Deploying an Nginx Workload in a CCE Autopilot Cluster
CCE Autopilot clusters are serverless. They support intelligent version upgrade, automatic vulnerability fixing, and intelligent parameter tuning, allowing you to have a more intelligent experience. In addition, CCE Autopilot uses the same underlying resource pool. You do not need to manage and maintain the allocation and expansion of underlying resources, effectively reducing O&M costs. The underlying resource pool supports quick fault isolation and rectification. This ensures that applications can run continuously and stably and improves application reliability.
Nginx is a high-performance, open-source HTTP web server and a reverse proxy for handling concurrent connections, balancing traffic, and caching static content. An Nginx workload in a cluster can serve as a load balancer and reverse proxy to effectively distribute traffic and ensure high availability and fault tolerance of applications. It also simplifies traffic management, security control, and API gateway functions in the microservice architecture, improving system flexibility and scalability.
The following describes how to create a CCE Autopilot cluster and deploy an Nginx workload in the cluster. Figure 1 shows the overall architecture.
Step |
Description |
Billing |
Sign up for a HUAWEI ID and make sure you have a valid payment method configured. |
Billing is not involved. |
Step 1: Enable CCE for the First Time and Perform Authorization |
Obtain the required permissions for your account when you use CCE in the current region for the first time. |
Create a CCE Autopilot cluster so that you can use Kubernetes in a more simple way. |
Cluster management and VPC endpoints are billed. For details, see Billing. |
Create an Nginx workload in the cluster and create a LoadBalancer Service so that the workload can be accessed from the public network. |
Pods and load balancers are billed. For details, see Cluster Billing and Billed Items (Dedicated Load Balancers). |
To avoid additional expenditures, release resources promptly if you no longer need them. |
Preparations
- Before you start, sign up for a HUAWEI ID and complete real-name authentication. For details, see Signing Up for a HUAWEI ID and Enabling Huawei Cloud Services and Getting Authenticated.
CCE works closely with multiple cloud services to support computing, storage, networking, and monitoring functions. When you log in to the CCE console for the first time, CCE automatically requests permissions to access those cloud services in the region where you run your applications. If you have been authorized in the current region, skip this step.
- Log in to the CCE console using your HUAWEI ID.
- Click
in the upper left corner of the console and select a region, for example, CN East-Shanghai1.
- Wait for the Authorization Statement dialog box to appear, carefully read the statement, and click OK.
After you agree to delegate the permissions, CCE creates an agency named cce_admin_trust in IAM to perform operations on other cloud resources and grants it the Tenant Administrator permissions. Tenant Administrator has the permissions on all cloud services except IAM. The permissions are used to call the cloud services on which CCE depends. The delegation takes effect only in the current region.
NOTICE:
CCE depends on other cloud services. If you do not have the Tenant Administrator permissions, CCE may be unavailable due to insufficient permissions. For this reason, do not delete or modify the cce_admin_trust agency when using CCE.
Step 2: Create a CCE Autopilot Cluster
Create a CCE Autopilot cluster so that you can use Kubernetes in a more simple way. In this example, only some mandatory parameters are described. You can keep the default values for other parameters. For details about other parameters, see Buying a CCE Autopilot Cluster.
- Log in to the CCE console.
- If there is no cluster in your account in the current region, click Buy Cluster or Buy CCE Autopilot Cluster.
- If there is already a cluster in your account in the current region, choose Clusters in the navigation pane and then click Buy Cluster.
- Configure basic cluster information. For details about the parameters, see Figure 2 and Table 2.
Table 2 Basic cluster information Parameter
Example Value
Type
CCE allows you to create various types of clusters for diverse needs.
- CCE standard clusters provide highly reliable and secure containers for commercial use.
- CCE Turbo clusters use high-performance cloud native networks and provide cloud native hybrid scheduling. Such clusters have improved resource utilization and can be used in more scenarios.
- CCE Autopilot clusters are serverless, and you do not need to bother with server O&M. This greatly reduces O&M costs and improves application reliability and scalability.
For more information about cluster types, see Cluster Comparison.
Cluster Name
autopilot-example
Enter a name for the cluster.
Enter 4 to 128 characters. Start with a lowercase letter and do not end with a hyphen (-). Only lowercase letters, digits, and hyphens (-) are allowed.
Enterprise Project
default
This parameter is displayed only for enterprise users who have enabled Enterprise Project.
Enterprise projects are used for cross-region resource management and make it easy to centrally manage resources by department or project team. For more information, see Project Management.
