LoadBalancer Ingress Annotations
You can add annotations to a YAML file for more advanced ingress functions. This section describes the annotations that can be used when you create a LoadBalancer ingress.
Indexes
| Category | Ingress Annotation |
| Load balancer settings | |
| Port or protocol settings | |
| Advanced features of ELB listeners | |
| Forwarding policy |
In a cluster, multiple ingresses can share a listener, allowing them to use the same port on a single load balancer. If two ingresses have different listener configurations, the listener configuration of the earlier ingress (known as the first route) will be used. For details about how to confirm the first route, see How Can I Determine Which Ingress the Listener Settings Have Been Applied To?
This case involves the following scenarios:
- Configuring ELB Certificates
- Using HTTP/2
- Configuring Timeout for an Ingress
- Blocklist/Trustlist
- Configuring an HTTP/HTTPS Header
- Enabling GZIP
Ensure that the configurations of different listeners for various ingresses are synchronized.
Basic Configurations for Interconnecting with ELB
- Associate an existing load balancer. For details, see Associating an Existing Load Balancer to an Ingress While Creating the Ingress.
- Automatically create a load balancer. For details, see Automatically Creating a Load Balancer While Creating an Ingress.
| Parameter | Type | Description | Supported Cluster Version |
| kubernetes.io/elb.class | String | Select a proper load balancer type. This parameter cannot be modified after the ingress is created. Options:
Default: union | v1.9 or later |
| kubernetes.io/ingress.class | String |
This parameter is mandatory when you create an ingress. The default value is cce. For clusters v1.23 or later, use the parameter ingressClassName. For details, see Creating a LoadBalancer Ingress Using kubectl. | Only clusters v1.21 or earlier |
| kubernetes.io/elb.port | String | External port registered with the LoadBalancer Service address. The value ranges from 1 to 65535. The default value is 80 for HTTP and 443 for HTTPS. NOTE: Some ports on a shared load balancer are highly risky and blocked by default, for example, port 21. | v1.9 or later |
| kubernetes.io/elb.id | String | When associating only existing load balancers, you can use either this parameter or kubernetes.io/elb.ip. If they conflict, kubernetes.io/elb.id will take precedence. This parameter cannot be modified after the ingress is created. This parameter indicates the ID of a load balancer. How to obtain: Log in to the ELB console and click the load balancer name. On the Summary tab of the load balancer details page, find the ID field and copy it. | v1.9 or later |
| kubernetes.io/elb.ip | String | When associating only existing load balancers, you can use either this parameter or kubernetes.io/elb.id. If they conflict, kubernetes.io/elb.id will take precedence. This parameter cannot be modified after the ingress is created. This parameter indicates the IP address of a load balancer. When creating an ingress, specify a public or private IP address for a shared load balancer. For a dedicated load balancer, only a private IP address can be specified. | v1.9 or later |
| kubernetes.io/elb.autocreate | Table 26 object | Mandatory when load balancers are automatically created. This parameter cannot be modified after the ingress is created. Example:
| v1.9 or later |
| kubernetes.io/elb.enterpriseID | String | Optional when load balancers are automatically created. This parameter is available in clusters v1.15 or later. In clusters earlier than v1.15, load balancers are created in the default project by default. This parameter indicates the ID of the enterprise project in which the ELB load balancer will be created. If this parameter is not specified or is set to 0, resources will be bound to the default enterprise project. How to obtain: Log in to the EPS console. Click the enterprise project name. On the details page, copy the ID. | v1.15 or later |
| kubernetes.io/elb.subnet-id | String | Optional when load balancers are automatically created. ID of the subnet where the cluster is located. The value can contain 1 to 100 characters.
| Mandatory for clusters of a version earlier than v1.11.7-r0 Discarded in clusters of a version later than v1.11.7-r0 |
Adding Resource Tags
For details about applications and use cases, see Automatically Creating a Load Balancer While Creating an Ingress.
