Updated on 2026-06-16 GMT+08:00
Dashboard
Settings offers you an entry to check and modify the basic settings of clusters. It includes information from dimensions like Cluster Information, Cluster Settings, Master Node AZs, and Installed Add-ons.
Accessing the Settings
  2. In the navigation pane, choose Settings and click the Dashboard tab.
    Figure 1 Checking the cluster dashboard
Cluster Information
It includes:
  • Cluster ID: uniquely identifies a cluster resource. It is automatically generated after a cluster is created and can be used in scenarios such as API calling.
  • Current Name: After a cluster is created, you can click to change its name.
  • Original Name: specifies a cluster's original name after its current name is changed. The current name of a cluster must be unique.
  • Status: specifies the status of a cluster. For details, see Cluster Lifecycle.
  • Security Service: specifies whether HSS is enabled for the current cluster. After this function is enabled, the cluster management permissions are granted to the HSS agency, and CCE will automatically install the agent on the nodes in the cluster. However, this will use certain resources.
    • Free Security Check Report: identifies risky cluster configurations, image vulnerabilities, and privileged containers.
    • HSS Container Edition: counts your containers, protects their runtimes from escapes and other intrusions, and enhances security for service containerization. For details about the prices, see Price Calculator.
    After HSS is enabled, CCE will automatically grant cluster management permissions to the HSS agency hss_policy_trust. For details, see hss_policy_trust.
  • Type: specifies whether a cluster is a CCE standard cluster or a CCE Turbo cluster. For details about the differences between CCE standard and CCE Turbo clusters, see Comparison Between Cluster Types.
  • Created On: specifies the time when a cluster was created. You will be billed based on the creation time of clusters.
Cluster Settings
After a cluster is created, you can modify the following items for it:
  • Cluster Scale: specifies how many nodes a cluster can manage at most. You can change the cluster scale as needed. For details, see Changing a Cluster Scale.
  • Cluster Version | Patch Version: specifies the Kubernetes version and CCE patch version of a cluster.
  • Network Model: specifies the network model of a cluster, which cannot be changed. For details about network models, see Container Networks.
  • Billing Mode: specifies the billing mode of a cluster. A pay-per-use cluster can be changed to a yearly/monthly one. For details, see Changing the Billing Mode of a Cluster from Pay-per-Use to Yearly/Monthly.
  • Enterprise Project: specifies the enterprise project to which a cluster belongs. For details, see Enterprise Center Overview.
  • Operation Protection: After this function is enabled, you need to confirm operations by using the virtual MFA device, SMS messages, or emails. You can go to the IAM console, choose Security Settings > Critical Operations, and enable the protection functions.
  • Resource Tag: You can add resource tags to classify resources.
  • Cluster Description: specifies the description that you entered for a cluster. A maximum of 200 characters is allowed.
  • Secret Encryption: You can encrypt Kubernetes secrets stored in CCE using envelope encryption with KMS keys. For details, see Using KMS to Encrypt Secrets at Rest.
  • Global OBS Access Secret (paas.longaksk): If you have created a global access secret while using OBS volumes in a cluster, the system will create a secret called paas.longaksk in the kube-system namespace of the cluster. This secret is used to store the global AK and SK.
    The global access secret (paas.longaksk) is used by project. Once a global access secret is used, it is automatically created for each cluster within the same project. However, this can lead to security and management complexities. Therefore, it is not recommended that you use global access secrets. To disable global access keys, check whether the cluster uses global access keys. For details, see What Is an OBS Global Access Key and How Do I Check Whether a Global Access Key Is Used in a Cluster?
  • Cluster Deletion Protection: a measure taken to prevent accidental deletion of clusters through the console or APIs. After this function is enabled, you will not be able to delete or unsubscribe from clusters.
Master Node AZs
You can check how many master nodes are supported in a cluster. To check data such as the resource usage of the master nodes, click View Monitoring in the upper right corner to go to Monitoring Center.
Installed Add-ons
You can check the installed add-ons in a cluster. If there is an add-on to be upgraded in the cluster, click Upgrade Now to go to the Add-ons page and see more details.
