Supported Runtimes
To create a function in FunctionGraph, you need to specify a runtime that passes events, context, and responses. Choose from a built-in runtime or customize your own.
For details about the runtimes and versions supported by FunctionGraph, see Table 1.
Runtime | Supported Version | Development Instructions |
Node.js | 6.10, 8.10, 10.16, 12.13, 14.18, 16.17, 18.15, 20.15 | For details about the function syntax, SDK APIs, and function development, see Developing Functions in Node.js. |
Python | 2.7, 3.6, 3.9, 3.10, 3.12 | For details about the function syntax, SDK APIs, and function development, see Developing Functions in Python. |
Java | 8, 11, 17, 21 (only available in ME-Riyadh and TR-Istanbul) | For details about the function syntax, SDK APIs, and function development, see Developing Functions in Java. |
Go | 1.x | For details about the function syntax, SDK APIs, and function development, see Developing Functions in Go. |
C# | .NET Core 2.1, .NET Core 3.1, .NET Core 6.0, .NET Core 8.0 (only in ME-Riyadh and TR-Istanbul) | For details about the function syntax, SDK APIs, and function development, see Developing Functions in C#. |
PHP | 7.3 and 8.3 | For details about the function syntax, SDK APIs, and function development, see Developing Functions in PHP. |
Custom | - | - |
Cangjie | 1.0 | - |