| kubernetes.io/elb.tags | String | Add resource tags to a load balancer. This parameter can be configured only when a load balancer is automatically created. A tag is in the format of "key=value". Use commas (,) to separate multiple tags. | v1.23.11-r0, v1.25.6-r0, v1.27.3-r0, v1.23.8-r1, v1.25.3-r1, or later |
Configuring a Custom EIP
For details about applications and use cases, see Configuring a Custom EIP for a LoadBalancer Ingress.
| kubernetes.io/elb.custom-eip-id | String | ID of the custom EIP, which can be seen on the EIP console. The EIP must be bindable. | v1.23.18-r0, v1.25.13-r0, v1.27.10-r0, v1.28.8-r0, v1.29.4-r0, v1.30.1-r0, or later |
Configuring a Reclaim Policy for an Auto-created Load Balancer
| kubernetes.io/elb.instance-reclaim-policy | String | Optional when load balancers are automatically created. Configure a reclaim policy for an auto-created load balancer. The options are as follows:
| v1.28.15-r60, v1.29.15-r20, v1.30.14-r20, v1.31.10-r20, v1.32.6-r20, v1.33.5-r10, or later |
The following shows how to use the preceding annotation:
kind: Ingress
namespace: default
annotations:
kubernetes.io/elb.port: '80'
kubernetes.io/elb.class: performance
kubernetes.io/elb.autocreate: '{"type":"inner","available_zone":["******"],"elb_virsubnet_ids":["*****"],"ipv6_vip_virsubnet_id":"******","l7_flavor_name":"L7_flavor.elb.pro.max","l4_flavor_name":"","vip_subnet_cidr_id":"******"}'
kubernetes.io/elb.enterpriseID: '0'
kubernetes.io/elb.instance-reclaim-policy: retain # Configure a reclaim policy for an auto-created load balancer.
rules:
- host: ''
http:
paths:
- path: /
backend:
service:
port:
number: 80
property:
ingressClassName: cce Configuring ELB Certificates
For details about applications and use cases, see Configuring an HTTPS Certificate for a LoadBalancer Ingress.
| kubernetes.io/elb.tls-certificate-ids | String | ELB certificate IDs, which are separated by comma (,). The list length is greater than or equal to 1. The first ID in the list is the server certificate, and the other IDs are SNI certificates in which a domain name must be contained. How to obtain: Log in to the ELB console and choose Certificates. In the certificate list, copy the ID under the target certificate name. | v1.19.16-r2, v1.21.5-r0, v1.23.3-r0, or later |
| kubernetes.io/elb.tls-ciphers-policy | String | The default value is tls-1-2, which is the default security policy used by the listener and takes effect only when HTTPS is used. Options:
For details of cipher suites for each security policy, see Table 3. | Clusters v1.17.17 or later |
| kubernetes.io/elb.security_policy_id | String | The ID of the custom security group policy on ELB. Obtain it on the ELB console. This field takes effect only when HTTPS is used and has a higher priority than the default security policy. For details about how to create and update a custom security policy, see TLS Security Policy. | Clusters v1.17.17 or later |
Using HTTP/2
For details about applications and use cases, see Configuring HTTP/2 for a LoadBalancer Ingress.
| kubernetes.io/elb.http2-enable | String | Whether HTTP/2 is enabled. Request forwarding using HTTP/2 improves access performance between your application and the load balancer. However, the load balancer still uses HTTP/1.x to forward requests to the backend server. Options:
Note: HTTP/2 can be enabled or disabled only when the listener uses HTTPS. This parameter is invalid and defaults to false when the listener protocol is HTTP. | v1.23.13-r0, v1.25.8-r0, v1.27.5-r0, v1.28.3-r0, or later |
Interconnecting with HTTPS/gRPC Backend Services
For details about applications and use cases, see Configuring HTTPS Backend Services for a LoadBalancer Ingress and Configuring gRPC Backend Services for a LoadBalancer Ingress.
| kubernetes.io/elb.pool-protocol | String | To interconnect with HTTPS backend services, set this parameter to https. | v1.23.8, v1.25.3, or later |
| To interconnect with gRPC backend services, set this parameter to grpc. | v1.23.10-r20, v1.25.5-r20, v1.27.2-r20, v1.28.1-r0, or later |
Configuring a Range of Listening Ports
A custom listening port can be configured for an ingress. In this way, both ports 80 and 443 can be exposed.
