Help Center/ ServiceStage/ User Guide/ Continuous Delivery/ Creating a Source Code Job
Updated on 2025-11-11 GMT+08:00
The software package or image package can be generated with a few clicks in a build job. In this way, the entire process of source code pull, compilation, packaging, and archiving is automatically implemented.
  • Images built in the x86-system jobs are ones of the x86 system.
  • Images built in the Arm-system jobs are ones of the Arm system.
  • You have created a cluster. For details, see Buying a CCE Standard/Turbo Cluster. Create a CCE Turbo or CCE Standard cluster based on your service requirements.
    • The build job starts a build container on the cluster node to perform build-related operations. To ensure build security, you are advised to perform security hardening on CCE cluster nodes. For details, see Forbidding Containers to Obtain Host Machine Metadata.
    • If you create a CCE Turbo cluster, set SNAT rules for the cluster so that the cluster can access the public network through the NAT gateway to pull source code. Otherwise, when a source code-build task is executed, the source code fails to be obtained because the public network cannot be accessed. As a result, the component deployment or build fails. For details about how to configure SNAT rules for a cluster, see Accessing the Internet from a Container.
    • The build job depends on the JDK, Golang, Maven, Gradle, Ant, or Node.js compilation tool preconfigured in the build container.
    • Different IAM users under the same account can perform operations on the same cluster. To cancel the build permission from a specific IAM user, set the servicestage:assembling:create, servicestage:assembling:modify, and servicestage:assembling:delete permissions to Deny by referring to Using IAM Roles or Policies to Grant Access to ServiceStage.
  • An EIP has been bound to the build node. For details, see Binding an EIP to an Instance.
  • The CCE cluster must be of the current commercial version. CCE clusters that have reached EOS are not supported. The OS of the corresponding node must be of the commercial version. OS versions that have reached EOS are not supported.
  1. Log in to ServiceStage.
  2. Choose Continuous Delivery > Build.
  3. Click Create Source Code Job and set basic information about the build job by referring to the following table. Parameters marked with an asterisk (*) are mandatory.
    *Name
    Unique build job name.
    Enter 1 to 64 characters. Start with a letter or digit. Only use letters, digits, underscores (_), and hyphens (-).
    *Enterprise Project
    Enterprise projects let you manage cloud resources and users by project.
    It is available after you enable the enterprise project function.
    Build job description. Enter up to 64 characters.
    *Code Source
    The technology stack used by the source code must be Java, Tomcat, Node.js, Python, or PHP.
    • If you select a source code repository, create authorization by referring to Creating Repository Authorization and set the code source.
    • Click Samples and select a required sample.
    *Cluster
    Select a cluster for build. The cluster must belong to the configured enterprise project.
    Key
    Set Key and Value of the node label and deliver the build job to the fixed node bound with an EIP.
    For details about how to add labels, see Managing Node Labels.
    Value
  4. Click Next.
  5. Select a build template.
    • If you select Maven, Ant, Gradle, Go, or Docker, you can compile and archive binary packages or Docker images at the same time. Go to 6.
    • If you select Custom, you can customize the build mode. Go to 8.
  6. Select an archive mode.
    • Not archived: No Docker build job is added or archived.
    • Archive binary package: No Docker build job is added and binary packages are archived.
    • Archive image compilation: Docker build job is added and Docker images are archived.
  7. Set mandatory parameters based on the archive mode selected in 6.
  8. Click Advanced Settings to configure the build environment.
    1. Click Add Plug-in in the left pane. The Select Job Type page is displayed.
    2. Click Select next to the target job type, add a job type, and set job parameters based on the task type.
      When the Build Common Cmd plug-in is added to the compilation process, pay attention to the following:
      • Exercise caution when inputting sensitive information in the echo, cat, or debug command, or encrypt sensitive information to avoid information leakage.
      • Enter the compilation command. A maximum of 512 characters are allowed. Otherwise, an error message is displayed, indicating that the task input parameter is incorrect. In this case, you can add multiple Build Common Cmd plug-ins to split the command.
      • When Language is set to Python and Python Framework Type is set to a Python project that complies with the WSGI standard, you need to set Main Python Module and Function of the Main Python Module. The following is an example of the main Python module and main function:
        Main Python Module: If the entry point file of the Python project is server.py, the main module name is server.
        Function of the Main Python Module: If the application function name of the Python project entry point file server.py is app=get_wsgi_application(), the function name of the main module is app.
  9. Determine whether to execute the build:
    • If yes, click Build to save the settings and execute the build job.
    • If no, click Save to save the settings only.
Follow-up Operations
