Help Center/ Object Storage Service/ User Guide/ Data Management/ Data Replication/ Cross-Account, Cross-Region Replication Using OBS
Updated on 2026-11-24 GMT+08:00
Cross-account, cross-region replication is currently available only in some regions (for example, CN North-Beijing4). Refer to the console for the latest support status.
Cross-region replication across accounts is to replicate data from a source bucket in one region of an account to a destination bucket in a different region of another account.
  • Replicating data from bucket A in region A under account A to bucket B in region B under account B
  • Replicating data uploaded by account B from bucket A in region A under account A to bucket B in region B under account A
This section describes how to replicate data between buckets across different accounts and regions using OBS Console, OBS APIs, or obsutil.
Replication scope: files/folders, object lists, objects matching a specified prefix, and objects modified after a specified time
Replication content: object content, metadata (object name, size, last modification time, creator, version ID, and user-defined metadata), ACL, and storage class
You can use cross-region replication across accounts to meet the following requirements:
  • Compliance requirements
    OBS stores data across geographically distant AZs by default, but some compliance standards may require even greater separation. In such cases, you can use cross-region replication to meet compliance requirements.
  • Low latency
    The same OBS resources may need to be accessed from different locations. To minimize the access latency, you can use cross-region replication to create object copies in the nearest region.
  • Data replication
    You want to migrate data stored in OBS to the data center in another region.
  • Data backup and disaster recovery
    For security and availability purposes, you want to create explicit backups for all data written to OBS in the data center of another region to ensure data remains available if there is any damage.
  • Easy maintenance
    If you have compute clusters in two different OBS regions that need to analyze the same set of objects, you can maintain object replicas in both regions.
OBS helps you replicate your service data stored in OBS to a specified region. However, Huawei Cloud does not have visibility into your data and is not responsible for ensuring the legal compliance of your use of OBS. If your replication involves cross-border transfer, ensure that your use complies with relevant laws and regulations.
Table 1 Constraints on cross-account, cross-region replication
Category
Bucket version
Only buckets with version 3.0 or later support cross-region replication.
You can view the version of a bucket in the Basic Information area on the bucket's Overview page of OBS Console. For details, see Viewing Bucket Information.
Functions
  • Objects in the Archive or Deep Archive storage class cannot be replicated.
  • If the destination bucket's region does not support storage classes, all replicated objects are stored in the Standard storage class.
  • OBS supports replication only between one source bucket and one destination bucket. Replication from a single source bucket to multiple destination buckets is not supported. You can change the destination bucket, but doing so updates the destination bucket for all existing rules.
  • Cross-region replication does not replicate appendable objects.
  • A source bucket can have either a single cross-region replication rule that applies to all objects in the bucket, or up to 100 rules that apply to objects with specified prefixes.
  • Objects encrypted with SSE-C cannot be replicated across regions.
  • Bucket keys are not supported.
  • Objects encrypted with SSE-KMS cannot be replicated across regions and accounts.
Time
Cross-region replication is not real-time. After you configure a replication rule, objects may not be replicated immediately. Please wait patiently.
Regions
  • The source and destination buckets must be in two different regions.
  • The source and destination regions support replication with each other. Figure 2 lists the supported regions. "√" indicates that data can be replicated between regions. "x" indicates that data cannot be replicated between regions.
Synchronization of existing objects
  • By default, objects uploaded before cross-region replication is enabled are not replicated to the destination bucket unless the function for synchronizing existing objects is enabled.
  • Modifying cross-region replication settings may prevent existing objects from being replicated, so avoid making changes until the synchronization of existing objects is complete.
  • If a replicated object is deleted from the destination bucket and you configure the source-to-destination replication rule again, with replication of existing objects enabled, within three days of the deletion, the same version of that object is not replicated again.
    For example, you first configure cross-region replication rule 1 to replicate the current version of object test.txt from the source bucket to the destination bucket. Later, you delete test.txt from the destination bucket and delete rule 1. Two days later, you create a cross-region replication rule 2 that allows replication of existing objects. In this case, test.txt will not be replicated to the destination bucket again.
  • Changes to cross-account, cross-region replication settings do not apply to previously uploaded or already replicated objects.
Versioning
  • The source and destination buckets must have the same versioning status (enabled or disabled). If you change the versioning status after cross-region replication has been configured, any updates made when the source and destination buckets have inconsistent versioning statuses cannot be replicated. After versioning is enabled, it can only be suspended and cannot be disabled. Therefore, exercise caution when changing the versioning status while using replication rules.
  • If versioning is enabled or suspended for both the source and destination buckets and the cross-region replication rule is enabled, deleting an object in the source bucket without specifying its version will also delete the object in the destination bucket.
