Creating a LoadBalancer Service
LoadBalancer Services can access workloads from the public network through ELB, which is more reliable than EIP-based access. The LoadBalancer access address is in the format of IP address of public network load balancer:Access port, for example, 10.117.117.117:80.
If dedicated load balancers are deployed for CCE Autopilot clusters, passthrough networking is supported to reduce the network latency and ensure zero performance loss.
External access requests are directly forwarded from a load balancer to pods. Internal access requests can be forwarded to a pod through a Service.
- Automatically created load balancers should not be used by other resources. If they are used by other resources, they cannot be deleted completely.
 - CCE Autopilot clusters support only dedicated load balancers. Dedicated load balancers must have private IP addresses bound. If a Service needs to support HTTP, dedicated load balancers must also support application load balancing (load balancing over HTTP or HTTPS).
 - In the navigation pane, choose Services & Ingresses. In the upper right corner, click Create Service.
 - Configure the parameters.
- Service Name: Specify a Service name, which can be the same as the workload name.
 - Service Type: Select LoadBalancer.
 - Namespace: Select the namespace that the workload belongs to.
 - Service Affinity
Cluster level: The IP addresses and access ports of all nodes in a cluster can access the workload associated with the Service. Service access will cause performance loss due to route redirection, and the source IP address of the client cannot be obtained.
 - Selector: Add a label and click Confirm. A Service selects a pod based on the added label. You can also click Reference Workload Label to reference the label of an existing workload. In the dialog box that is displayed, select a workload and click OK.
 - Load Balancer: Select the load balancer type and whether to use an existing load balancer or create one.
You can select Dedicated. Only dedicated load balancers are supported. A dedicated load balancer supports Network (TCP/UDP), Application (HTTP/HTTPS), or Network (TCP/UDP) & Application (HTTP/HTTPS).
Select either Use existing or Auto create. For more information, see Table 1.Table 1 Load balancer configurations Option
Use existing
Only the load balancers in the same VPC as the cluster can be selected. If no load balancer is available, click Create Load Balancer to create one on the ELB console.
Auto create
- Instance Name: Enter a load balancer name.
 - Enterprise Project: This parameter is only available for enterprise users who have enabled an enterprise project. Enterprise projects facilitate project-level management and grouping of cloud resources and users.
 - AZ: This parameter is only available for dedicated load balancers. You can create load balancers in multiple AZs to improve service availability. If disaster recovery is required, you are advised to select multiple AZs.
 - Frontend Subnet: This parameter is used to allocate IP addresses to load balancers to receive traffic from clients.
 - Backend Subnet: This parameter is used to allocate IP addresses for load balancers to route traffic to pods.
 - Network/Application-oriented Specifications
- Elastic: applies to fluctuating traffic, billed based on the total traffic.
 - Fixed: applies to stable traffic, billed based on specifications.
 - EIP: If you select Auto create, you can select a bandwidth billing option and set the bandwidth.
 - Resource Tag: You can add resource tags to classify resources. You can create predefined tags on the TMS console. The predefined tags are available to all resources that support tags. You can use predefined tags to improve the tag creation and resource migration efficiency. This is supported by clusters of v1.27.5-r0, v1.28.3-r0, and later versions.
You can click Edit in the Set ELB area to set the load balancing algorithm and sticky session.
- Algorithm: Three algorithms are available: weighted round robin, weighted least connections algorithm, or source IP hash.
          - Weighted round robin: Requests are forwarded to different servers based on their weights, which indicate server processing performance. Backend servers with higher weights receive proportionately more requests, whereas equal-weighted servers receive the same number of requests. This algorithm is often used for short connections, such as HTTP services.
 - Weighted least connections: In addition to the weight assigned to each server, the number of connections processed by each backend server is considered. Requests are forwarded to the server with the lowest connections-to-weight ratio. This algorithm is based on the least connections algorithm and assigns a weight to each server based on their processing capability. This algorithm is often used for persistent connections, such as database connections.
