- Function Overview
- Product Bulletin
- Billing
- Getting Started
User Guide
- Clusters
- Workloads
- Network
- Storage
- O&M
- Namespaces
- ConfigMaps and Secrets
- Auto Scaling
- Add-ons
- Helm Chart
- Permissions
- Settings
- Best Practices
API Reference
- Before You Start
- API Overview
- Calling APIs
APIs
- Autopilot Cluster Management
- Add-on Management for Autopilot Clusters
Autopilot Cluster Upgrade
- Upgrading a Cluster
- Performing a Pre-upgrade Check for a Cluster
- Performing a Post-upgrade Check for a Cluster
- Backing Up a Cluster
- Obtaining Details About a Specified Cluster Upgrade Booting Task
- Quota Management for Autopilot Clusters
- Tag Management for Autopilot Clusters
Chart Management for Autopilot Clusters
- Uploading a Chart
- Obtaining a Chart List
- Obtaining a Release List
- Creating a Release
- Updating a Chart
- Deleting a Chart
- Updating a Release
- Obtaining a Chart
- Deleting a Release
- Downloading a Chart
- Obtaining Chart Values
- Kubernetes APIs
- Appendix
- Billing
- Workloads
- Network Management
- Can PVs of the EVS Type in a CCE Autopilot Cluster Be Restored After They Are Deleted or Expire?
- Can CCE Autopilot PVCs Detect Underlying Storage Faults?
- How Can I Delete the Underlying Storage If It Remains After a Dynamically Created PVC is Deleted?
- Permissions
Help Center/
Cloud Container Engine_Autopilot/
User Guide/
Network/
Service/
LoadBalancer/
Configuring Security Group Rules for ICMP Traffic
Dedicated load balancers are used for CCE Autopilot clusters. If both the listener protocol and the health check protocol are UDP, you need to allow ICMP traffic from the backend subnet of the load balancer in the security group associated with the elastic network interfaces.
- Log in to the CCE console, choose Service List > Networking > Virtual Private Cloud. In the navigation pane on the left, choose Access Control > Security Groups.
- In the security group list, locate the security group associated with the elastic network interfaces. The default security group is named {Cluster name}-cce-eni-{Random ID}.
If you specify a custom security group for the cluster, select this security group.
- Click the name of the security group. On the Inbound Rules tab, click Add Rule to add an inbound rule. For details, see Figure 1.
- Protocol & Port: Select all ICMP ports.
- Source: Enter the backend subnet of the load balancer.
- Click OK.
Parent Topic: LoadBalancer
