Setting Job Review Configurations
In the internal development process of an enterprise, job creation or modification must be reviewed rigorously to ensure code quality and security. However, in actual operations, due to the lack of an effective review mechanism, jobs are directly released without being approved. This increases system risks. To address this challenge, you can forcibly specify a shift or an individual as the reviewer when creating or modifying a job. Reviewers can be notified by SMS messages or DingTalk. Jobs can only be created or modified once they are approved, ensuring better code quality and system security.
Precautions
To configure a reviewer by specifying a shift, you need to create a shift in Overview in advance.
If manual review is enabled, you can select a risk level for jobs. If you select the same risk level when creating a custom job, this job needs to be reviewed, and the manual review function will be forcibly enabled.
Only tenant accounts support review configurations.
- Log in to COC.
- In the navigation pane, choose Resource O&M > Automated O&M.
- In the Routine O&M area, click Job Management. The Job Management page is displayed.
- In the Custom Jobs tab page, click Review Configurations.
- Set review configurations by referring to Table 1.
Table 1 Parameters of review configurations Parameter
Manual Review
This function is disabled by default.
- If this function is disabled, you do not need to set other parameters.
- If this function is enabled, the parameter configurations for creating a custom job will be affected.
If this parameter is enabled, you must select a risk level. If you select the same risk level when creating a job, the job will be manually reviewed.
Risk Level
This parameter needs to be set when manual review is enabled.
The job risk level can be High, Medium, or Low.
If you select the same risk level when creating a custom job, this job needs to be reviewed and the enterprise project, reviewer, and notification channel you set here will be automatically used for configurations on the job creation page.
Enterprise Project
Select an enterprise project from the drop-down list.
Reviewer
Select Shift or Individual.- Shift: Select a shift scenario and a role from the drop-down lists based on the configured values. For details about how to configure a shift, see Shift Schedule Management.
- Individual: Select a reviewer. For details about how to configure a reviewer, see Personnel Management.
Notification Mode
Notification channel for notifying the reviewer. Select a notification channel from the drop-down list.
- Default: The notification channel selected in the subscription notification settings of the reviewer is used by default. For details about how to set the default notification channel, see Selecting a Notification Method.
- SMS, WeCom, DingTalk, and Email: Notifications are sent based on the information reserved by the reviewer. For details about how to set the reviewer information, see Modifying Personnel Information.
- No notification: The system does not notify any recipient.
- Click OK. The review configuration is complete.
After the configuration is complete, if the risk level of a custom job during its creation or modification is the same as that selected in the review configurations, the system automatically enables manual inbound review.
Helpful Links
For details about how to set basic configurations involved in job review, see the following:
