What's New
The tables below describe the functions released in each Cloud Backup and Recovery version and corresponding documentation updates. New features will be successively launched in each region.
March 2024
No. |
Feature |
Description |
Phase |
Document |
1 |
Backup Locking |
To prevent the backup data from being deleted by mistake or maliciously, you can enable backup locking for vaults to improve data security. Once enabled, all backups in the vault enter the WORM (write once, read many) status. No one can delete the backups that are in their retention periods. |
Commercial use |
October 2023
No. |
Feature |
Description |
Phase |
Document |
1 |
Billing document optimization |
Integrated information about billing modes, billed items, renewals, and arrears. Added information about bills, stopping billing, and cost management. |
2 |
Desktop backup support |
You can protect your Workspace desktop data using desktop backup. |
August 2023
No. |
Feature |
Description |
Phase |
Document |
1 |
Storage data redundancy |
CBR allows you to create multi-AZ backup vaults so that your backup data can be stored in multiple AZs of a region. If one AZ becomes unavailable, backup data can still be accessed from other AZs. This feature is suitable for data storage that requires high reliability. |
Commercial use |
July 2022
No. |
Feature |
Description |
Phase |
Document |
1 |
File backup |
File backup allows you to back up cloud and on-premises directories and files inexpensively. |
Commercial use |
2 |
Periodic Full Backup |
CBR now allows you to implement periodic full backups in addition to the initial backup. This further improves backup data security and meets periodic full backup needs. |
Commercial use |
3 |
CBR Console GUI is upgraded. |
Commercial use |
May 2021
No. |
Feature |
Description |
Phase |
Document |
1 |
Migrating a Resource |
Migrating a resource means that you dissociate a resource from a vault and then associate it to another vault. All backups of the resource will be migrated to the destination vault. |
Commercial use |
September 2020
No. |
Feature |
Description |
Phase |
Document |
1 |
Exporting backup list |
You can export the backup list to view backup information. |
Commercial use |
May 2020
No. |
Feature |
Description |
Phase |
Document |
1 |
Replication of SFS Turbo backups |
CBR enables you to replicate file system backups from one region to another. |
Commercial use |
2 |
Enhanced compatibility of VMware hybrid cloud backup |
In addition to VMware vSphere 5.5 and 6.0, CBR allows you to synchronize backups of VMware vSphere 5.1, 6.5 and 6.7 to the cloud. |
Commercial use |
March 2020
No. |
Feature |
Description |
Phase |
Document |
1 |
SFS Turbo backup |
You can use CBR to easily back up SFS Turbo file systems. If there is a virus intrusion, accidental deletion, or software or hardware fault, you can restore data to any point in the past when the data was backed up. |
Commercial use |
September 2019
No. |
Feature |
Description |
Phase |
Document |
1 |
Sharing server backups between users |
You can share a server backup with other projects. The shared backups can be used to create servers. |
Commercial use |
July 2019
No. |
Feature |
Description |
Phase |
Document |
1 |
Enhanced backup policy |
You can set to retain weekly, monthly, or yearly backups in a backup policy. |
Commercial use |
2 |
Sharing disk backups between users |
You can share a disk backup with other projects. The shared backups can be used to create disks. |
Commercial use |
June 2019
No. |
Feature |
Description |
Phase |
Document |
1 |
Support for VMware backup |
VMware backup allows you to back up VMs in your on-premises VMware virtual environments to the cloud. |
Commercial use |
2 |
Commercial use of CBR |
Cloud Backup and Recovery (CBR) lets you back up cloud-native servers, disks, and file systems as well as on-premises VMware virtual environments with ease. If there is a virus intrusion, accidental deletion, or software/hardware fault, you can restore resources to any point when the data was backed up. |
Commercial use |