 - Source IP hash: The source IP address of each request is calculated using the hash algorithm to obtain a unique hash key, and all backend servers are numbered. The generated key allocates the client to a particular server. This enables requests from different clients to be distributed in load balancing mode and ensures that requests from the same client are forwarded to the same server. This algorithm applies to TCP connections without cookies.
 - Sticky Session: This feature is disabled by default.
If the listener's frontend protocol is TCP or UDP, sticky sessions can use source IP addresses. This means that access requests from the same IP address will be directed to the same pod.
 - Health Check: Configure health check for the load balancer.
- Global health check: applies only to ports of the same protocol. You are advised to select Custom health check.
 - Custom health check: applies to ports used by different protocols.
Table 2 Health check parameters Parameter
Protocol
When the protocol is set to TCP, both TCP and HTTP are supported. When the protocol is set to UDP, only UDP is supported.
Check Path: This parameter is only available for HTTP health check. It specifies the URL for health check. The check path must start with a slash (/) and contain 1 to 80 characters.
Port
By default, the service ports are used for health check. You can also specify another port for health check. If a port is specified, a service port named cce-healthz will be added for the Service.
Container Port: When a dedicated load balancer has an elastic network interface associated, the container port is used for health check. The value ranges from 1 to 65535.
Check Period (s)
Specifies the maximum interval between health checks. The value ranges from 1 to 50.
Timeout (s)
Specifies the maximum timeout duration for each health check. The value ranges from 1 to 50.
Max. Retries
Specifies the maximum number of health check retries. The value ranges from 1 to 10.
 - Port
- Protocol: Select the protocol used by the Service.
 - Service Port: Specify the port used by the Service. The port number ranges from 1 to 65535.
 - Container Port: Specify the port on which the workload listens. For example, Nginx uses port 80 by default.
 - Frontend Protocol: Set the protocol of the load balancer listener for establishing a connection with the clients. For a dedicated load balancer, to use HTTP/HTTPS, the type of the load balancer must be Application (HTTP/HTTPS).
 - Health Check: If Health Check is set to Custom health check, you can configure health check for ports that come with different protocols. For details, see Table 2.
 - Annotation: A LoadBalancer Service has some advanced features, which are implemented by annotations. For details, see Using Annotations to Configure Load Balancing.
 - Click OK.
Using kubectl to Create a Service (Using an Existing Load Balancer)
You can set the Service when creating a workload using kubectl. This section uses an Nginx workload as an example to describe how to add a LoadBalancer Service using kubectl.
- Use kubectl to connect to the cluster. For details, see Connecting to a Cluster Using kubectl.
 - Create the nginx-deployment.yaml and nginx-elb-svc.yaml files and edit them.
The file names are user-defined. nginx-deployment.yaml and nginx-elb-svc.yaml are merely example file names.
vi nginx-deployment.yaml
apiVersion: apps/v1 kind: Deployment metadata: name: nginx spec: replicas: 1 selector: matchLabels: app: nginx template: metadata: labels: app: nginx spec: containers: - image: nginx name: nginx imagePullSecrets: - name: default-secretvi nginx-elb-svc.yaml
apiVersion: v1 kind: Service metadata: name: nginx annotations: kubernetes.io/elb.id: <your_elb_id> # ELB ID. Replace it with the actual value. kubernetes.io/elb.class: performance # Load balancer type kubernetes.io/elb.lb-algorithm: ROUND_ROBIN # Load balancer algorithm kubernetes.io/elb.session-affinity-mode: SOURCE_IP # The sticky session type is source IP address. kubernetes.io/elb.session-affinity-option: '{"persistence_timeout": "30"}' # Stickiness duration (min) kubernetes.io/elb.health-check-flag: 'on' # Enable the ELB health check function. kubernetes.io/elb.health-check-option: '{ "protocol":"TCP", "delay":"5", "timeout":"10", "max_retries":"3" }' spec: selector: app: nginx ports: - name: service0 port: 80 # Port for accessing the Service, which is also the listener port on the load balancer. protocol: TCP targetPort: 80 # Port used by a Service to access the target container. This port is closely related to the applications running in a container. nodePort: 31128 # Port number on the node. If this parameter is not specified, a random port number ranging from 30000 to 32767 is generated. type: LoadBalancerThis example uses annotations to implement some advanced features of load balancing, such as sticky sessions and health check. For details, see Table 3.
