Updated on 2026-09-30 GMT+08:00
Overview
As IT operations evolve from traditional infrastructure to cloud service models, conventional approaches face challenges such as complex service-to-service interactions, fast application iteration, large-scale operational objects, and nonlinear behaviors in complex systems. Service downtime will bring huge economic losses and reputational damage to the company.
Chaos engineering is introduced to the O&M process. Through periodic simulation, system weaknesses (such as software bugs, solution design defects, and fault recovery process points) can be identified before problems occur on the live network, and system availability problems can be detected and resolved in a timely manner, continuously improve application resilience and build O&M confidence. For unavoidable scenarios (such as hardware faults and network device board faults), formulate a contingency plan for quick fault rectification.
COC allows you to perform automatic chaos drills covering from risk identification, contingency plan management, fault injection, and review and improvement. Based on years of best practices of Huawei Cloud SRE in chaos drills, customers can proactively identify, mitigate, and verify risks of cloud applications, continuously improving the resilience of cloud applications.
You have enabled the Fault Drills package. For details about billing, see Billing Items.
Procedure Description
Chaos drill process:
Step 1: To analyze the potential faults of an application, you can check the trigger conditions, symptoms, and impacts on customer services of a fault to establish a failure mode.
Step 2: You can plan a drill, specify an executor, and schedule the drill. Upon receiving a drill plan request, the executor can create a drill task that will be associated with a given failure mode and a region, simulating a realistic fault scenario.
Step 3: You can directly create a drill task. In the drill task list, start the chaos drill task and view the drill records.
Image and Disruptor Version Support Statement
Currently, a chaos drill supports targets such as Elastic Cloud Servers (ECSs), FlexusL instances, and Bare Metal Servers (BMSs), and provides corresponding resource and network disruptors for you to drill. Probe disruptors include disruptors for practicing, host resources, host processes, and host network modules. By integrating disruptor modules and functions, you can accurately simulate faults in the actual environment and identify system availability issues as early as possible, continuously improving application resilience.
The following table lists the ECSs, FlexusL, and BMSs image versions and supported probe tools.
CentOS 6.10 images and earlier versions do not support some probe disruptors because the system does not have the shared libraries (GLIBC_2.14 and GLIBCXX_3.4.15) required for running corresponding probe packages.
Table 1 lists the probe disruptors supported by each ECS image version.
Table 1 ECS and disruptor compatibility list
Disruptor
Supported Image Version
Disruptors for practicing
Qualifying practice
CentOS 7.2, CentOS 7.6, CentOS 7.9, CentOS 8.2, Ubuntu 16.04, Ubuntu 18.04, Ubuntu 20.04, Ubuntu 22.04, EulerOS 2.2, EulerOS 2.5, EulerOS 2.9, EulerOS 2.10, Debian 8.2.0, Debian 8.8.0, Debian 9.0.0, Debian 11.1.0, and Huawei Cloud EulerOS 2.0
Host resources
CPU usage increase
Memory usage increase
Disk usage increase
Disk I/O pressure increase
Host process
Process ID exhaustion
The process IDs of the EulerOS image are used up. The protection mechanism may be triggered, causing the kernel to restart. As a result, the drill fails.
Killing a process/Continuously killing a process
Host network
Network latency
CentOS 7.2, CentOS 7.6, CentOS 7.9, Ubuntu 16.04, Ubuntu 18.04, Ubuntu 20.04, Ubuntu 22.04, EulerOS 2.2, EulerOS 2.5, EulerOS 2.9, EulerOS 2.10, Debian 8.2.0, Debian 8.8.0, Debian 9.0.0, Debian 11.1.0, and Huawei Cloud EulerOS 2.0
Network packet loss
Network error packets
Duplicate packets
Network packet disorder
Network disconnection
NIC break-down
If the NIC becomes faulty, UniAgent may go offline. As a result, UniAgent information cannot be received, and the page fails to be displayed.
DNS tampering
Port occupation
Server disconnection
If the server becomes faulty, UniAgent may go offline. As a result, UniAgent information cannot be received, and the page fails to be displayed.
NIC bandwidth limiting
Connection exhaustion
Table 2 lists the probe disruptors supported by each BMS image version.
Table 2 Compatibility between bare metal server images and disruptors
Disruptor
Qualifying practice
CentOS 7.3, CentOS 7.9, Ubuntu 16.04, Ubuntu 18.04, and EulerOS 2.3
Host resources
CPU usage increase
Disk usage increase
Host process
CentOS 7.4, CentOS 7.9, Ubuntu 16.04, Ubuntu 18.04, and EulerOS 2.3
Host network
Network latency
Network packet loss
Duplicate packets
NIC break-down
DNS tampering
CentOS 6.9, CentOS 7.9, Ubuntu 16.04, Ubuntu 18.04, EulerOS 2.3, and EulerOS 2.9
Port occupation
CentOS 6.9, CentOS 7.4, CentOS 7.9, Ubuntu 16.04, Ubuntu 18.04, EulerOS 2.3, and EulerOS 2.9
Table 3 lists the probe disruptors supported by each FlexusL image.
Table 3 FlexusL instance images and disruptor tool compatibility list
Disruptor
Qualifying practice
CentOS 7.2, CentOS 8.2, Ubuntu 16.04, Ubuntu 22.04, EulerOS 2.0, Debian 8.2, and Debian 11.1.0
Host resources
CPU usage increase
Disk usage increase
Host process
Host network
Network latency
CentOS 7.2, Ubuntu 16.04, Ubuntu 22.04, EulerOS 2.0, Debian 8.2, and Debian 11.1.0
Network packet loss
Duplicate packets
NIC break-down
DNS tampering
Port occupation