For details about applications and use cases, see Configuring a Range of Listening Ports for a LoadBalancer Ingress.
| kubernetes.io/elb.listen-ports | String | Configure multiple listening ports for an ingress. The port number ranges from 1 to 65535. The following is an example for JSON characters: kubernetes.io/elb.listen-ports: '[{"HTTP":80},{"HTTPS":443}]'
| v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later |
Configuring Mutual Authentication
| kubernetes.io/elb.client-ca-cert-id | String | Required only for mutual authentication. The ELB certificate ID serves as the CA certificate. How to obtain: Log in to the ELB console and choose Certificates. In the certificate list, copy the ID under the target certificate name. | Clusters v1.28.15-r60, v1.29.15-r20, v1.30.14-r20, v1.31.10-r20, v1.32.6-r20, v1.33.5-r10, or later support this configuration. |
kind: Ingress
namespace: default
annotations:
kubernetes.io/elb.port: '443'
kubernetes.io/elb.id: *****
kubernetes.io/elb.tls-certificate-ids: *****
kubernetes.io/elb.client-ca-cert-id: ***** # Configure mutual authentication.
rules:
- host: ''
http:
paths:
- path: /
backend:
service:
port:
number: 80
property:
ingressClassName: cce Configuring a QUIC Listener
For details about applications and use cases, see Configuring a QUIC Listener for a LoadBalancer Ingress.
| kubernetes.io/elb.protocol | String | Frontend protocol of the load balancer listener. When configuring the QUIC frontend, set this parameter to QUIC. | v1.28.15-r80, v1.29.15-r40, v1.30.14-r40, v1.31.14-r0, v1.32.9-r0, v1.33.7-r0, v1.34.2-r0, or later |
For details about applications and use cases, see Configuring Timeout for a LoadBalancer Ingress.
| kubernetes.io/elb.keepalive_timeout | String | Timeout for client connections. If there are no requests reaching the load balancer during this period, the load balancer will disconnect the connection from the client and establish a new connection when there is a new request. The value ranges from 0 to 4000 (in seconds). The default value is 60. | Dedicated load balancers: v1.19.16-r30, v1.21.10-r10, v1.23.8-r10, v1.25.3-r10, or later Shared load balancers: v1.23.13-r0, v1.25.8-r0, v1.27.5-r0, v1.28.3-r0, or later |
| kubernetes.io/elb.client_timeout | String | Timeout for waiting for a request from a client. There are two cases:
The value ranges from 1 to 300 (in seconds). The default value is 60. | |
| kubernetes.io/elb.member_timeout | String | Timeout for backend server response. After a request is forwarded to the backend server, if the backend server does not respond within the duration specified by member_timeout, the load balancer will stop waiting and return HTTP 504 Gateway Timeout. The value ranges from 1 to 300 (in seconds). The default value is 60. |
Configuring a Slow Start
For details about applications and use cases, see Configuring a Slow Start for a LoadBalancer Ingress.
| kubernetes.io/elb.slowstart | String | Duration of slow start, in seconds. The slow start duration ranges from 30 to 1200.
