Updated on 2026-09-21 GMT+08:00
Overview
CCE provides multiple types of add-ons to manage extended cluster functions. You can select add-ons as required to enhance the functions and flexibility of containerized applications.
These add-ons include CCE-developed and enhanced add-ons and widely used open-source add-ons.
  • CCE-developed and enhanced add-ons are deeply integrated into CCE and optimized for specific service requirements and scenarios. They can better support complex enterprise applications and ensure high performance and reliability.
  • Open-source add-ons leverage extensive community support and mature technologies to provide you with various functions and flexible solutions to meet ever-changing service requirements.
CCE add-ons are deployed via Helm charts. To modify or upgrade an add-on, go to the Add-ons page or use the open add-on management APIs. For details, see "Add-on Management" in Cloud Container Engine (CCE) API Reference. Do not modify add-on resources in the backend, as this may cause abnormal add-on behavior or unexpected issues. For example, parameter settings may be overwritten after an upgrade.
Add-on pods are prioritized over service pods. When cluster resources are limited, the add-on pods can use resources that would otherwise be allocated to service pods. This may result in the eviction of service pods.
Scheduling and Elasticity Add-ons
Add-on Name
Volcano Scheduler
This add-on provides general computing capabilities such as a high-performance task scheduling engine, heterogeneous chip management, and task operation management, serving users through computing frameworks for different industries such as AI, big data, gene sequencing, and rendering.
CCE Cluster Autoscaler
This add-on scales in or out the workload nodes in a cluster based on pod scheduling status and resource usage.
CCE Advanced HPA
This add-on is developed by CCE. It can be used to flexibly scale in or out Deployments based on metrics such as CPU usage and memory usage.
CCE Cloud Bursting Engine for CCI
This add-on is an implementation of the open-source Virtual Kubelet project. When momentary traffic spikes occur in a CCE cluster, it scales pods of Deployments, StatefulSets, jobs, and CronJobs to CCI, eliminating the overhead of the cluster.
VPA
This add-on automatically adjusts the CPU and memory resource requests for pods based on their historical resource usage.
Cloud Native Observability Add-ons
Add-on Name
Cloud Native Cluster Monitoring
This add-on includes the Prometheus Operator and Prometheus components and provides easy-to-use, end-to-end Kubernetes cluster monitoring.
This add-on enables the connection of monitoring data and the monitoring center, so that you can view monitoring data and configure alarms on the console.
Cloud Native Log Collection
This add-on is developed based on Fluent Bit and OpenTelemetry for collecting logs. It supports CRD-based log collection policies, and collects and forwards standard output logs, container file logs, node logs, and Kubernetes events in a cluster based on the policies you configured.
CCE Node Problem Detector
This add-on monitors abnormal events of cluster nodes and connects with a third-party monitoring platform. It is a daemon running on each node. It collects node issues from different daemons and reports them to the API server. It can run as a DaemonSet or a daemon.
CCE Network Metrics Exporter
This add-on monitors and manages container network traffic. It collects how many IPv4 packets and bytes are received and sent (including those sent to the Internet) and allows you to select the monitoring backends using PodSelector. It supports multiple monitoring tasks, allows you to select monitoring metrics, and allows you to obtain pod labels. The monitoring data has been adapted to Prometheus. You can call the Prometheus API to view monitoring data.
Kubernetes Metrics Server
This add-on is an aggregator for monitoring data of core cluster resources.
Grafana
This add-on is an open-source visualized data monitoring platform. It provides you with various charts and panels for real-time monitoring, analysis, and visualization of various metrics and data sources.
Prometheus (EOM)
This add-on is an open-source system monitoring and alerting framework. CCE allows you to quickly install Prometheus as an add-on.
Cloud Native AI Add-ons
Add-on Name
CCE AI Suite (NVIDIA GPU)
This add-on supports and manages GPUs for containers. Only NVIDIA drivers are supported.
CCE AI Suite (Ascend NPU)
This add-on supports and manages NPUs for containers.
Container Network Add-ons
Add-on Name
CoreDNS
This add-on is a DNS server that provides domain name resolution for Kubernetes clusters through chained plugins.
NGINX Ingress Controller
This add-on provides application-layer forwarding functions, including load balancing, SSL proxies, and HTTP routing, for Services to support direct access from outside a cluster.
NodeLocal DNSCache
This add-on functions as a DaemonSet to run the DNS cache proxy on each cluster node to improve cluster DNS performance.
Container Storage Add-ons
Add-on Name
CCE Container Storage (Everest)
This add-on is a cloud native container storage system, which enables clusters of Kubernetes v1.15.6 or later to use cloud storage through the Container Storage Interface (CSI).
Container Security Add-ons
Add-on Name
CCE Secrets Manager for DEW
This add-on interconnects with Data Encryption Workshop (DEW). It allows you to mount secrets stored outside a cluster (DEW for storing sensitive information) to service pods. In this way, sensitive information can be decoupled from the cluster environment, which prevents information leakage caused by program hardcoding or plaintext configuration.