  • If you change the versioning status of the destination bucket while cross-region replication is enabled, object replication will fail. To change the versioning status of the source bucket, delete the replication configuration first and then make the change.
Access control
  • Bucket owners must have the read and write permissions for both source and destination buckets for successful replication. If the read/write permissions of the source or destination bucket are incorrect and the system cannot read source objects or write to the destination bucket, the affected objects will fail to replicate. Even after the permissions are corrected, these objects will not be replicated again.
  • Do not delete or overwrite object replicas in the destination bucket, or modify their ACLs. Doing so may cause inconsistencies in the latest object versions or permission settings between the source and destination buckets.
  • To replicate objects from the source bucket to the destination bucket, first configure a bucket policy on the destination bucket to grant the source bucket owner all permissions except DeleteBucket, PutBucketPolicy, and PutBucketAcl. For details about permission configuration, see Creating a Custom Bucket Policy (Visual Editor).
  • If the source bucket contains objects uploaded by users other than the source bucket owner, you must configure the bucket ACL on the source bucket to grant the source bucket owner the FULL_CONTROL permission and specify the object read permission (set Delivered to true in the API). Only then can objects uploaded by other accounts be replicated to the destination bucket. To achieve this, you can edit the ACL of the source bucket owner.
  • If you want to replicate the ACL of the source object to the destination bucket when replicating the source object content, you must first configure the bucket ACL on the destination bucket to grant the source bucket owner the FULL_CONTROL permission and specify the object read permission (set Delivered to true in the API).
    For details about how to configure a bucket ACL, see Configuring a Bucket ACL. For details about the FULL_CONTROL permission, see Customizing an ACL.
Tags
A cross-region replication rule does not replicate tags applied to the source bucket and objects to the destination bucket.
  • Objects in a source bucket can be replicated to only one destination bucket, and cannot be replicated further from that destination bucket to another bucket. For example, bucket A and bucket B are in two different regions. You can replicate data from bucket A to bucket B or vice versa. However, replicas in either bucket cannot be replicated again.
  • If BlockPublicAcls is enabled for the destination bucket but the ACLs of objects in the source bucket allow public access, cross-region replication will fail due to ACL conflicts.
Billing for Cross-Region Replication Across Accounts
  • When you use OBS Console, APIs, or obsutil to replicate data across regions, you will be billed for requests, traffic, and storage. For details, see Table 2.
    Table 2 Billing for cross-region replication
    Action
    Billing Item
    Billing Mode
    Replicate data across regions
    Requests
    You are billed for the number of successfully replicated objects. Successfully replicating one object creates a copy request. For details, see Copying Objects.
    • For non-multipart objects, replicating an object creates a GET request to the source bucket and a PUT request to the destination bucket; deleting an object from the source bucket creates a DELETE request to the destination bucket.
    • For multipart objects, replicating each part creates a GET request to the source bucket and a PUT request to the destination bucket.
    • Modifying a replicated source object's ACL automatically synchronizes the change to the destination object.
      Because the source bucket initiates this ACL replication, it incurs the resulting PUT request charges.
    For details about request billing, see Requests.
    Pay-per-use
    Data transfer
    Traffic generated when you replicate data from the source bucket to the destination bucket in another region. Billing only applies to the data transferred out of the source bucket.
    If objects are encrypted using server-side encryption, the cost of their cross-region replication traffic is calculated based on the length of the plaintext for SSE-KMS and SSE-OBS.
    Cross-account, cross-region replication does not support SSE-KMS-encrypted objects.
    Pay-per-use
    Storage space
    Space occupied by the replicated objects in the destination bucket
    If you have specified another storage class for object copies in the destination bucket, these copies are billed based on the new storage class.
    If objects are encrypted using server-side encryption, their storage cost is calculated based on the length of the ciphertext.
    Pay-per-use
    Resource packages
    Synchronize existing objects
    Requests
    You are billed for the number of existing objects that are successfully replicated to the destination bucket.
    Billing applies to the number of objects that are successfully replicated. You are also billed for listing the existing objects.
    Pay-per-use
    Data transfer
    Traffic generated when OBS replicates existing objects to the destination bucket in another region. Billing only applies to the data transferred out of the source bucket.
    If historical objects are encrypted using server-side encryption, the cost of their cross-region replication traffic is calculated based on the length of the plaintext for SSE-KMS and SSE-OBS.
    Pay-per-use
    Storage space
    If historical objects are encrypted using server-side encryption, their storage cost is calculated based on the length of the ciphertext.
    Pay-per-use
    Resource packages
  • There is a source bucket in a region of an account.
  • There is a destination bucket in a different region of another account. To create a bucket, see Creating a Bucket.
  • When you use OBS Console, APIs, or obsutil to replicate objects across accounts and regions, the source bucket must be version 3.0 or later, and its region must support cross-region, cross-account replication.
