Help Center/ Cloud Container Engine_Autopilot/ Getting Started/ Scaling a Workload Using an HPA Policy
Updated on 2025-12-11 GMT+08:00
The traffic to applications fluctuates in peak and off-peak hours. If sufficient compute is always maintained to cope with peak traffic, the cost is high. To solve this problem, you can configure an auto scaling policy for the workload. This policy automatically adjusts the number of pods in the workload based on traffic changes or resource usage to reduce costs. You can set auto scaling policies for workloads in CCE standard, CCE Turbo, and CCE Autopilot clusters. For details about the differences, see Table 1.
This example describes how you can use HPA to adjust the scale of a workload running in a CCE Autopilot cluster. In CCE Autopilot clusters, you do not need to deploy, manage, or maintain nodes. You only need to set HPA policies to automatically adjust the number of pods on demand, simplifying resource management and O&M. In addition, CCE Autopilot prioritizes performance by setting up a serverless resource foundation in collaboration with underlying services. It uses multi-level resource pool pre-provisioning technology to meet diverse heterogeneous resource requirements and continuously improves performance through iterations.
Table 1 Comparison of workload auto scaling policies
Cluster Type
Policy
Differences
CCE standard/CCE Turbo clusters
You need to configure a Cluster AutoScaling (CA) policy for nodes and Horizontal Pod Autoscaling (HPA) policy for the workload.
  • CA policy: scales nodes to prevent workload creation failures caused by insufficient resources.
  • HPA policy: adjusts the number of pods in a workload.
  • Both CA and HPA policies are required.
  • Auto scaling can be implemented in minutes.
You only need to create an HPA policy for workload scaling.
  • Only an HPA policy is required.
  • Auto scaling can be implemented in seconds.
In this example, you only need to configure an HPA policy. The following describes how this HPA policy works:
Like in Figure 1, the HPA policy periodically monitors specified metrics (such as CPU usage, memory usage, and other custom metrics) to dynamically adjust the number of pods in the workload. Take the CPU usage as an example. When the CPU usage is higher than the maximum threshold, the HPA policy increases the number of pods to reduce the compute pressure of the workload. When the CPU usage is lower than the minimum threshold, the HPA policy reduces the number of pods to save costs. For more information about HPA, see How HPA Works.
Figure 1 How HPA works
Video Tutorial
Table 2 Procedure for configuring auto scaling
Step
Billing
Preparations
Sign up for a HUAWEI ID and make sure you have a valid payment method configured.
Billing is not involved.
Step 1: Enable CCE for the First Time and Perform Authorization
Obtain the required permissions for your account when you use CCE in the current region for the first time.
Step 2: Create a CCE Autopilot Cluster
Create a CCE Autopilot cluster so that you can use Kubernetes in a more simple way.
Cluster management and VPC endpoints are billed. For details, see CCE Billing.
Step 3: Create a Compute-intensive Application and Upload Its Image to SWR
Create a compute-intensive application for the stress test. Create an image using the application and then push the image to SWR for deployment and management in the cluster.
An ECS is required. You will be billed for the ECS and the bound EIP. For details, see ECS Billing.
Step 4: Create a Workload Using the hpa-example Image
Use the image to create a workload and create a Service of the LoadBalancer type for the workload so that the workload can be accessed from the public network.
Pods and load balancers are billed. For details, see CCE Billing and ELB Billing Items.
Step 5: Create an HPA Policy
Create an HPA policy for the workload to control the number of pods required by the workload.
Step 6: Verify Auto Scaling
Verify that the HPA policy triggers auto scaling for the workload.
During auto scaling, the number of pods increases or decreases and the pod price changes. For details, see CCE Billing.
Follow-up Operations: Releasing Resources
To avoid additional expenditures, release resources promptly if you no longer need them.
Preparations
When you first log in to the CCE console, CCE automatically requests permissions to access related cloud services (compute, storage, networking, and monitoring) in the region where the cluster is deployed. If you have authorized CCE in the deployment region, skip this step.