NOTE: The load balancer linearly increases the proportion of requests to backend servers in slow start mode. When the configured slow start duration elapses, the load balancer sends full share of requests to backend servers and exits the slow start mode. | v1.23 or later |
Blocklist/Trustlist
For details about applications and use cases, see Configuring a Blocklist/Trustlist Access Policy for a LoadBalancer Ingress.
| kubernetes.io/elb.acl-id | String |
| v1.23.12-r0, v1.25.7-r0, v1.27.4-r0, v1.28.2-r0, or later |
| kubernetes.io/elb.acl-status | String | This parameter is mandatory when you configure an IP address blocklist or trustlist for a load balancer. Options:
| kubernetes.io/elb.acl-type | String | This parameter is mandatory when you configure an IP address blocklist or trustlist for a load balancer. Options:
For details about applications and use cases, see Configuring an HTTP/HTTPS Header for a LoadBalancer Ingress.
| kubernetes.io/elb.x-forwarded-port | String | A load balancer can obtain the port number of a listener using X-Forwarded-Port and include the port number into the packets sent to the backend server.
| kubernetes.io/elb.x-forwarded-for-port | String | A load balancer can obtain a client port number for requests using X-Forwarded-For-Port and include the port number into the packets sent to the backend server.
| kubernetes.io/elb.x-forwarded-host | String |
| kubernetes.io/elb.x-real-ip | String |
| v1.25.16-r30, v1.27.16-r30, v1.28.15-r20, v1.29.13-r0, v1.30.10-r0, v1.31.6-r0, v1.32.1-r0, or later |
Enabling GZIP
For details about applications and use cases, see Configuring GZIP Data Compression for a LoadBalancer Ingress.
| kubernetes.io/elb.gzip-enabled | String | LoadBalancer ingresses support data compression, which reduces the size of files to be transferred, improves file transfer efficiency, and reduces the bandwidth needed for the transmission. If this function is enabled, specific files will be compressed. If it is not enabled, files will not be compressed. By default, data compression is disabled. The files in the following format can be compressed:
This function is available only for HTTP/HTTPS listeners of dedicated load balancers. Deleting the advanced configuration for data compression or the target annotation will not modify the existing ELB settings. | v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later |
Configuring IP Addresses as Backend Servers
For details about applications and use cases, see Configuring IP Addresses as Backend Servers for LoadBalancer Ingresses.
| kubernetes.io/elb.ip-target-enabled | String | Enable IP addresses as backend servers for a load balancer. After this function is enabled, the backend IP addresses added to the associated Service or ingress are all IP addresses in VPC subnets. For a CCE Turbo cluster, the backend is <pod-IP-address>:<target-port>. For a CCE standard cluster, the backend is <node-IP-address>:<NodePort>.
CAUTION:
Configuring Grayscale Release
For details about applications and use cases, see Configuring Grayscale Release for a LoadBalancer Ingress.
| kubernetes.io/elb.canary | String | Grayscale release status for an ingress. If this parameter is set to true, the implementation of grayscale release varies depending on annotation configurations. Option: true
| kubernetes.io/elb.canary-weight | String | Weight of a grayscale release. After this parameter is configured, the ingress will be grayscale released based on the weight.
| kubernetes.io/elb.session-affinity-mode | String | After weight-based grayscale release is enabled, configure sticky sessions. This parameter can only be set to HTTP_COOKIE for grayscale releases. | v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later |
| kubernetes.io/ elb.session-affinity-option | String | Sticky session timeout after sticky sessions are enabled for weight-based grayscale releases. The parameter value is a JSON string in the following format: {"persistence_timeout": "1440"} Parameters:
| kubernetes.io/elb.canary-by-header | String | Key of an ingress header used for grayscale release, indicating the name of a request header. This parameter must be used with kubernetes.io/elb.canary-by-header-value. Parameters: Enter 1 to 40 characters. Only letters, digits, hyphens (-), and underscores (_) are allowed. | v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later |
| kubernetes.io/elb.canary-by-header-value | String | Value of an ingress header used for grayscale release. This parameter must be used with kubernetes.io/elb.canary-by-header. The parameter value is an array in JSON format, for example: '{"values":["a","b"]}' Parameters:
| kubernetes.io/elb.canary-by-cookie | String | Key of cookie-based grayscale release, indicating the name of a request cookie. This parameter must be used with kubernetes.io/elb.canary-by-cookie-value. Parameters: Enter 1 to 100 characters, including letters, digits, and other characters (!%'"()*+,./:=?@^\\-_`~). | v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later |
| kubernetes.io/elb.canary-by-cookie-value | String | Value of cookie-based grayscale release. This parameter must be used with kubernetes.io/elb.canary-by-cookie. The parameter value is an array in JSON format, for example: '{"values":["a","b"]}' Parameters:
| kubernetes.io/elb.canary-related-ingress-uid | String | UID of the original ingress associated with the grayscale release ingress, which is used to display the association between the original ingress and the grayscale release ingress. ● Format: character string ● Value: metadata.uid of the original ingress | v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later |
Configuring URL Redirection
For details about applications and use cases, see Configuring URL Redirection for a LoadBalancer Ingress.
