Updated on 2026-09-18 GMT+08:00
Creating a Scheduled CronHPA Policy
There are predictable and unpredictable traffic peaks for some services. For such services, CCE CronHPA allows you to scale resources in fixed periods. It can work with HPA policies to periodically adjust the HPA scaling scope, implementing workload scaling.
CronHPA can periodically adjust the maximum and minimum numbers of pods in HPA policies or directly adjust the number of pods of each Deployment.
The CCE Advanced HPA add-on has been installed in the cluster.
Using CronHPA to Adjust the HPA Scaling Scope
CronHPA can periodically adjust the maximum and minimum number of pods in HPA policies to satisfy complex services.
HPA and CronHPA associate scaling objects using the scaleTargetRef field. If a Deployment is the scaling object for both CronHPA and HPA, the two scaling policies are independent of each other. The operation performed later overwrites the operation performed earlier. As a result, the scaling effect does not meet the expectation.
When CronHPA and HPA are used together, CronHPA rules take effect based on the HPA policy. CronHPA uses HPA to perform operations on the Deployment. Understanding the following parameters can help you better understand the working rules of the CronHPA.
  • targetReplicas: Number of pods set for CronHPA. When CronHPA takes effect, this parameter adjusts the maximum or minimum number of pods in HPA policies to adjust the number of Deployment pods.
  • minReplicas: Minimum number of Deployment pods.
  • maxReplicas: Maximum number of Deployment pods.
  • replicas: Number of pods in a Deployment before the CronHPA policy takes effect.
When the CronHPA rule takes effect, the maximum or minimum number of pods is adjusted by comparing the number of targetReplicas with the actual number of pods and combining the minimum or maximum number of pods in the HPA policy.
Figure 1 CronHPA scaling scenarios
Figure 1 shows possible scaling scenarios. The following examples detail how CronHPA modifies the number of pods in HPA.
Table 1 CronHPA scaling parameters
Scenario Description
CronHPA
(targetReplicas)
Deployment
(replicas)
HPA
(minReplicas/maxReplicas)
Result
Operation Description
targetReplicas < minReplicas ≤ replicas ≤ maxReplicas
4
5
5/10
HPA: 4/10
Deployments: 5
When the value of targetReplicas is smaller than that of minReplicas:
  • Change the value of minReplicas.
  • The value of replicas requires no change.
2
targetReplicas = minReplicas ≤ replicas ≤ maxReplicas
5
6
5/10
HPA: 5/10
Deployments: 6
When the value of targetReplicas is equal to that of minReplicas:
  • The value of minReplicas requires no change.
3
minReplicas < targetReplicas < replicas ≤ maxReplicas
4
5
1/10
HPA: 4/10
Deployments: 5
When the value of targetReplicas is greater than that of minReplicas and smaller than that of replicas:
4
minReplicas < targetReplicas = replicas < maxReplicas
5
5
1/10
HPA: 5/10
Deployments: 5
When the value of targetReplicas is greater than that of minReplicas and equal to that of replicas:
5
minReplicas ≤ replicas < targetReplicas < maxReplicas
6
5
1/10
HPA: 6/10
Deployments: 6
When the value of targetReplicas is greater than that of replicas and less than that of maxReplicas:
  • Change the value of replicas.
6
minReplicas ≤ replicas < targetReplicas = maxReplicas
10
5
1/10
HPA: 10/10
Deployments: 10
When the value of targetReplicas is greater than that of replicas and equal to that of maxReplicas:
7
minReplicas ≤ replicas ≤ maxReplicas < targetReplicas
11
5
5/10
HPA: 11/11
Deployments: 11
When the value of targetReplicas is greater than that of maxReplicas:
  • Change the value of maxReplicas.
  1. Log in to the CCE console and click the cluster name to go to the cluster console.
  2. Choose Workloads in the navigation pane. Locate the target workload and choose Auto Scaling in the Operation column.
  3. Set Policy Type to HPA+CronHPA and enable HPA and CronHPA policies.
    CronHPA periodically adjusts the maximum and minimum numbers of pods using the HPA policy.
  4. Configure the HPA policy. For details, see Creating an HPA Policy.
    Figure 2 Enabling an HPA policy
    Table 2 HPA policy configuration
    Pod Range
    Minimum and maximum numbers of pods.
    When a policy is triggered, the pods are scaled within this range.
    NOTICE:
    In CCE Autopilot clusters, if you use a dedicated load balancer for a workload, the number of pods cannot exceed the load balancer's backend server group quota, which is 500 by default. If this limit is exceeded, no more pods can be added as the load balancer backend.
    Scaling Behavior
    • Default: Scale workloads using the Kubernetes default behavior. For details, see Default Behavior.
    • Custom: Scale workloads using custom policies such as stabilization window, steps, and priorities. Unspecified parameters use the values recommended by Kubernetes.
      • Disable scale-out or Disable scale-in: Select whether to disable scale-out or scale-in.
      • Stabilization Window: a period during which CCE continuously checks whether the metrics used for scaling keep fluctuating. CCE triggers scaling if the desired state is not maintained for the entire window. This window restricts the unwanted flapping of pod count due to metric changes.