  1. Log in to the CCE console using your HUAWEI ID.
  2. Click in the upper left corner of the console and select a region, for example, CN East-Shanghai1.
  3. Wait for the Authorization Statement dialog box to appear, carefully read the statement, and click OK.
    After you agree to delegate the permissions, CCE creates an agency named cce_admin_trust in IAM to perform operations on other cloud resources and grants it the Tenant Administrator permissions. Tenant Administrator has the permissions on all cloud services except IAM. The permissions are used to call the cloud services on which CCE depends. The delegation takes effect only in the current region.
    CCE depends on other cloud services. If you do not have the Tenant Administrator permissions, CCE may be unavailable due to insufficient permissions. For this reason, do not delete or modify the cce_admin_trust agency when using CCE.
    CCE has updated the cce_admin_trust agency permissions to enhance security while accommodating dependencies on other cloud services. The new permissions no longer include Tenant Administrator permissions. This update is only available in certain regions. If your clusters are of v1.21 or later, a message will appear on the console asking you to re-grant permissions. After re-granting, the cce_admin_trust agency will be updated to include only the necessary cloud service permissions, with the Tenant Administrator permissions removed.
    When creating the cce_admin_trust agency, CCE creates a custom policy named CCE admin policies. Do not delete this policy.
Create a CCE Autopilot cluster so that you can use Kubernetes in a more simple way. In this example, only some mandatory parameters are described. You can keep the default values for other parameters. For details about other parameters, see Buying a CCE Autopilot Cluster.
  1. Log in to the CCE console.
    • If there is no cluster in your account in the current region, click Buy Cluster or Buy CCE Autopilot Cluster.
    • If there is already a cluster in your account in the current region, choose Clusters in the navigation pane and then click Buy Cluster.
  2. Configure basic cluster information. For details about the parameters, see Figure 2 and Table 3.
    Figure 2 Basic cluster information
    Table 3 Basic cluster information
    Example Value
    Type
    CCE allows you to create various types of clusters for diverse needs.
    • CCE standard clusters provide highly reliable and secure containers for commercial use.
    • CCE Turbo clusters use high-performance cloud native networks and provide cloud native hybrid scheduling. Such clusters have improved resource utilization and can be used in more scenarios.
    • CCE Autopilot clusters are serverless, and you do not need to bother with server O&M. This greatly reduces O&M costs and improves application reliability and scalability.
    For more information about cluster types, see Cluster Comparison.
    Cluster Name
    autopilot-example
    Enter a name for the cluster.
    Enter 4 to 128 characters. Start with a lowercase letter and do not end with a hyphen (-). Only lowercase letters, digits, and hyphens (-) are allowed.
    Enterprise Project
    default
    This parameter is displayed only for enterprise users who have enabled Enterprise Project.
    Enterprise projects are used for cross-region resource management and make it easy to centrally manage resources by department or project team. For more information, see Project Management.
    Select an enterprise project as needed. If there is no special requirement, you can select default.
    Cluster Version
    v1.28
    Select the Kubernetes version for the cluster. You are advised to select the latest version.
  3. Configure cluster network information. For details about the parameters, see Figure 3 and Table 4.
    Figure 3 Cluster network information
    Table 4 Cluster network information
    Example Value
    VPC
    vpc-autopilot
    Select a VPC where the cluster will be running. If no VPC is available, click Create VPC on the right to create one. For details, see Creating a VPC and Subnet. The VPC cannot be changed after the cluster is created.
    Control Plane Subnet
    subnet-502f
    Select the subnet where the control plane is located. The cluster control plane node uses the IP address in this subnet by default. Ensure that the subnet has sufficient available IPv4 addresses. The subnet cannot be modified after being created.
    If no subnet is available, click Create Subnet on the right to create one. For details, see Creating a VPC and Subnet.
    Pod Subnet
    subnet-502f
    Select the subnet where the pods will be running. Each pod requires a unique IP address. The number of IP addresses in a subnet determines the maximum number of pods in a cluster and the maximum number of containers. After the cluster is created, you can add subnets.
    Service CIDR Block
    10.247.0.0/16
    Select a Service CIDR block, which will be used by containers in the cluster to access each other. This CIDR block determines the maximum number of Services. After the cluster is created, the Service CIDR block cannot be changed.