For more annotations and examples related to advanced features, see Using Annotations to Configure Load Balancing.
Table 3 annotations parameters Parameter
Mandatory
Type
Yes
String
ID of an enhanced load balancer.
Mandatory when an existing load balancer is to be associated.
How to obtain:
On the ELB console, click the load balancer name. On the Summary tab of the load balancer details page, find the ID and copy it.
Yes
String
The value can be:
- performance: dedicated load balancer
NOTE:When an existing dedicated load balancer is used for a LoadBalancer Service, the private network must be supported.
No
String
Specifies the load balancing algorithm of the backend server group. The default value is ROUND_ROBIN.
Options:
- ROUND_ROBIN: weighted round robin algorithm
 - LEAST_CONNECTIONS: weighted least connections algorithm
 - SOURCE_IP: source IP hash algorithm
NOTE:If this parameter is set to SOURCE_IP, the weight setting (weight field) of backend servers bound to the backend server group is invalid, and sticky session cannot be enabled.
No
String
In source IP address-based sticky sessions, requests from the same IP address are forwarded to the same backend server.
- Disabling sticky session: Do not configure this parameter.
 - To enable sticky sessions, ensure the frontend protocol is TCP or UDP and set the sticky session type to SOURCE_IP.
NOTE:When kubernetes.io/elb.lb-algorithm is set to SOURCE_IP (source IP hash), sticky session cannot be enabled.
No
Table 4 Object
Sticky session timeout.
No
String
Whether to enable the ELB health check.
- Enabling health check: Leave blank this parameter or set it to on.
 - Disabling health check: Set this parameter to off.
If this option is enabled, the kubernetes.io/elb.health-check-option field must also be specified at the same time.
No
Table 5 Object
ELB health check configuration items.
Table 4 elb.session-affinity-option data structure Parameter
Mandatory
Type
persistence_timeout
Yes
String
Sticky session timeout, in minutes. This parameter is valid only when elb.session-affinity-mode is set to SOURCE_IP.
Value range: 1 to 60. Default value: 60
Table 5 elb.health-check-option data structure Parameter
Mandatory
Type
delay
No
String
Health check interval (s)
Value range: 1 to 50. Default value: 5
timeout
No
String
Health check timeout, in seconds.
Value range: 1 to 50. Default value: 10
max_retries
No
String
Maximum number of health check retries.
Value range: 1 to 10. Default value: 3
protocol
No
String
Health check protocol.
Value options: TCP or HTTP
path
No
String
Health check URL. This parameter needs to be configured when the protocol is HTTP.
Default value: /
Value range: 1-80 characters
 - Create a workload.
kubectl create -f nginx-deployment.yaml
If information similar to the following is displayed, the workload has been created.
deployment/nginx created
kubectl get pod
If information similar to the following is displayed, the workload is running.
NAME READY STATUS RESTARTS AGE nginx-2601814895-c1xhw 1/1 Running 0 6s
 - Create a Service.
kubectl create -f nginx-elb-svc.yaml
If information similar to the following is displayed, the Service has been created.
service/nginx created
kubectl get svc
If information similar to the following is displayed, the access type has been set, and the workload is accessible.
NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE kubernetes ClusterIP 10.247.0.1 <none> 443/TCP 3d nginx LoadBalancer 10.247.130.196 10.78.42.242 80:31540/TCP 51s
 - Enter the URL in the address box of the browser, for example, 10.78.42.242:80. 10.78.42.242 indicates the IP address of the load balancer, and 80 indicates the access port displayed on the CCE console.
