Overview
Kubernetes logs allow you to locate and rectify faults. This section describes how to manage Kubernetes logs using different methods.
Comparison Between ICAgent and Cloud Native Log Collection
| Collection Tool | ICAgent | Cloud Native Log Collection | ||
| Log Storage Location | LTS | AOM 1.0 (not recommended) | LTS | AOM 2.0 |
| Content to Be Collected | - Container stdout logs - Container file logs - Node logs - Kubernetes events | - Container stdout logs - Container file logs | - Container stdout logs - Container file logs - Node logs - Kubernetes events - Kubernetes audit logs - Control plane component logs - Add-on logs | Kubernetes events |
| Advantages and Disadvantages | - Log collection policies and workloads are configured separately. Modifying policies does not affect pod running. - You can specify a container whose logs are to be collected. - Docker and containerd are supported. Nodes using containerd require ICAgent v5.12.130 or later. - Container file log collection supports overlay2, not Device Mapper. | - Each workload needs to be configured separately. - Log collection policies are coupled with pods. Modifying policies will restart the pod. | - Log collection policies and workloads are configured separately. Modifying policies does not affect pod running. - You can specify a container whose logs are to be collected. - If the node storage driver is Device Mapper, container file logs must be collected from the path where the data disk is attached to the node. | All warning events and some normal events are reported by default. The reported events can be used to configure alarms. |
| Configuration Method | Create a collection policy in LTS. For details, see Ingesting CCE Application Logs to LTS. |
| For details, see Reporting Kubernetes Events to AOM. |
| Monitored Directories | Up to five levels of directories, with up to 1,000 files | Up to three levels of directories by fuzzy match | - | |
| Monitored Files |
| Up to 4,096 logs collected based on log policies on each node | - | |