    VPC Endpoint (Image Access)
    To ensure that your cluster nodes can pull images from SWR, existing SWR and OBS endpoints in the selected VPC are used by default. If there are no such endpoints, new SWR and OBS endpoints will be automatically created.
    VPC endpoints are billed. For details, see VPC Endpoint Price Calculator.
  4. Deselect Enable Alarm Center because no alarms are involved in this example. Configure this item based on your requirements.
  5. Click Next: Select Add-on. On the page displayed, select the add-ons to be installed during cluster creation.
    In this example, only the default add-ons, CoreDNS and Kubernetes Metrics Server, are installed.
  6. Click Next: Add-on Configuration to configure the selected add-ons. Mandatory add-ons cannot be configured.
  7. Click Next: Confirm Settings, check the displayed cluster resource list, and click Submit.
    It takes about 5 to 10 minutes to create a cluster. After the cluster is created, the cluster is in the Running state.
    Figure 4 A running cluster
Create a compute-intensive application for the stress test, which will be used to verify whether the HPA policy can automatically adjust the number of pods based on the metrics. Create an image using the application and then push the image to SWR for deployment and management in the cluster.
  1. Prepare a Linux ECS that is in the same VPC as the cluster created in Step 2: Create a CCE Autopilot Cluster and bind an EIP to the ECS. For details, see Purchasing and Using Linux ECS. You can choose to use an existing ECS or buy a new one.
    In this example, CentOS 7.9 64-bit (40 GiB) is used as an example to describe how you can use PHP to create a compute-intensive application and upload its image to SWR.
  2. Log in to the ECS. For details, see Logging In to a Linux ECS Using CloudShell.
  3. Install Docker.
    1. Run the following command to check whether Docker has been installed: If Docker has been installed, skip this step. If not, take the following steps to install, run, and check Docker.
      docker --version
      If the following information is displayed, Docker is not installed:
      -bash: docker: command not found
    2. Run the following command to install and run Docker:
      yum install docker
      Enable Docker to automatically start upon system boot and run immediately.
      systemctl enable docker
      systemctl start docker
    3. Run the following command to check the installation result:
      docker --version
      If the following information is displayed, Docker has been installed:
      Docker version 1.13.1, build 7d71120/1.13.1
  4. Create a compute-intensive application and use it to build an image.
    1. Create a PHP file named index.php. You can change the file name as needed. This file means that after receiving a user request, the file performs 1,000,000 cyclic calculations for a square root (0.0001+0.01+0.1+... in this example) and then returns "OK!".
      A Linux file name is case sensitive and can contain letters, digits, underscores (_), and hyphens (-), but cannot contain slashes (/) or null characters (\0). To improve compatibility, do not use special characters, such as spaces, question marks (?), and asterisks (*).
      vim index.php
      The file content is as follows:
      <?php
        $x = 0.0001;
        for ($i = 0; $i <= 1000000; $i++){
          $x += sqrt($x);
        echo "OK!";
      Press Esc to exit editing mode and enter :wq to save the file.
    2. Run the following command to compile a Dockerfile to create an image:
      vim Dockerfile
      # Use the official PHP Docker image.
      FROM php:5-apache
      # Copy the local index.php file to the specified directory in the container. This file will be used as the default web page.
      COPY index.php /var/www/html/index.php
      # Modify the permissions of the index.php file to make it readable and executable for all users, ensuring that the file can be correctly accessed on the web server.
      RUN chmod a+rx index.php
    3. Build an image named hpa-example and with the latest tag. You can change the name and image tag as needed.
      docker build -t hpa-example:latest .
      If the following information is displayed, the image has been built.
      Sending build context to Docker daemon  158.1MB
      Step 1/3 : FROM php:5-apache
      Successfully built xxx
      Successfully tagged hpa-example:latest
  5. Upload the hpa-example image to SWR.
    1. Log in to the SWR console. In the navigation pane, choose Organizations. In the upper right corner, click Create Organization. Set Name and click OK. If there is already an organization, skip this step.
      Figure 5 Creating an organization
    2. In the navigation pane, choose My Images. In the upper right corner, click Upload Through Client. On the page that is displayed, click Temporary Login Command and click to copy the temporary login command for logging in to SWR from ECS.