Container Image Signature Verification
This add-on allows you to verify the digital signature of an image file, ensuring its integrity and authenticity. It effectively prevents tampering or malicious code implantation, ensuring user security.
Other Add-ons
Add-on Name
Kubernetes Dashboard
This add-on is a general-purpose, web-based UI for Kubernetes clusters and integrates all commands that can be used in the command-line interface (CLI). It allows you to manage applications in a cluster and troubleshoot faults, as well as manage the cluster itself.
OpenKruise
This add-on is a Kubernetes-based extension suite that automates cloud native application tasks like deployment, release, O&M, and availability protection.
Gatekeeper
This add-on is a customizable cloud native policy controller based on Open Policy Agent (OPA). It helps enhance policy execution and governance and provides more security policy rules that comply with Kubernetes application scenarios in clusters.
Kubernetes Web Terminal (EOM)
This add-on allows you to use kubectl on a web UI. It can connect to Linux by using WebSocket through a browser and provides APIs for integration into independent systems. It can be directly used as a service to obtain information through the configuration management database (CMDB) and log in to servers.
Add-on Lifecycle
An add-on lifecycle involves all the statuses from installation to uninstallation.
Table 1 Add-on statuses
Status
Attribute
Running
Stable state
The add-on is running properly, all add-on pods are deployed properly, and the add-on can be used properly.
Partially ready
Stable state
The add-on is running properly, but some add-on pods are not properly deployed. In this state, the add-on functions may be unavailable.
Unavailable
Stable state
The add-on malfunctions, and all add-on pods are not properly deployed.
Installing
Intermediate state
The add-on is being deployed.
If all pods cannot be scheduled due to incorrect add-on configuration or insufficient resources, the system sets the add-on status to Unavailable 10 minutes later.
Installation failed
Stable state
The add-on installation failed. Uninstall it and try again.
Upgrading
Intermediate state
The add-on is being upgraded.
Upgrade failed
Stable state
The add-on upgrade failed. Upgrade it again, or uninstall it and try again.
Rolling back
Intermediate state
The add-on is being rolled back.
Rollback failed
Stable state
The add-on rollback failed. Retry the rollback, or uninstall it and try again.
Deleting
Intermediate state
The add-on is being deleted.
If this state stays for a long time, an exception has occurred.
Deletion failed
Stable state
The add-on deletion failed. Try again.
Deleted
Stable state
The add-on is deleted.
Unknown
Stable state
The add-on release was not found.
When an add-on is in an intermediate state such as Installing or Deleting, you are not allowed to edit or uninstall the add-on.
If the add-on is in the Unknown state and "don't install the addon in this cluster" is returned in status.Reason, this issue is typically caused by the deletion of the secret associated with the Helm release of the add-on by mistake. In this case, uninstall the add-on and reinstall it with the same configurations.
Related Operations
You can perform the operations listed in Table 2 on the Add-ons page.
Table 2 Related operations
Operation
Installing the add-on
Install a specified add-on.
  1. Log in to the CCE console and click the cluster name to access the cluster console. In the navigation pane, choose Add-ons.
  2. Click Install under the target add-on.
    Each add-on has different configuration parameters. For details, see the corresponding chapter.
  3. Configure the add-on parameter and click Install.
Upgrading the add-on
Upgrade an add-on to the new version.
  2. If an add-on can be upgraded, the Upgrade button is displayed under it.
    Click Upgrade. Each add-on has different configuration parameters. For details, see the corresponding chapter.
  3. Configure the add-on parameter and click OK.
Editing the add-on
Edit add-on parameters.
  2. Click Edit under the target add-on.
Uninstalling the add-on
Uninstall an add-on from the cluster.
  2. Click Uninstall under the target add-on.
  3. In the displayed dialog box, enter DELETE and click OK.
    This operation cannot be undone.
Rolling back the add-on
Roll back an add-on to the source version.
  • If you have modified the add-on startup parameters, check and delete the custom parameters before the rollback. If you do not perform these operations, the rollback may fail because the target version does not support these parameters.
  • After the add-on is upgraded, you can roll back the add-on to the source version. If only the add-on parameters are updated, the add-on cannot be rolled back.
  • An add-on cannot be rolled back repeatedly.
  2. If an add-on can be rolled back, the Roll Back option will be provided.
    Choose More > Roll Back.
  3. In the displayed dialog box, click Yes.
Rollback is supported by the following add-ons of certain versions:
  • CoreDNS: 1.25.11 and later versions
  • CCE Container Storage (Everest): 2.1.19 and later versions
  • CCE Cluster Autoscaler
    • v1.21 clusters: 1.21.22 and later versions
    • v1.23 clusters: 1.23.24 and later versions
    • v1.25 clusters: 1.25.14 and later versions
  • Volcano Scheduler: 1.11.4 and later versions
  • CCE Node Problem Detector: 1.18.22 and later versions
  • CCE AI Suite (NVIDIA GPU)
    • v1.28 and later clusters: 2.7.35 and later versions (The source version must be later than 2.7.13).
    • v1.27 and earlier clusters: 2.1.19 and later versions (The source version must be later than 2.1.8).