| kubernetes.io/elb.redirect-url | String | URL for redirection. Format:
Parameter: This configuration takes effect on all forwarding rules of a single ingress. After the configuration is deleted, the target URL redirection rule will be automatically cleared. Either this annotation or the annotation of a grayscale release can be configured. | v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later |
| kubernetes.io/elb.redirect-url-code | String | Code returned after an ingress is redirected to a URL. Format: The return code can be 301, 302, 303, 307, or 308. Parameter: The default value is 301. |
Configuring URL Rewriting
For details about applications and use cases, see Configuring URL Rewriting for a LoadBalancer Ingress.
| kubernetes.io/elb.rewrite-target | String | Information about the rewritten path. Format: A proper rule matching a regular expression must start with a slash (/). Parameter: This configuration takes effect on the URL of a single ingress matching the regular expression. After the configuration is deleted, the target URL rewriting rule will be automatically cleared. Either this annotation or the annotation of a grayscale release can be configured. | v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later |
Redirecting HTTP to HTTPS
For details about applications and use cases, see Redirecting HTTP to HTTPS for a LoadBalancer Ingress.
| kubernetes.io/elb.ssl-redirect | String | Whether to enable redirection from HTTP to HTTPS. Format: The value can be true or false. Parameter: true indicates that redirection is enabled. If the value is false or the parameter is unavailable, redirection is disabled. NOTE: Either this annotation or the annotation of a grayscale release can be configured. | If a dedicated load balancer is used, the cluster version must be v1.23.14-r0, v1.25.9-r0, v1.27.6-r0, v1.28.4-r0, or later. |
Configuring the Priorities of Forwarding Rules
When ingresses use the same load balancer listener, forwarding rules can be prioritized based on the following rules:
- Forwarding rules of different ingresses: The rules are sorted based on the priorities (ranging from 1 to 1000) of the kubernetes.io/elb.ingress-order annotation. A smaller value indicates a higher priority.
- Forwarding rules of an ingress: If the kubernetes.io/elb.rule-priority-enabled annotation is set to true, the forwarding rules are sorted based on the sequence in which they are added during ingress creation. A forwarding rule added earlier indicates a higher priority. If the kubernetes.io/elb.rule-priority-enabled annotation is not configured, the default sorting of the forwarding rules on the load balancer will be used.
If the preceding annotations are not configured, the default sorting of the forwarding rules on the load balancer will be used, regardless of whether the forwarding rules are of the same ingress or different ingresses under the same load balancer listener.