      Run the copied login command on the ECS.
      docker login -u cn-east-3xxx swr.cn-east-3.myhuaweicloud.com
      If information similar to the following is displayed, the login is successful:
      Login Succeeded
    3. Add a tag to the hpa-example image. The code structure is as follows:
      docker tag {Image name 1:Tag 1} {Image repository address}/{Organization name}/{Image name 2:Tag 2}
      Example:
      docker tag hpa-example:latest swr.cn-east-3.myhuaweicloud.com/test/hpa-example:v1
      Table 5 Parameters for adding a tag to an image
      Example Value
      hpa-example:latest
      Replace the values with the name and tag of the image to be uploaded.
      Replace it with the domain name at the end of the login command.
      {Organization name}
      test
      Replace it with the name of the created image organization.
      hpa-example:v1
      Replace the values with the name and tag to be displayed in the SWR image repository. You can change them as needed.
    4. Push the image to the image repository. The code structure is as follows:
      docker push {Image repository address}/{Organization name}/{Image name 2:Tag 2}
      Example:
      docker push swr.cn-east-3.myhuaweicloud.com/test/hpa-example:v1
      If the following information is displayed, the image is successfully pushed:
      6d6b9812c8ae: Pushed
      fe4c16cbf7a4: Pushed
      v1: digest: sha256:eb7e3bbdxxx size: xxx
      On the SWR console, refresh the My Images page to view the image pushed.
Use the hpa-example image to create a workload and create a Service of the LoadBalancer type for the workload so that the workload can be accessed from the public network. You can use either of the following methods to create the workload.
  1. Log in to the CCE console. Click the cluster name to access the cluster console.
  2. In the navigation pane, choose Workloads. In the upper right corner, click Create Workload.
  3. Configure basic workload information. For details about the parameters, see Figure 6 and Table 6.
    In this example, only some mandatory parameters are described. You can keep the default values for other parameters. For details about other parameters, see Creating a Workload. You can select a reference document based on the workload type.
    Figure 6 Basic workload information
    Table 6 Basic workload information
    Example Value
    Workload Type
    Deployment
    A workload defines the creation, status, and lifecycle of pods. By creating a workload, you can manage and control the behavior of multiple pods, such as scaling, update, and restoration.
    • Deployment: runs a stateless application. It supports online deployment, rolling upgrade, replica creation, and restoration.
    • StatefulSet: runs a stateful application. Each pod for running the application has an independent state, and the data can be restored when the pod is restarted or migrated, ensuring application reliability and consistency.
    • Job: a one-off job. After the job is complete, the pods are automatically deleted.
    • Cron Job: a time-based job runs a specified job in a specified period.
    For more information about workloads, see Workload Overview.
    hpa-example is mainly used for stress tests and does not need to store any persistent data locally. Therefore, hpa-example is deployed as a Deployment in this example.
    Workload Name
    hpa-example
    Enter a name for the workload.
    Enter 1 to 63 characters, starting with a lowercase letter and ending with a lowercase letter or digit. Only lowercase letters, digits, and hyphens (-) are allowed.
    Namespace
    default
    A namespace is a conceptual grouping of resources or objects. Each namespace provides isolation for data from other namespaces.
    After a cluster is created, the default namespace is created by default. If there is no special requirement, select default.
    Pod Type
    General computing
    Select the pod type. The performance and price of each pod type are different. For details, see Specifying the Pod Type.
    • General-computing: This type is suitable for customers who have high requirements on computing performance and focus on the scale and stability of compute. Intel CPUs are used to provide compute.
    • General-computing-lite: provides cost-effective compute with comparable performance.
    Pods
    Enter the number of pods. The policy for setting the number of pods is as follows:
    • High availability: To ensure high availability of the workload, at least 2 pods are required to prevent individual faults.
    • High performance: Set the number of pods based on the workload traffic and resource requirements to avoid overload or resource waste.
    In this example, set the number of pods to 1.
  4. Configure container information. For details about the parameters, see Figure 7 and Table 7.
    Figure 7 Container settings
    Table 7 Container settings
    Example Value
    Image Name
    hpa-example
    Click Select Image. In the displayed dialog box, switch to the My Images tab and select the hpa-example image pushed.