Select an enterprise project as needed. If there is no special requirement, you can select default.
Cluster Version
v1.28
Select the Kubernetes version for the cluster. You are advised to select the latest version.
- Configure cluster network information. For details about the parameters, see Figure 3 and Table 3.
Table 3 Cluster network information Parameter
Example Value
VPC
vpc-autopilot
Select a VPC where the cluster will be running. If no VPC is available, click Create VPC on the right to create one. For details, see Creating a VPC and Subnet. The VPC cannot be changed after the cluster is created.
Pod Subnet
subnet-502f
Select the subnet where the pods will be running. Each pod requires a unique IP address. The number of IP addresses in a subnet determines the maximum number of pods in a cluster and the maximum number of containers. After the cluster is created, you can add subnets.
If no subnet is available, click Create Subnet on the right to create one. For details, see Creating a VPC and Subnet.
Service CIDR Block
10.247.0.0/16
Select a Service CIDR block, which will be used by containers in the cluster to access each other. This CIDR block determines the maximum number of Services. After the cluster is created, the Service CIDR block cannot be changed.
SNAT
Enabled
This option is enabled by default, and the cluster can access the Internet through a NAT gateway. By default, an existing NAT gateway in the selected VPC is used. If there are no NAT gateways, CCE Autopilot automatically creates a NAT gateway with default specifications, binds an EIP to the NAT gateway, and configures SNAT rules.
The NAT gateway will be billed. For details, see NAT Gateway Billing.
- Click Next: Select Add-on. On the page displayed, select the add-ons to be installed during cluster creation.
In this example, only the default add-ons, CoreDNS and Kubernetes Metrics Server, are installed.
- Click Next: Add-on Configuration to configure the selected add-ons. Mandatory add-ons cannot be configured.
- Click Next: Confirm configuration, check the displayed cluster resource list, and click Submit.
It takes about 5 to 10 minutes to create a cluster. After the cluster is created, the cluster is in the Running state.
Figure 4 A running cluster
Step 3: Deploy Nginx and Access It
You can create an Nginx workload in a cluster and deploy it in containers for high resource utilization and automatic management. You also need to create a LoadBalancer Service for the workload so that the workload can be accessed from the public network. You can use either of the following methods to deploy and access the Nginx workload.
- In the navigation pane, choose Workloads. In the upper right corner, click Create Workload.
- Configure basic workload information. For details about the parameters, see Figure 5 and Table 4.
In this example, only some mandatory parameters are described. You can keep the default values for other parameters. For details about other parameters, see Creating a Workload. You can select a reference document based on the workload type.
Table 4 Basic workload information Parameter
Example Value
Workload Type
Deployment
Select a workload type. A workload defines the creation, status, and lifecycle of pods. By creating a workload, you can manage and control the behavior of multiple pods, such as scaling, update, and restoration.
- Deployment: runs a stateless application. It supports online deployment, rolling upgrade, replica creation, and restoration.
- StatefulSet: runs a stateful application. Each pod for running the application has an independent state, and the data can be restored when the pod is restarted or migrated, ensuring application reliability and consistency.
- Job: a one-off job. After the job is complete, the pods are automatically deleted.
- Cron Job: a time-based job runs a specified job in a specified period.
For more information about workloads, see Workload Overview.
In this example, Nginx is deployed as a Deployment because Nginx is mainly used to forward requests, balance loads, and distribute static content. No persistent data needs to be stored locally.
Workload Name
nginx
Enter a name for the workload.
Enter 1 to 63 characters, starting with a lowercase letter and ending with a lowercase letter or digit. Only lowercase letters, digits, and hyphens (-) are allowed.
Namespace
default
Select a namespace. A namespace is a conceptual grouping of resources or objects. Each namespace provides isolation for data from other namespaces.
After a cluster is created, the default namespace is created by default. If there is no special requirement, select default.
Pods
Enter the number of pods. The policy for setting the number of pods is as follows:
- High availability: To ensure high availability of the workload, at least 2 pods are required to prevent individual faults.
- High performance: Set the number of pods based on the workload traffic and resource requirements to avoid overload or resource waste.
In this example, set the number of pods set to 1.
- Configure container information. For details about the parameters, see Figure 6 and Table 5.
Table 5 Container settings Parameter
Example Value
Image Name
nginx
Click Select Image. In the displayed dialog box, click the Open Source Images tab and select a public image.
