Configuring an Outbound Calling Number
A tenant administrator can configure a calling number for an outbound call.
- The Calling Number Anonymization feature has been enabled for the tenant space, and the system parameter Allowing Tenants to Maintain Calling Numbers. is set to Yes.
- Some operations under the current menu are controlled by separate permissions. If related operation permissions are not configured, the corresponding operations are not supported. For details about the operation permissions that can be configured separately, see Table 1.
- Sign in to the AICC as a tenant administrator and choose .
- Click Add Caller Number to add a calling number for an outbound call task. Figure 1 Create Outbound Calling Number page
Table 1 GUI elements on the Create Caller Number page Element
Type
Add
Button
Add a text box of an outbound calling number.
Caller Number
Text box
Enter an outbound calling number.
The value can contain a maximum of 24 characters.
Operation
Button
Delete a text box of an outbound calling number.
Organization Unit
Drop-down list
Set the OU to which the new outbound calling number belongs.
- Tenant administrator: Unorganized and all OUs under the current tenant are available.
- Common agent:
- When the tenant parameter Has the tenant enabled inter-organization data isolation enforcement is set to Yes, the owning OU, sub-OUs, and accessible OUs are available.
- When the tenant parameter Has the tenant enabled inter-organization data isolation enforcement is set to No, Unorganized and all OUs under the current tenant are available.
If the value of Organization Unit is left empty, Unorganized is selected.
Text box
Enter a description.
Value range: 0–255
- Click Save.
- Import outbound calling number information.
- Click
. The Import page is displayed. Figure 2 Import page
- Click Download Template to download the outbound calling number information template to the local PC.
- Enter outbound calling number information.
Only outbound calling numbers can be entered in the file to be uploaded. Each number can contain a maximum of 20 digits.
- Click
to upload the outbound calling number information list. - Click OK. An import task is created.
- Click
to view the import result. Select an import task according to the import time and click Download to view the import result. Figure 3 Import Result page
- Click