    Image Tag
    v1
    Select the required image tag.
    CPU Quota
    0.25 cores
    Specify the CPU limit, which defines the maximum number of CPU cores that can be used by a container. The default value is 0.25 cores.
    Memory Quota
    512 MiB
    Specify the memory limit, which is the maximum memory available for a container. The default value is 512 MiB. If the memory exceeds 512 MiB, the container will be terminated.
  5. Click under Service Settings. On the page that is displayed, configure the Service. For details about the parameters, see Figure 8 and Table 8.
    In this example, only some mandatory parameters are described. You can keep the default values for other parameters. For details about the parameters, see Service . Select a reference document based on the Service type.
    Figure 8 Service settings
    Table 8 Service settings
    Example Value
    Service Name
    hpa-example
    Enter a Service name.
    Service Type
    LoadBalancer
    Select a Service type, which determines how the workload is accessed.
    • ClusterIP: The workload can only be accessed using IP addresses in the cluster.
    • LoadBalancer: The workload can be accessed from the public network through a load balancer.
    In this example, external access to hpa-example is required. So you need to create a Service of the LoadBalancer type. For more information about the Service types, see Service.
    Load Balancer
    • Dedicated
    • Network (TCP/UDP) & Application (HTTP/HTTPS)
    • Use existing
    • elb-hpa-example
    • Select Use existing if there is a load balancer available.
      The load balancer must meet the following requirements:
      • It is in the same VPC as the cluster.
      • It is a dedicated load balancer.
      • It has a private IP address bound.
    Port
    Protocol: TCP
    Protocol: Select a protocol for the load balancer listener.
    Container Port: 80
    Container Port: Enter the port on which the application listens. This port must be the same as the listening port provided by the application for external systems.
    Service Port: 80
    Service Port: Enter a custom port. The load balancer will use this port as the listening port to provide an entry for external traffic.
  6. Click Create Workload.
    After the Deployment is created, it is in the Running state in the Deployment list.
    Figure 9 A running workload
  7. Click the workload name to go to the workload details page and obtain the external access address of hpa-example. On the Access Mode tab, you can view the external access address in the format of {EIP bound to the load balancer}:{Access port}. {EIP bound to the load balancer} indicates the public IP address of the load balancer, and {Access port} is the Service Port in 5.
    Figure 10 Access address
  1. Install kubectl on the ECS. You can check whether kubectl has been installed by running kubectl version. If kubectl has been installed, you can skip this step.
    1. Run the following command to download kubectl:
      cd /home
      curl -LO https://dl.k8s.io/release/{v1.28.0}/bin/linux/amd64/kubectl
      {v1.28.0} specifies the version. Replace it as needed.
    2. Run the following command to install kubectl:
      chmod +x kubectl
      mv -f kubectl /usr/local/bin
  2. Create a YAML file for creating a workload. In this example, the file name is hpa-example.yaml. You can change the file name as needed.
    vim hpa-example.yaml
    apiVersion: apps/v1
    kind: Deployment
      name: hpa-example     # Workload name
      replicas: 1     # Number of pods
      selector:
        matchLabels:  # Selector for selecting resources with specific labels
          app: hpa-example
      template:
          labels:     # Labels
            app: hpa-example
          containers:
          - name: container-1
            image: 'swr.cn-east-3.myhuaweicloud.com/test/hpa-example:v1' # Replace it with the address of the image you have pushed to SWR.
            resources:
              limits:  # The value of limits must be the same as that of requests to prevent flapping during scaling.
                cpu: 250m
                memory: 512Mi
              requests:
                cpu: 250m
                memory: 512Mi
          imagePullSecrets:
          - name: default-secret
    Replace 'swr.cn-east-3.myhuaweicloud.com/test/hpa-example:v1' with the image path in SWR. The image path is the content following docker push in the step of pushing the image to the image repository.
  3. Run the following command to create the workload:
    kubectl create -f hpa-example.yaml
    If information similar to the following is displayed, the workload is being created:
    deployment.apps/hpa-example created
  4. Run the following command to check the workload status:
    kubectl get deployment
    If the value of READY is 1/1, the pod created for the workload is available. This means the workload has been created.