      • Step: specifies the scaling step. You can set the number or percentage of pods to be scaled in or out within a specified period. If there are multiple policies, you can select the policy that maximizes or minimizes the number of pods.
    System Policy
    • Metric: You can select CPU usage or Memory usage.
      Usage = CPUs or memory used by pods/Requested CPUs or memory
    • Desired Value: Enter the desired average resource usage.
      This parameter indicates the desired value of the selected metric. Number of pods to be scaled (rounded up) = (Current metric value/Desired value) x Number of current pods
      When calculating the number of pods to be added or reduced, the HPA policy uses the maximum number of pods in the last 5 minutes.
    • Tolerance Range: Scaling is not triggered when the metric value is within the tolerance range. The desired value must be within the tolerance range.
      If the metric value is greater than the scale-in threshold and less than the scale-out threshold, no scaling is triggered. This parameter is only supported in clusters v1.15 or later.
  5. Click in the CronHPA policy rule. In the displayed dialog box, configure scaling policy parameters.
    Figure 3 Enabling the CronHPA policy
    Table 3 CronHPA policy parameters
    Target Instances
    When the policy is triggered, CCE will adjust the number of HPA policy pods based on service requirements. For details, see Table 1.
    Trigger Time
    You can select a specific time every day, every week, every month, or every year.
    The trigger time is calculated based on the time zone of the cluster location.
    Enable
    Enable or disable the policy rule.
  6. Click OK. Then, the added policy rule is displayed in the rule list. Repeat the preceding steps to add multiple policy rules, but the triggering time of the policies must be different.
  7. Click Create.
When the CronHPA is compatible with the HPA policy, the scaleTargetRef field in CronHPA must be set to the HPA policy, and the scaleTargetRef field in the HPA policy must be set to Deployment. In this way, CronHPA adjusts the maximum and minimum numbers of pods in the HPA policy at a fixed time and the scheduled scaling is compatible with the auto scaling.
  1. Create an HPA policy for the Deployment.
    apiVersion: autoscaling/v1
    kind: HorizontalPodAutoscaler
      namespace: default
       maxReplicas: 10               #  Maximum number of pods
      minReplicas: 5               #  Minimum number of pods
      scaleTargetRef:              # Associate a Deployment.
        apiVersion: apps/v1
        kind: Deployment
      targetCPUUtilizationPercentage: 50
  2. Create a CronHPA policy and associate it with the HPA policy created in 1.
    apiVersion: autoscaling.cce.io/v2alpha1
    kind: CronHorizontalPodAutoscaler
      namespace: default
       scaleTargetRef:                  # Associate an HPA policy.
       rules:
       - ruleName: "scale-down"
         schedule: "15 * * * *"         # Running time and period of a job, for example, 0 * * * * or @hourly. For details, see the Cron syntax.
         targetReplicas: 1              # Number of target pods
         disable: false
       - ruleName: "scale-up"
         schedule: "13 * * * *"
         targetReplicas: 11
         disable: false
    Table 4 Key fields of CronHPA
    Field
    apiVersion
    API version. The value is fixed at autoscaling.cce.io/v2alpha1.
    kind
    API type. The value is fixed at CronHorizontalPodAutoscaler.
    metadata.name
    Name of a CronHPA policy.
    metadata.namespace
    Namespace to which the CronHPA policy belongs.
    spec.scaleTargetRef
    Specifies the scaling object of CronHPA. The following fields can be configured:
    • apiVersion: API version of the CronHPA scaling object.
    • kind: API type of the CronHPA scaling object.
    • name: Name of the CronHPA scaling object.
    CronHPA supports HPA policies or Deployments. For details, see Using CronHPA to Adjust the HPA Scaling Scope or Using CronHPA to Directly Adjust the Number of Deployment Pods.
    spec.rules
    CronHPA policy rules. Multiple rules can be added. The following fields can be configured for each rule:
    • ruleName: CronHPA rule name, which must be unique.
    • schedule: Running time and period of a job. For details, see Cron, for example, 0 * * * * or @hourly.
    • targetReplicas: indicates the number of pods to be scaled in or out.
    • disable: The value can be true or false. false indicates that the rule takes effect, and true indicates that the rule does not take effect.
CronHPA adjusts the associated Deployments separately to periodically adjust the number of Deployment pods. You can create a CronHPA policy using the console or kubectl.
  3. Set Policy Type to HPA+CronHPA, disable HPA, and enable CronHPA.
    CronHPA periodically adjusts the number of workload pods.
  4. Click in the CronHPA policy rule. In the displayed dialog box, configure scaling policy parameters.
    Figure 4 Using CronHPA to adjust the number of workload pods
    Table 5 CronHPA policy parameters
    Target Instances
    When a policy is triggered, the number of workload pods will be adjusted to the value of this parameter.
    Trigger Time
    Enable
  5. Click OK. Then, the added policy rule is displayed in the rule list. Repeat the preceding steps to add multiple policy rules, but the triggering time of the policies must be different.
  6. Click Create.
  namespace: default
      apiVersion: apps/v1
      kind: Deployment
   rules:
     schedule: "08 * * * *"    # Running time and period of a job. For details, see Cron, for example, 0 * * * * or @hourly.
     targetReplicas: 1
     disable: false
     schedule: "05 * * * *"
     targetReplicas: 3
     disable: false