Image Tag
latest
Select the required image tag.
CPU Quota
0.25 cores
Specify the CPU limit, which defines the maximum number of CPU cores that can be used by a container. The default value is 0.25 cores.
Memory Quota
512 MiB
Specify the memory limit, which is the maximum memory available for a container. The default value is 512 MiB. If the memory exceeds 512 MiB, the container will be terminated.
- Click
under Service Settings. On the page that is displayed, configure the Service. For details about the parameters, see Figure 7 and Table 6.
In this example, only some mandatory parameters are described. You can keep the default values for other parameters. For details about other parameters, see Service . Select a reference document based on the Service type.
Table 6 Service settings Parameter
Example Value
Service Name
nginx
Enter a name for the Service.
Service Type
LoadBalancer
Select a Service type, which determines how the workload is accessed.
- ClusterIP: The workload can only be accessed using IP addresses in the cluster.
- LoadBalancer: The workload can be accessed from the public network through a load balancer.
In this example, external access to Nginx is required. So you need to create a Service of the LoadBalancer type. For more information about the Service types, see Service.
Load Balancer
- Dedicated
- Network load balancing (TCP/UDP)
- Use existing
- elb-nginx
- Select Use existing if there is a load balancer available.
The load balancer must meet the following requirements:
- It is in the same VPC as the cluster.
- It is a dedicated load balancer.
- It has a private IP address bound.
- If there is no available load balancer, select Auto create to create one with an EIP bound. For details, see Creating a LoadBalancer Service.
Port
Protocol: TCP
Protocol: Select a protocol for the load balancer listener.
Container Port: 80
Container Port: Enter the port on which the application listens. This port must be the same as the listening port provided by the application for external systems.
When the nginx image is used, the container port must be set to 80 because Nginx uses port 80 to provide HTTP services by default.
Service Port: 8080
Service Port: Enter a custom port. The load balancer will use this port as the listening port to provide an entry for external traffic.
- Click Create Workload.
After the Deployment is created, it is in the Running state in the Deployment list.
Figure 8 A running workload - Click the workload name to go to the workload details page and obtain the external access address of Nginx. On the Access Mode tab, view the access address in the format of {EIP bound to the load balancer}:{Access port}. {EIP bound to the load balancer} indicates the public IP address of the load balancer, and {Access port} is the Service Port in 5.
Figure 9 Access address
- In the address box of your browser, enter {EIP bound to the load balancer}:{Access port} to access the application.
Figure 10 Accessing Nginx
Command line operations are required. You can perform related operations in either of the following ways:
- Using CloudShell: You need to ensure kubectl has been configured in CloudShell and the cluster has been connected using CloudShell. For details, see Connecting to a Cluster Using CloudShell.
- Using an ECS: You need to prepare a Linux ECS that is in the same VPC as the cluster and has an EIP bound. For details, see Purchasing and Using a Linux ECS. You can use an existing ECS or buy a new one. You also need to install kubectl and connect to the cluster through kubectl.
The following uses the first method as an example to describe how you can use kubectl to create an Nginx workload.
- Click the cluster name to access the cluster console.
- In the upper right corner, click CLI tool to access CloudShell.
Using CloudShell to connect to a cluster is only available in some regions. For details, see the management console. If a region is not supported, using an ECS for operations.
Figure 11 CloudShell - Create a YAML file for creating a workload. In this example, the file name is nginx-deployment.yaml. You can change it as needed.
A Linux file name is case sensitive and can contain letters, digits, underscores (_), and hyphens (-), but cannot contain slashes (/) or null characters (\0). To improve compatibility, do not use special characters, such as spaces, question marks (?), and asterisks (*).
vim nginx-deployment.yaml
The file content is as follows:
apiVersion: apps/v1 kind: Deployment metadata: name: nginx # Workload name spec: replicas: 1 # Number of pods selector: matchLabels: # Selector, which is used to select resources with specific labels. The value must be the same as that of the selector in the YAML file of the LoadBalancer Service in 6. app: nginx template: metadata: labels: # Labels app: nginx spec: containers: - image: nginx:latest # {Image name}:{Image tag} name: nginx imagePullSecrets: - name: default-secret
Press Esc to exit editing mode and enter :wq to save the file.
- Run the following command to create the workload:
kubectl create -f nginx-deployment.yaml
If information similar to the following is displayed, the workload is being created:
deployment.apps/nginx created
- Run the following command to check the workload status:
kubectl get deployment
If the value of READY is 1/1, the pod created for the workload is available. This means the workload has been created.