    NAME           READY   UP-TO-DATE   AVAILABLE   AGE
    hpa-example    1/1     1            1           4m59s
    The following table describes the parameters in the command output.
    Table 9 Parameters in the command output
    Example Value
    NAME
    hpa-example
    Workload name.
    READY
    1/1
    The number of available pods/desired pods for the workload.
    UP-TO-DATE
    The number of pods that have been updated for the workload.
    AVAILABLE
    The number of pods available for the workload.
    AGE
    4m59s
    How long the workload has run.
  5. Run the following command to create the nginx-elb-svc.yaml file for configuring the LoadBalancer Service and associating the Service with the created workload. You can change the file name.
    An existing load balancer is used to create the Service. For details, see Using kubectl to Create a Load Balancer.
    vim hpa-example-elb-svc.yaml
    apiVersion: v1
    kind: Service
      name: hpa-example      # Service name
      annotations:
        kubernetes.io/elb.id: <your_elb_id>          # Load balancer ID. Replace it with the actual value.
        kubernetes.io/elb.class: performance         # Load balancer type
      selector:             # The value must be the same as the value of matchLabels in the YAML file of the workload in 3.
         app: hpa-example
      ports:
      - name: service0
        port: 80
        protocol: TCP
        targetPort: 80
      type: LoadBalancer
    Table 10 Parameters for using an existing load balancer
    Example Value
    405ef586-0397-45c3-bfc4-xxx
    ID of an existing load balancer.
    How to Obtain: Log in to the Network Console. In the navigation pane, choose Elastic Load Balance > Load Balancers. Locate the load balancer and obtain the ID below the load balancer name. Click the name of the load balancer. On the Summary tab, verify that the load balancer meets the preceding requirements.
    performance
    Load balancer type. The value can only be performance, which means that only dedicated load balancers are supported.
    selector
    app: hpa-example
    Selector, which is used by the Service to send traffic to pods with specific labels.
    ports.port
    8080
    The port used by the load balancer as an entry for external traffic. You can use any port.
    ports.protocol
    TCP
    Protocol for the load balancer listener.
    ports.targetPort
    80
    Port used by a Service to access the target container. This port is closely related to the applications running in the container.
  6. Run the following command to create a Service:
    kubectl create -f hpa-example-elb-svc.yaml
    If information similar to the following is displayed, the Service has been created:
    service/hpa-example created
  7. Run the following command to check the Service:
    kubectl get svc
    If information similar to the following is displayed, the workload access mode has been configured: You can access the workload using {External access address}:{Service port}. The external access address is the first IP address displayed for EXTERNAL-IP, and the Service port is 8080.
    NAME             TYPE           CLUSTER-IP     EXTERNAL-IP                  PORT(S)          AGE
    kubernetes       ClusterIP      10.247.0.1     <none>                       443/TCP          18h
    hpa-example      LoadBalancer   10.247.56.18   xx.xx.xx.xx,xx.xx.xx.xx      8080:30581/TCP   5m8s
HPA periodically checks pod metrics, calculates the number of replicas required to handle the increased or decreased load, and then adds the required number of pods for the workload. You can use either of the following methods to create an HPA policy.
In this example, only some mandatory parameters are described. You can keep the default values for other parameters. For details about the default parameters, see Horizontal Pod Autoscaling.
  1. Return to the cluster console. In the navigation pane, choose Policies. In the upper right corner, click Create HPA Policy.
  2. Configure the parameters. For details about the parameters, see Table 11.
    Figure 11 Policy basic Information
    Table 11 Policy basic Information
    Example Value
    Policy Name
    hpa-example
    Enter a policy name.
    Namespace
    default
    Associated Workload
    hpa-example
    Select the workload created in Step 4: Create a Workload Using the hpa-example Image.
    An HPA policy matches the associated workload by name. If the application labels of multiple workloads in the same namespace are the same, the policy will fail to meet the expectation.
  3. Configure the policy. For details about the parameters, see Table 12.
    Figure 12 Policy configuration
    Table 12 Policy configuration
    Example Value
    Pod Range
    1 to 10
    The minimum and maximum numbers of pods that can be created for the workload.
