- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
O&M Operations Center
You can query and follow up O&M to-do tasks.
Query and follow up O&M to-do tasks on COC.
- Log in to COC.
- On the Overview page of COC, you can view the number of incidents to be handled, alarms to be handled, and your to-do tasks in the upper left part of the page.
Figure 1 O&M transaction tracking
- Click Pending Incidents, Pending Alarms, or My To-Dos to go to the corresponding O&M transaction page.
Parent topic: Overview
