How a Workload Is Scaled
How a HorizontalPodAutoscaler Works
A HorizontalPodAutoscaler is a controller that controls horizontal pod scaling. A HorizontalPodAutoscaler periodically checks the pod metrics, calculates the numbers of replicas required to meet the target values configured for the resources, and then adjusts the numbers of replicas for the target resource object (such as a Deployment).
A prerequisite for auto scaling is that runtime metrics can be collected, such as the number of pods, and CPU and memory usage of containers. Kubernetes does not have built-in monitoring capabilities, but you can use extensions like Prometheus and Metrics Server to monitor and collect data.
- Prometheus is an open-source monitoring and alarming framework that can collect multiple types of metrics. Prometheus has been a standard monitoring solution of Kubernetes.
- Metrics Server is a cluster-wide aggregator of resource utilization data. Metrics Server collects metrics from the Summary API exposed by kubelet. These metrics are set for core Kubernetes resources, such as pods, nodes, containers, and Services. Metrics Server provides a set of standard APIs for external systems to collect these metrics.
A HorizontalPodAutoscaler can work with Metrics Server to implement auto scaling based on CPU and memory usages. It can also work with Prometheus to implement auto scaling based on custom metrics.
Figure 1 shows how a HorizontalPodAutoscaler works.
Two core modules of a HorizontalPodAutoscaler:
- Data source monitoring
The community provided only CPU- and memory-based HorizontalPodAutoscaler at the early stage. With the population of Kubernetes and Prometheus, developers need more custom metrics or monitoring information at the access layer for their own applications, for example, the QPS of the load balancer and the number of online users of the website. In response, the community defines a set of standard metric APIs to provide services externally through these aggregated APIs.
- metrics.k8s.io provides monitoring metrics related to the CPU and memory of pods and nodes.
- custom.metrics.k8s.io provides custom monitoring metrics related to Kubernetes objects.
- external.metrics.k8s.io provides metrics that come from external systems and are irrelevant to any Kubernetes resource metrics.
- Scaling decision-making algorithms
The HorizontalPodAutoscaler controller calculates the scaling ratio based on the current metric values and desired metric values using the following formula:
desiredReplicas = ceil[currentReplicas x (currentMetricValue/desiredMetricValue)]
For example, if the current metric value is 200m and the target value is 100m, the desired number of pods will be doubled according to the formula. In practice, pods may be constantly added or reduced. To ensure stability, the HorizontalPodAutoscaler controller is optimized from the following aspects:
- Cooldown interval: In v1.11 and earlier versions, Kubernetes introduced the startup parameters horizontal-pod-autoscaler-downscale-stabilization-window and horizontal-pod-autoScaler-upscale-stabilization-window to indicate the cooldown intervals after a scale-in and scale-out, respectively, during which no scaling operation will be performed. In versions later than v1.14, the scheduling queue is introduced to store all decision-making suggestions detected within a period of time. Then, the system makes decisions based on all valid decision-making suggestions to minimize changes of the desired number of replicas to ensure stability.
- Tolerance: It can be considered as a buffer zone. If the pod number change can be tolerated, the number of pods will remain unchanged.
Use the formula: ratio = currentMetricValue/desiredMetricValue
When |ratio – 1.0| ≤ tolerance, scaling will not be performed.
When |ratio – 1.0| > tolerance, the desired value is calculated using the formula mentioned above.
The default value is 0.1 in the current community version.
The HorizontalPodAutoscaler performs scaling based on metric thresholds. Common metrics include the CPU and memory usage. You can also set custom metrics, such as the QPS and number of connections, to trigger scaling. However, metric-based scaling brings in latency of minutes generated during data collection, determination, and scaling phases. Such latency may cause high CPU usage and slow response. To solve this problem, CCE allows you to configure scheduled policies to scale resources regularly for applications with periodic changes.