    Scaling Behavior
    Default
    Auto scaling behaviors. The options are as follows:
    • Default: Default behaviors (such as stabilization window and step) recommended by Kubernetes are used. For more information, see Horizontal Pod Autoscaling.
    • Custom: You can create custom scaling behaviors (such as stabilization window and step) for more flexible configuration. For parameters that are not configured, the default values recommended by Kubernetes are used. For more information, see Horizontal Pod Autoscaling.
    System Policy
    Metric: CPU usage
    HPA can trigger pod scaling based on pod resource metrics.
    • CPU usage = CPU used by the pod/CPU request
    • Memory usage = Memory used by the pod/Memory request
    Desired Value: 50%
    Desired value of the selected metric, which can be used to calculate the number of pods to be scaled. The formula is as follows: Number of pods to be scaled = (Current metric value/Desired value) × Number of current pods
    Tolerance Range: 30% to 70%
    Scale-in and scale-out thresholds. Scaling will not be triggered when the metric value is within the range. This range prevents frequent adjustments caused by slight fluctuation and ensures system stability. Note that the desired value must be within the tolerance range.
  4. Click Create. You can view the created policy in the HPA policy list. Its status is Started.
    Figure 13 HPA policy started
  1. Create a YAML file for configuring an HPA policy. In this example, the file name is hpa-policy.yaml. You can change it as needed.
    vim hpa-policy.yaml
    apiVersion: autoscaling/v2
    kind: HorizontalPodAutoscaler
      name: hpa-example   # HPA policy name
      namespace: default  # Namespace
      annotations:
        # Define the condition for triggering scaling: When the CPU usage is between 30% and 70%, scaling is not performed. Otherwise, scaling is performed.
        extendedhpa.metrics: '[{"type":"Resource","name":"cpu","targetType":"Utilization","targetRange":{"low":"30","high":"70"}}]'
      scaleTargetRef:     # Associated workload
        kind: Deployment
        apiVersion: apps/v1
      minReplicas: 1     # Minimum number of pods in the workload
      maxReplicas: 10  # Maximum number of pods in the workload
      metrics:
        - type: Resource  # Set the resources to be monitored.
          resource:
            name: cpu      # Set the resource to CPU or memory.
            target:
              type: Utilization   # Set the metric to usage.
              averageUtilization: 50  # The HPA controller keeps the average resource usage of pods at 50%.
  2. Create the HPA policy.
    kubectl create -f hpa-policy.yaml
    If information similar to the following is displayed, the HPA policy has been created:
    horizontalpodautoscaler.autoscaling/hpa-example created
  3. View the HPA policy.
    kubectl get hpa
    Information similar to the following is displayed:
    NAME          REFERENCE                TARGETS         MINPODS   MAXPODS   REPLICAS   AGE
    hpa-example   Deployment/hpa-example   <unknown>/50%   1         10        0          10s
Verify that auto scaling can be performed for the hpa-example workload. There are two methods for verification: using the console or kubectl.
  1. Log in to the ECS used in Step 3: Create a Compute-intensive Application and Upload Its Image to SWR.
  2. Run the following command in a loop to access the workload. In the command, ip:port indicates the access address of the workload, which is the same as <EIP-bound-to-the-load-balancer>:<Access port> in 7.
    while true;do wget -q -O- http://ip:port; done
    OK!
    OK!
  3. Log in to the CCE console and click the cluster name to access the cluster console. In the navigation pane, choose Workloads. On the page displayed, click the workload name. Click on the right of the search bar to observe the automatic scale-out of the workload. You can find that the number of pods created for the hpa-example workload has increased from 1 to 2.
    Figure 14 Automatic workload scale-out
  4. Return to the ECS, press Ctrl+C to stop accessing the workload, and observe the automatic scale-in of the workload.
    Return to the CCE console and click on the right of the search bar. The stabilization window for workload scale-in is 300 seconds by default. After the scale-in is triggered, the workload is not scaled in immediately. Instead, it will be cooled down for 300 seconds to prevent short-term fluctuations.
    Figure 15 Workload scale-in
  1. Run the following command in a loop to access the workload. In the command, ip:port indicates the access address of the workload, which is the same as <external-access-address>:<Service-port> in 8.
    OK!
