Help Center/ Object Storage Service/ User Guide/ Data Management/ Data Replication/ Same-Region Replication Within an Account Using OMS
Updated on 2026-11-02 GMT+08:00
Same-region replication within an account is to replicate data from a source bucket to a destination bucket within the same region of an account.
This section describes how to replicate data between buckets within the same region of an account using the OMS console, OMS APIs, OBS APIs, OBS SDKs, OBS Browser+, or obsutil.
Replication scope: files/folders, object lists, objects matching a specified prefix, and objects modified after a specified time
Replication content: object content, metadata (object name, size, last modification time, creator, version number, and user-defined metadata), ACLs (supported by OBS APIs and obsutil), object tags (supported by OBS APIs), and storage class
Figure 1 Same-region replication within an account
OBS helps you replicate your service data stored in OBS to another bucket in the same region. However, Huawei Cloud does not have visibility into your data and is not responsible for ensuring the legal compliance of your use of OBS.
Billing for Same-Region Replication Within an Account
  • When you use the OMS console or APIs to migrate data, OBS APIs of both the source and destination ends are invoked to handle data upload and download. You will be billed for the API requests and data download traffic. For details, see OMS Billing. In addition, you will be billed for storing the objects in the destination bucket. For details, see Storage Costs.
  • When you use OBS APIs, OBS SDKs, OBS Browser+, or obsutil to replicate data within the same region, you will be billed for requests and storage. For details, see Table 1.
    Table 1 Billing for same-region replication
    Action
    Billing Item
    Billing Mode
    Replicate data in the same region
    Requests
    You are billed for the number of successfully replicated objects. Successfully replicating one object creates a copy request. For details, see Copying Objects.
    Replicating an object generates a GET request to the source bucket and a PUT request to the destination bucket.
    For details about request billing, see Requests.
    Pay-per-use
    Data transfer
    Free, because data in the same region is replicated over an intranet.
    N/A
    Storage space
    Storage space occupied by objects stored in the destination bucket.
    If you have specified another storage class for object copies in the destination bucket, these copies are billed based on the new storage class.
    Pay-per-use
    Resource packages
  • There is a source bucket in a region of an account.
  • There is a destination bucket in the same region of the same account. To create a bucket, see Creating a Bucket.
You can use the OMS console or APIs to migrate data within the same account and region or use OBS APIs, SDKs, or obsutil to replicate data within the same account and region.