NAME READY UP-TO-DATE AVAILABLE AGE nginx 1/1 1 1 4m59s
The following table describes the parameters in the command output.
Table 7 Parameters in the command output Parameter
Example Value
NAME
nginx
Workload name.
READY
1/1
The number of available pods/desired pods for the workload.
UP-TO-DATE
The number of pods that have been updated for the workload.
AVAILABLE
The number of pods available for the workload.
AGE
4m59s
How long the workload has run.
- Run the following command to create the nginx-elb-svc.yaml file for configuring the LoadBalancer Service and associating the Service with the created workload. You can change the file name as needed.
An existing load balancer is used to create the Service. To automatically create a load balancer, see Using kubectl to Create a Load Balancer.
vim nginx-elb-svc.yaml
apiVersion: v1 kind: Service metadata: name: nginx # Service name annotations: kubernetes.io/elb.id: <your_elb_id> # Load balancer ID. Replace it with the actual value. kubernetes.io/elb.class: performance # Load balancer type spec: selector: # The value must be the same as the value of matchLabels in the YAML file of the workload in 3. app: nginx ports: - name: service0 port: 8080 protocol: TCP targetPort: 80 type: LoadBalancer
Table 8 Parameters for using an existing load balancer Parameter
Example Value
405ef586-0397-45c3-bfc4-xxx
ID of an existing load balancer.
How to Obtain: Log in to the Network Console. In the upper left corner, select the region where the cluster resides. In the navigation pane, choose Elastic Load Balance > Load Balancers and locate the load balancer. The ID is displayed below the load balancer name. Click the name of the load balancer. On the Summary tab, verify that the load balancer meets the preceding requirements.
performance
Load balancer type. The value can only be performance, which means that only dedicated load balancers are supported.
selector
app: nginx
Selector, which is used by the Service to send traffic to pods with specific labels.
ports.port
8080
The port used by the load balancer as an entry for external traffic. You can use any port.
ports.protocol
TCP
Protocol for the load balancer listener.
ports.targetPort
80
Port used by a Service to access the target container. This port is closely related to the applications running in the container.
If the nginx image is used, set this port to 80.
- Run the following command to create a Service:
kubectl create -f nginx-elb-svc.yaml
If information similar to the following is displayed, the Service has been created:
service/nginx created
- Run the following command to check the Service:
kubectl get svc
If information similar to the following is displayed, the workload access mode has been configured:
NAME TYPE CLUSTER-IP EXTERNAL-IP PORT(S) AGE kubernetes ClusterIP 10.247.0.1 <none> 443/TCP 18h nginx LoadBalancer 10.247.56.18 xx.xx.xx.xx,xx.xx.xx.xx 8080:30581/TCP 5m8s
- In the address box of your browser, enter {External access address}:{Service port} to access the workload. The external access address is the first IP address displayed for EXTERNAL-IP, and the Service port is 8080.
Figure 12 Accessing Nginx
Example Value
Workload Type
Deployment
Workload Name
nginx
Namespace
default
Pods
Example Value
Image Name
nginx
Image Tag
latest
CPU Quota
0.25 cores
Memory Quota
512 MiB
- Click
Example Value
Service Name
nginx
Service Type
LoadBalancer
Load Balancer
- Dedicated
- Use existing
- elb-nginx
Port
Protocol: TCP
Container Port: 80
Service Port: 8080
Example Value
NAME
nginx
Workload name.
READY
1/1
UP-TO-DATE
AVAILABLE
AGE
4m59s
Example Value
performance
selector
app: nginx
ports.port
8080
ports.protocol
TCP
ports.targetPort
80
kubectl get svc
Follow-up Operations: Releasing Resources
- Deleting a cluster will delete the workloads and Services in the cluster, and the deleted data cannot be recovered.
- VPC resources (such as endpoints, NAT gateways, and EIPs for SNAT) associated with a cluster are retained by default when the cluster is deleted. Before deleting a cluster, ensure that the resources are not used by other clusters.
- Log in to the CCE console. In the navigation pane, choose Clusters.
- Locate the cluster, click
in the upper right corner of the cluster card, and click Delete Cluster.
- In the displayed Delete Cluster dialog box, delete related resources as prompted.
- Enter DELETE and click Yes to start deleting the cluster.
It takes 1 to 3 minutes to delete a cluster. If the cluster name disappears from the cluster list, the cluster has been deleted.