For details about applications and use cases, see Configuring Forwarding Rule Priorities for LoadBalancer Ingresses.
| kubernetes.io/elb.ingress-order | String | Specifies the sequence of forwarding rules of different ingresses. The value ranges from 1 to 1000. A smaller value indicates a higher priority. The priority of a forwarding rule must be unique under the same load balancer listener. This parameter is available only for dedicated load balancers. NOTE:
| v1.23.15-r0, v1.25.10-r0, v1.27.7-r0, v1.28.5-r0, v1.29.1-r10, or later |
| kubernetes.io/elb.rule-priority-enabled | String | This parameter can only be set to true, indicating to sort the forwarding rules of an ingress. The priorities of the forwarding rules are determined based on the sequence in which they are added during ingress creation. A forwarding rule added earlier indicates a higher priority. If this parameter is not configured, the default sorting of the forwarding rules on the load balancer will be used. After this parameter is enabled, it cannot be disabled. This parameter is available only for dedicated load balancers. |
Configuring a Custom Header Forwarding Policy
For details about applications and use cases, see Configuring a Custom Header Forwarding Policy for a LoadBalancer Ingress.
| kubernetes.io/elb.headers.${svc_name} | String | Custom header of the Service associated with an ingress. ${svc_name} is the Service name. Format: a JSON string, for example, {"key": "test", "values": ["value1", "value2"]}
| v1.23.16-r0, v1.25.11-r0, v1.27.8-r0, v1.28.6-r0, v1.29.2-r0, or later |
Configuring Cross-Origin Access
For details about applications and use cases, see Configuring Cross-Origin Access for LoadBalancer Ingresses.
| kubernetes.io/elb.cors-allow-origin | Array[string] | Specify Access-Control-Allow-Origin for the origin that can be accessed. Options:
| v1.23.18-r10, v1.25.16-r0, v1.27.16-r0, v1.28.13-r0, v1.29.8-r0, v1.30.4-r0, or later |
| kubernetes.io/elb.cors-allow-headers | Array[string] | Specify Access-Control-Allow-Headers for allowed request headers. You can enter multiple values by separating them with commas (,). | |
| kubernetes.io/elb.cors-expose-headers | Array[string] | Specify Access-Control-Expose-Headers for custom response headers that can be accessed by a cross-origin request. This allows you to retrieve non-standard response headers using client-side JavaScript code. You can enter multiple values by separating them with commas (,). | |
| kubernetes.io/elb.cors-allow-methods | Array[string] | Specify Access-Control-Allow-Methods for allowed HTTP request methods. You can enter multiple values by separating them with commas (,). | |
| kubernetes.io/elb.cors-allow-credentials | String | Specify Access-Control-Allow-Credentials to control the sending of credentials (such as cookies). Options:
Once configured, the settings cannot be deleted. To remove the configuration, use kubernetes.io/elb.cors-disabled to delete all cross-origin settings. | |
| kubernetes.io/elb.cors-max-age | String | Specify Access-Control-Max-Age for the cache duration of a CORS pre-check request. Unit: second. Value range: -1 to 172800 Properly configure this parameter based on service requirements. If the value is too low, pre-check requests may happen frequently. If the value is too high, the CORS policy may not take effect immediately. | |
| kubernetes.io/elb.cors-disabled | String | Specify whether to disable all cross-origin settings. Options:
Configuring Advanced Forwarding Rules
For details about applications and use cases, see Configuring an Advanced Forwarding Policy for a LoadBalancer Ingress.
| kubernetes.io/elb.conditions.${svc_name} | String | Configure advanced forwarding rules. ${svc_name} indicates the Service name, which can contain a maximum of 51 characters. If the annotation value is set to [], the advanced forwarding rule will be deleted. The annotation value is a JSON array. For details, see Table 4. NOTICE:
Configuring Advanced Forwarding Actions
| kubernetes.io/elb.actions.${svc_name} | String | Advanced forwarding action of the Service associated with an ingress. ${svc_name} indicates the Service name, which can contain a maximum of 51 characters. The annotation value is a JSON array. If it is set to [], the advanced forwarding action will be deleted. The following advanced forwarding actions are supported: | The forwarding actions supported by clusters vary depending on the cluster version. For details, see Table 2. |
Parameters for Automatically Creating a Load Balancer
| Parameter | Mandatory | Type | Description |
| name | No | String | Name of the automatically created load balancer. The value can contain 1 to 64 characters. Only letters, digits, underscores (_), hyphens (-), and periods (.) are allowed. Default: cce-lb+service.UID |
| type | No | String | Network type of the load balancer.
