Help Center/ API Gateway/ What's New
What's New
Updated on 2025/07/22 GMT+08:00
The tables below describe the functions released in each API Gateway version and corresponding documentation updates. New features will be successively launched in each region.
June 2025
No.
Feature
Phase
Document
OIDC authentication policy
APIG offers OIDC authentication. When accessing backend services through the gateway, APIG retrieves tokens and user data from the IDP, then appends this information to backend requests.
Commercial use
Customizing Error Response for APIs
OIDC Authentication
Error Codes
April 2025
No.
Feature
Phase
Document
Tracing
APIG allows you to enable tracing for APIs and provides complete tracing and service topology by connecting to APM.
Commercial use
Creating a REST API
Creating a gRPC API
Viewing API Call Logs
October 2024
No.
Feature
Phase
Document
Reference load balance channel
The reference load balance channel can reference other existing load balance channels.
Commercial use
Load Balance Channels
2
Traffic Mirroring
APIG mirrors requests to images for traffic analysis without affecting online services.
Commercial use
Traffic Mirroring
June 2024
No.
Feature
Phase
Document
Custom Inbound Port
APIG allows you to customize inbound ports for gateways so that clients can access different backend services through different ports.
Commercial use
Custom Inbound Port
2
Gateway access control policies
APIG provides access control policies to gateways. You can set an IP address blacklist or whitelist to forbid or allow an IP address to access a gateway.
Commercial use
Viewing or Modifying Gateway Information
May 2024
No.
Feature
Phase
Document
Orchestration Rule Management
APIG supports API parameter orchestration. You can configure different algorithm rules to map new request parameters and values.
Commercial use
2
Response Cache
You can configure a response cache policy to cache responses returned by the backend service (server) in APIG. When a client sends the same request, APIG does not need to send the request to the backend service but directly returns the cached response. This effectively reduces the backend load and API invoking latency.
Commercial use
Response Cache
March 2024
No.
Feature
Phase
Document
Unescaping parameters supported for API request path
You can configure whether to escape the parameters of the API path.
Commercial use
Configuring Parameters
January 2024
No.
Feature
Phase
Document
gRPC APIs with a function backend
gRPC APIs can use a function backend.
Commercial use
Creating a gRPC API
2
Client request customization
You can customize client request parameters, such as enabling or disabling HTTP/2 and modifying the request body timeout.
Commercial use
October 2023
No.
Feature
Phase
Document
Support for OpenAPI 3.0
APIs can be imported or exported in compliance with OpenAPI 3.0.
Commercial use
Importing and Exorting APIs
2
API policy cloning
You can quickly create API policies by cloning existing ones. Request throttling and signature key policies cannot be cloned.
Commercial use
Creating a Policy and Binding It to APIs
3
Server-sent events(SSE) transmission
The responses of backend APIs are output in streaming mode for character-based rendering.
Commercial use
September 2023
No.
Feature
Phase
Document
gRPC supported
If both your client and server are of the gRPC type, you can create an gRPC API to open up your backend capabilities.
Commercial use
Creating a gRPC API
Routing gRPC Service Requests
August 2023
No.
Feature
Phase
Document
gzip compression
Responses can be compressed using gzip to reduce public network traffic.
Commercial use
May 2023
No.
Feature
Phase
Document
Third-Party Authorizer
You can configure your own service to authenticate API requests. APIG first invokes this service for authentication, and then invokes the backend service after receiving a success response.
Commercial use
2
Custom Logs
Whether to enable custom logs. Once enabled, values of specified parameters will be printed in specified locations of calling logs for all APIs in the gateway.
Commercial use
March 2023
No.
Feature
Phase
Document
Cloning an API
To improve API creation efficiency, you can clone an API with a custom name and path.
Commercial use
Cloning an API
February 2023
No.
Feature
Phase
Document
Frontend HTTPS two-way authentication
CA certificates can be added to verify client certificates. When a client connects to a server, the client verifies the server and the server also verifies the client.
Commercial use
SSL Certificates
2
Custom authentication headers
You can configure custom headers for app authentication or authentication with HMAC or Basic Auth signature key policies.
Commercial use
December 2022
No.
Feature
Phase
Document
Microservice load balance channels
Server channels balance the loads of backend services and microservice channels automatically synchronize service node changes.
Commercial use
2
HTTP-to-HTTPS auto redirection
Requests of HTTP backends can be automatically redirected to HTTPS.
Commercial use
Managing Domain Names
3
Gateway tags
Tags classify your dedicated gateways to facilitate search, analysis, and management.
Commercial use
Tag Management
November 2022
No.
Feature
Phase
Document
Bandwidth monitoring
APIG provides monitoring metrics about inbound and outbound bandwidth.
Commercial use
Bandwidth Monitoring
October 2022
No.
Feature
Phase
Document
Importing CCE workloads
By importing Cloud Container Engine (CCE) workloads, you can open your CCE service capabilities through APIs.
Commercial use
Importing a CCE Workload
September 2022
No.
Feature
Phase
Document
Redirection from HTTP to HTTPS
HTTP backends can be redirected to HTTPS.
Commercial use
Signature keys
2
Log modularization
Log templates are available for O&M.
Commercial use
Log Analysis
3
Request throttling 2.0 policy
The new console supports high-performance and single-node request throttling.
Commercial use
Request Throttling 2.0
4
Circuit breaker policy
The new console supports circuit breaker policies. They protect your backend services when a performance issue occurs.
Commercial use
Circuit Breaker
5
API calling through HTTP 2.0
APIs can be called through HTTP 2.0 with better latency and performance.
Commercial use
HTTP 2.0
6
Gateway specification modification
If the specifications of a gateway cannot meet your service requirements, upgrade the specifications.
Commercial use
Modifying Specifications
7
Access control policy
The new console supports access control policies. They restrict API calls from specified client (API caller) IP addresses to protect backend services.
Commercial use
Binding an Access Control Policy
8
Credential quota policy
You can create quota policies for a client (API caller) on the new console to limit the number of API calls during a specified period.
Commercial use
Binding a Credential Quota Policy
9
Kafka log push policy
The new console supports collecting calling logs of open APIs. Kafka log push policies push API calling logs to Kafka for users to obtain.
Commercial use
Kafka Log Push
10
SSL certificate management
The new console supports SSL certificate management.
Commercial use
SSL Certificates
11
New APIG console
The new console is now available with powerful policy-based API control.
Commercial use
New Console
December 2021
No.
Feature
Phase
Document
Request throttling plugin
The plug-in is used to limit the number of times an API can be called within a specific time period. Parameter-based, basic, and excluded throttling is supported.
Commercial use
Request Throttling
June 2021
No.
Feature
Phase
Document
Dedicated gateway APIs
Dedicated gateways enable you to decouple internal systems of your enterprise and deploy services in Virtual Private Clouds(VPCs). The services communicate with each other through RESTful APIs, with high network security.
Commercial use
Service Overview
Buying a Dedicated Gateway
Best Practices
January 2020
No.
Feature
Phase
Document
API design, review, and release
You can design, develop, review, and release APIs.
Commercial use
Creating an API Group
December 2018
No.
Feature
Phase
Document
API export
You can export APIs in JSON or YAML format
Commercial use
Exporting APIs
November 2018
No.
Feature
Phase
Document
Multi-project management
API Gateway supports multi-project management.
Commercial use
Enterprise Project
