Creating an HPA Policy
Horizontal Pod Autoscaling (HPA) in Kubernetes implements horizontal scaling of pods. In a CCE HPA policy, you can configure different cooldown time windows and scaling thresholds for different applications based on the Kubernetes HPA.
- Kubernetes Metrics Server: provides basic resource usage metrics, such as container CPU and memory usages.
- Log in to the CCE console and click the cluster name to go to the cluster console.
- Choose Workloads in the navigation pane. Locate the target workload and choose Auto Scaling in the Operation column.
- Set Policy Type to HPA+CronHPA, enable the created HPA policy, and configure parameters.
Only HPA policies are described here. To enable CronHPA, see Creating a Scheduled CronHPA Policy.
Figure 1 Enabling an HPA policy
Table 1 HPA policy configuration Parameter
Pod Range
Minimum and maximum numbers of pods.
When a policy is triggered, the pods are scaled within this range.
NOTICE:In CCE Autopilot clusters, if you use a dedicated load balancer for a workload, the number of pods cannot exceed the load balancer's backend server group quota, which is 500 by default. If this limit is exceeded, no more pods can be added as the load balancer backend.
Scaling Behavior
- Default: Scale workloads using the Kubernetes default behavior. For details, see Default Behavior.
- Custom: Scale workloads using custom policies such as stabilization window, steps, and priorities. Unspecified parameters use the values recommended by Kubernetes.
- Disable scale-out or Disable scale-in: Select whether to disable scale-out or scale-in.
- Stabilization Window: a period during which CCE continuously checks whether the metrics used for scaling keep fluctuating. CCE triggers scaling if the desired state is not maintained for the entire window. This window restricts the unwanted flapping of pod count due to metric changes.
- Step: specifies the scaling step. You can set the number or percentage of pods to be scaled in or out within a specified period. If there are multiple policies, you can select the policy that maximizes or minimizes the number of pods.
System Policy
- Metric: You can select CPU usage or Memory usage. NOTE:
Usage = CPUs or memory used by pods/Requested CPUs or memory
- Desired Value: Enter the desired average resource usage.
This parameter indicates the desired value of the selected metric. Number of pods to be scaled (rounded up) = (Current metric value/Desired value) x Number of current pods
NOTE:When calculating the number of pods to be added or reduced, the HPA policy uses the maximum number of pods in the last 5 minutes.
- Tolerance Range: Scaling is not triggered when the metric value is within the tolerance range. The desired value must be within the tolerance range.
If the metric value is greater than the scale-in threshold and less than the scale-out threshold, no scaling is triggered. This parameter is only supported in clusters v1.15 or later.
- Click Create.