Default: inner |
| bandwidth_name | Yes for public network load balancers | String | Bandwidth name. The default value is cce-bandwidth-******. The value can contain 1 to 64 characters. Only letters, digits, underscores (_), hyphens (-), and periods (.) are allowed. |
| bandwidth_chargemode | Yes for public network load balancers | String | Bandwidth billing mode.
| bandwidth_size | Yes for public network load balancers | Integer | Bandwidth size. The value ranges from 1 Mbit/s to 2000 Mbit/s by default. Configure this parameter based on the bandwidth range allowed in your region. The minimum increment for bandwidth adjustment varies depending on the bandwidth range.
| bandwidth_sharetype | Yes for public network load balancers | String | Bandwidth sharing mode.
| eip_type | Yes for public network load balancers | String | EIP type.
The types vary by region. For details, see the EIP console. |
| vip_subnet_cidr_id | No | String | The ID of the IPv4 subnet where the load balancer resides. This subnet is used to allocate IP addresses for the load balancer to provide external services. The IPv4 subnet must belong to the cluster's VPC. If this parameter is not specified, the load balancer and the cluster will be in the same subnet by default. This field can be specified only for clusters v1.21 or later. How to obtain: Log in to the VPC console. In the navigation pane, choose Subnets. Filter the target subnet by the cluster's VPC name, click the subnet name, and copy the IPv4 Subnet ID on the Summary tab. |
| ipv6_vip_virsubnet_id | No | String | The ID of the IPv6 subnet where the load balancer is deployed. IPv6 must be enabled for the subnet. This parameter is available only for dedicated load balancers. How to obtain: Log in to the VPC console. In the navigation pane, choose Subnets. Filter the target subnet by the cluster's VPC name, click the subnet name, and copy the Network ID on the Summary tab. |
| elb_virsubnet_ids | No | Array of strings | The network ID of the subnet where the load balancer is located. This subnet is used to allocate IP addresses for accessing the backend server. If this parameter is not specified, the subnet specified by vip_subnet_cidr_id will be used by default. Load balancers occupy varying numbers of subnet IP addresses based on their specifications. Do not use the subnet CIDR blocks of other resources (such as clusters or nodes) as the load balancer's CIDR block. This parameter is available only for dedicated load balancers. Example: "elb_virsubnet_ids": [ "14567f27-8ae4-42b8-ae47-9f847a4690dd" ] How to obtain: Log in to the VPC console. In the navigation pane, choose Subnets. Filter the target subnet by the cluster's VPC name, click the subnet name, and copy the Network ID on the Summary tab. |
| vip_address | No | String | Private IP address of the load balancer. Only IPv4 addresses are supported. The IP address must be in the ELB CIDR block. If this parameter is not specified, an IP address will be automatically assigned from the ELB CIDR block. This parameter is only available in clusters v1.23.11-r0, v1.25.6-r0, v1.27.3-r0, or later versions. |
| available_zone | Yes | Array of strings | AZ where the load balancer is located. You can obtain all supported AZs by getting the AZ list. This parameter is available only for dedicated load balancers. |
| l4_flavor_name | No | String | Flavor name of the Layer 4 load balancer. This parameter is mandatory when TCP, TLS, or UDP is used. You can obtain all supported types by getting the flavor list. This parameter is available only for dedicated load balancers. |
| l7_flavor_name | No | String | Flavor name of the Layer 7 load balancer. This parameter is mandatory when HTTP or HTTPS is used. You can obtain all supported types by getting the flavor list. This parameter is available only for dedicated load balancers. Its value must match that of l4_flavor_name, both of which must be either elastic or fixed. |