Nginx is accessible.
Figure 2 Accessing Nginx through the LoadBalancer Service
Using kubectl to Create a Service (Automatically Creating a Load Balancer)
vi nginx-deployment.yamlapiVersion: apps/v1 kind: Deployment metadata: name: nginx spec: replicas: 1 selector: matchLabels: app: nginx template: metadata: labels: app: nginx spec: containers: - image: nginx name: nginx imagePullSecrets: - name: default-secretvi nginx-elb-svc.yaml
Example of a Service using a dedicated load balancer on a public network:apiVersion: v1 kind: Service metadata: name: nginx labels: app: nginx namespace: default annotations: kubernetes.io/elb.class: performance kubernetes.io/elb.autocreate: '{ "type": "public", "bandwidth_name": "cce-bandwidth-1626694478577", "bandwidth_chargemode": "bandwidth", "bandwidth_size": 5, "bandwidth_sharetype": "PER", "eip_type": "5_bgp", "vip_subnet_cidr_id": "*****", "vip_address": "**.**.**.**", "elb_virsubnet_ids": ["*****"], "available_zone": [ "" ], "l4_flavor_name": "L4_flavor.elb.s1.small" }' kubernetes.io/elb.enterpriseID: '0' # ID of the enterprise project to which the load balancer belongs kubernetes.io/elb.lb-algorithm: ROUND_ROBIN # Load balancer algorithm kubernetes.io/elb.session-affinity-mode: SOURCE_IP # The sticky session type is source IP address. kubernetes.io/elb.session-affinity-option: '{"persistence_timeout": "30"}' # Stickiness duration (min) kubernetes.io/elb.health-check-flag: 'on' # Enable the ELB health check function. kubernetes.io/elb.health-check-option: '{ "protocol":"TCP", "delay":"5", "timeout":"10", "max_retries":"3" }' kubernetes.io/elb.tags: key1=value1,key2=value2 # ELB resource tags spec: selector: app: nginx ports: - name: cce-service-0 targetPort: 80 nodePort: 0 port: 80 protocol: TCP type: LoadBalancerThis example uses annotations to implement some advanced features of load balancing, such as sticky sessions and health check. For details, see Table 6.
Table 6 annotations parameters Parameter
Mandatory
Type
Yes
String
Select a proper load balancer type.
The value can be:
Yes
elb.autocreate object
Whether to automatically create a load balancer for the Service.
NOTE:Automatic creation of a public network load balancer: You need to purchase an EIP for the load balancer to allow access over the public network. The load balancer can also be accessed over a private network.
Automatic creation of a private network load balancer: You do not need to purchase an EIP for the load balancer. The load balancer can only be accessed over a private network.
Example
- If a public network load balancer will be automatically created, set this parameter to the following value:
'{"type":"public","bandwidth_name":"cce-bandwidth-1551163379627","bandwidth_chargemode":"bandwidth","bandwidth_size":5,"bandwidth_sharetype":"PER","eip_type":"5_bgp","name":"james","available_zone": ["cn-east-3a"],"l4_flavor_name": "L4_flavor.elb.s1.small"}'
 - If a private network load balancer will be automatically created, set this parameter to the following value:
'{"type":"inner","available_zone": ["cn-east-3a"],"l4_flavor_name": "L4_flavor.elb.s1.small"}'
kubernetes.io/elb.subnet-id
String
ID of the subnet where the cluster is located. The value can contain 1 to 100 characters.
- Mandatory when a cluster of v1.11.7-r0 or earlier is to be automatically created.
 - Optional for clusters later than v1.11.7-r0.
For details, see What Are the Differences Between the VPC Subnet API and the OpenStack Neutron Subnet API?
No
String
ID of the enterprise project for the load balancer. It is only applicable to enterprise accounts with enterprise projects enabled. After an enterprise project ID is selected, resources can be created in the ELB enterprise project.
If this parameter is not specified or is set to 0, resources will be bound to the default enterprise project.
