Phase |
Document |
1 |
The best practice for verifying OBS data consistency is released. |
OBS verifies data consistency by calculating the MD5 value when data is uploaded or downloaded. Data consistency verification is disabled by default. You can enable it when using obsutil, OBS Browser+, or OBS SDKs to upload and download data. |
Commercial use |
February 2020
No. |
Feature |
Description |
Phase |
Document |
1 |
User-defined domain names can be configured for buckets. |
You can configure a user-defined domain name for an OBS bucket so that you can use this domain name to access files stored in the bucket. |
Commercial use |
