Updated on 2026-09-28 GMT+08:00
CCE Advanced HPA
CCE Advanced HPA (cce-hpa-controller) is an in-house add-on, which can be used to flexibly scale in or out Deployments based on metrics such as CPU usage and memory usage.
Main Functions
  • Scaling can be performed based on the percentage of the current number of pods.
  • The minimum scaling step can be set.
  • Different scaling operations can be performed based on the actual metric values.
Notes and Constraints
An add-on that can provide the Metrics API has been installed in the cluster.
  • Kubernetes Metrics Server: provides basic resource usage metrics, such as container CPU and memory usages. It is supported by all cluster versions.
Installing the Add-on
  1. Log in to the CCE console and click the cluster name to go to the cluster console.
  2. In the navigation pane, choose Add-ons. On the right of the displayed page, find the CCE Cluster Autoscaler add-on and click Install.
  3. On the Install Add-on slide-out panel, configure the specifications.
    Table 1 CCE Advanced HPA specifications
    Pods
    Number of pods for the add-on.
    High availability is not possible if there is only one pod. If an error occurs on the node where the pod runs, the add-on will fail.
    CPU and memory quotas of the container allowed for the selected add-on specifications.
    You can adjust the container specifications of an add-on pod as needed.
  4. Click Install.
Components
Table 2 cce-hpa-controller component
Component
Resource Type
customedhpa-controller
CCE auto scaling component, which scales in or out Deployments based on metrics such as CPU usage and memory usage
Deployment
Release History
Table 3 Release history
Add-on Version
Supported Cluster Version
New Feature
1.4.5
  • v1.36
  • v1.35
  • v1.34
  • v1.32
  • v1.31
Supported CCE Autopilot clusters v1.36.
1.4.4
  • v1.35
  • v1.34
  • v1.32
  • v1.31
Supported CCE Autopilot clusters v1.35.
1.4.3
  • v1.34
  • v1.32
  • v1.31
Supported CCE Autopilot clusters v1.34.
1.4.1
  • v1.32
  • v1.31
  • v1.28
Supported CCE Autopilot clusters v1.32.
1.3.50
  • v1.31
  • v1.28
  • v1.27
Supported CCE Autopilot clusters v1.31.
1.3.48
  • v1.31
  • v1.28
  • v1.27
1.3.47
  • v1.28
  • v1.27
Fixed some issues.
1.3.46
  • v1.28
  • v1.27
Performed a regular upgrade of add-on dependencies.
1.3.45
  • v1.28
  • v1.27
Fixed some issues.
1.3.44
  • v1.28
  • v1.27
Supported CronHPA policies.
