- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Help Center/
Cloud Operations Center/
User Guide/
Faults/
Alarms/
Aggregated Alarms/
Handling Alarms
Handling Alarms
- Log in to COC.
- In the navigation pane, choose Fault Management > Alarms. On the displayed page, click Aggregated alarm > Unhandled Alarms tabs. Locate the target alarm record, choose More > handle in the Operation column.
Figure 1 Handling alarms
- On the displayed page, configure the parameters and click Submit.
Figure 2 Handling an alarm
- If you select Scripts, configure the parameters by referring to Executing Custom Scripts and Executing Common Scripts.
- If you select Jobs, configure the parameters by referring to Executing a Custom Job and Executing a Common Job.
Parent topic: Aggregated Alarms