How to obtain:
Log in to the EPS console, click the name of the target enterprise project. On the enterprise project details page, find the ID field and copy the ID.
No
String
Options:
No
String
 - Enabling sticky session: Set this parameter to SOURCE_IP, indicating that the sticky session is based on the source IP address.
No
Table 4 Object
No
String
No
Table 5 Object
No
String
Add resource tags to a load balancer. This parameter can be configured only when a load balancer is automatically created.
A tag is in the format of "key=value". Use commas (,) to separate multiple tags.
Table 7 elb.autocreate data structure Parameter
Mandatory
Type
name
No
String
Name of the automatically created load balancer.
The value can contain 1 to 64 characters. Only letters, digits, underscores (_), hyphens (-), and periods (.) are allowed.
Default: cce-lb+service.UID
type
No
String
Network type of the load balancer.
- public: public network load balancer
 - inner: private network load balancer
Default: inner
bandwidth_name
Yes for public network load balancers
String
Bandwidth name. The default value is cce-bandwidth-******.
String
Bandwidth billing option.
- bandwidth: billed by bandwidth
 - traffic: billed by traffic
Default: bandwidth
bandwidth_size
Integer
Bandwidth size. The default value is 1 to 2,000 Mbit/s. Configure this parameter based on the bandwidth range allowed in your region.
The minimum increment for bandwidth adjustment varies depending on the bandwidth range.- The minimum increment is 1 Mbit/s if the allowed bandwidth does not exceed 300 Mbit/s.
 - The minimum increment is 50 Mbit/s if the allowed bandwidth ranges from 300 Mbit/s to 1,000 Mbit/s.
 - The minimum increment is 500 Mbit/s if the allowed bandwidth exceeds 1,000 Mbit/s.
bandwidth_sharetype
String
Bandwidth sharing mode.
- PER: dedicated bandwidth
eip_type
String
EIP type.
- 5_telcom: China Telecom
 - 5_union: China Unicom
 - 5_bgp: dynamic BGP
 - 5_sbgp: static BGP
vip_subnet_cidr_id
No
String
Specifies the subnet where a load balancer is located. The subnet must belong to the VPC where the cluster resides.
If this parameter is not specified, the ELB load balancer and the cluster are in the same subnet.
vip_address
No
String
Specifies the private IP address of the load balancer. Only IPv4 addresses are supported. IPv6 addresses are not supported.
The IP address must be in the CIDR block of the load balancer. If this parameter is not specified, an IP address will be automatically assigned from the CIDR block of the load balancer.
available_zone
Yes
Array of strings
AZ where the load balancer is located.
You can obtain all supported AZs by querying the AZ list.
l4_flavor_name
Yes
String
Flavor name of the Layer-4 load balancer.
You can obtain all supported types by calling the API for querying the flavor list.
l7_flavor_name
No
String
Flavor name of the Layer-7 load balancer.
This parameter is available only for dedicated load balancers. The value of this parameter must be the same as that of l4_flavor_name, that is, both are elastic specifications or fixed specifications.
elb_virsubnet_ids
No
Array of strings
The network ID of the subnet where the load balancer is located. This subnet is used to allocate IP addresses for accessing the backend server. If this parameter is not specified, the subnet specified by vip_subnet_cidr_id will be used by default. Load balancers occupy different number of subnet IP addresses based on their specifications. Do not use the subnet CIDR blocks of other resources (such as clusters and nodes) as the load balancer CIDR block.
Example:
"elb_virsubnet_ids": [ "14567f27-8ae4-42b8-ae47-9f847a4690dd" ]
How to obtain:
Log in to the VPC console. In the navigation pane, choose Subnets. Filter the target subnet by the cluster's VPC name, click the subnet name, and copy the Network ID on the Summary tab.
If information similar to the following is displayed, the workload is being created.
kubectl get pod
 - Create a Service.
kubectl get svc
Figure 3 Accessing Nginx through the LoadBalancer Service