    OK!
  2. In the upper left corner of the page, choose Terminal > New Session. In the terminal that is displayed, run the following command to view the automatic workload scale-out:
    kubectl get hpa hpa-example --watch
    hpa-example   Deployment/hpa-example   24%/50%   1         10        1          17m
    hpa-example   Deployment/hpa-example   100%/50%   1         10        1          17m
    hpa-example   Deployment/hpa-example   100%/50%   1         10        2          18m
    hpa-example   Deployment/hpa-example   57%/50%    1         10        2          19m
    hpa-example   Deployment/hpa-example   57%/50%    1         10        2          20m
    Table 13 Parameters in the command output
    Example Value
    NAME
    hpa-example
    HPA policy name.
    In this example, the HPA policy name is hpa-example.
    REFERENCE
    Object for which the HPA policy takes effect.
    In this example, the object is a Deployment named hpa-example.
    TARGETS
    24%/50%
    Current and desired values of the metric.
    In this example, the metric is CPU usage. 24% indicates the current CPU usage, and 50% indicates the desired CPU usage.
    MINPODS
    Minimum number of pods allowed by the HPA policy.
    In this example, the minimum number of pods is 1. When the number of pods is 1, the scale-in will not be performed even if the current CPU usage is lower than the tolerance range.
    MAXPODS
    10
    Maximum number of pods allowed by the HPA policy.
    In this example, the maximum number of pods is 10. When the number of pods is 10, the scale-out will not be performed even if the current CPU usage is higher than the tolerance range.
    REPLICAS
    Number of running pods.
    AGE
    17m
    How long the HPA policy has been used.
    • On line 2, the CPU usage of the workload is 100%, which exceeds 70%. As a result, auto scaling is triggered.
    • On line 3, the number of pods is increased from 1 to 2.
    • On line 5, the CPU usage of the workload decreases to 57%, which is between 30% and 70%. No auto scaling is triggered.
  3. In the terminal displayed in 1, press Ctrl+C to stop accessing the workload and observe the automatic scale-in.
    On the terminal in 2, view the command output. Note that the stabilization window for workload scale-in is 300 seconds by default. After the scale-in is triggered, the workload is not scaled in immediately. Instead, it will be cooled down for 300 seconds to prevent short-term fluctuations.
    hpa-example   Deployment/hpa-example   19%/50%    1         10        2          30m
    hpa-example   Deployment/hpa-example   0%/50%     1         10        2          31m
    hpa-example   Deployment/hpa-example   0%/50%     1         10        2          35m
    hpa-example   Deployment/hpa-example   0%/50%     1         10        1          36m
    • On line 1, the CPU usage of the workload is 19%, which is lower than 30%. As a result, auto scaling is triggered. However, the workload is not scaled in immediately because it is in the cooldown period.
    • On line 4, the number of pods is decreased from 2 to 1, which is the minimum number of pods. In this case, auto scaling is not triggered.
  • Deleting a cluster will delete the workloads and Services in the cluster, and the deleted data cannot be recovered.
  • VPC resources (such as endpoints, NAT gateways, and EIPs for SNAT) associated with a cluster are retained by default when the cluster is deleted. Before deleting a cluster, ensure that the resources are not used by other clusters.
  1. Log in to the CCE console. In the navigation pane, choose Clusters.
  2. Locate the cluster, click in the upper right corner of the cluster card, and click Delete Cluster.
  3. In the displayed Delete Cluster dialog box, delete related resources as prompted.
    Enter DELETE and click Yes to start deleting the cluster.
    It takes 1 to 3 minutes to delete a cluster. If the cluster name disappears from the cluster list, the cluster has been deleted.
  4. Log in to the ECS console. In the navigation pane, choose Elastic Cloud Server. Locate the target ECS, click More > Delete.
    In the displayed dialog, select Delete the EIPs bound to the ECSs and Delete all data disks attached to the ECSs, and click Next.
    Figure 16 Deleting ECSs
    Enter DELETE and click OK to start deleting the ECS.
    It takes 0.5 minutes to 1 minute to delete an ECS. If the ECS name disappears from the ECS list, the ECS has been deleted.
    Figure 17 Confirming the deletion
