Updated on 2025-09-30 GMT+08:00
Connecting DLI to LakeFormation
LakeFormation is an enterprise-level, all-in-one lakehouse construction service that provides unified metadata management capabilities. It supports seamless integration with various compute engines and big data cloud services, enabling you to efficiently build data lakes and operate related businesses, thereby accelerating the extraction of business data value.
In Spark and SQL job scenarios, LakeFormation can be connected to achieve unified metadata management. This section will guide you through the steps to configure the data connection between DLI and LakeFormation.
For the Spark syntax of LakeFormation, see Spark Syntax Reference.
For the Flink syntax of LakeFormation, see Flink Syntax Reference.
Notes
To use this function, which is currently in the limited use phase, submit a request by choosing Service Tickets > Create Service Ticket in the upper right corner of the management console.
Connecting DLI to LakeFormation depends on the availability of the LakeFormation service. To understand the availability scope of LakeFormation, refer to Global Products and Services.
Figure 1 Procedure
Notes and Constraints
  • Table 1 lists the DLI queue and engine types that allow you to connect DLI to LakeFormation to obtain metadata.
    For the engine type and version of a queue, see Viewing Basic Information About a Queue.
    Table 1 Queue and engine types that allow for the connection of DLI to LakeFormation for metadata retrieval
    Queue Type
    Engine Type and Version
    default queue
    • Spark 3.3.x: can connect to LakeFormation to obtain metadata.
    • HetuEngine 2.2.0: can connect to LakeFormation to obtain metadata.
    For SQL
    For general purpose
    Flink job scenario: Flink 1.15 or later supports integration with LakeFormation to obtain metadata when using queues within an elastic resource pool.
  • DLI can only connect to the default LakeFormation instance. Set the instance in LakeFormation as the default to ensure successful connection.
  • DLI can read data in Avro, JSON, Parquet, CSV, ORC, Text, and Hudi formats from LakeFormation.
  • LakeFormation manages the permissions for databases and tables in the data catalog of LakeFormation.
  • After connecting DLI to LakeFormation, the original databases and tables in DLI will be moved to the data directory of DLI.
Step 1: Create a LakeFormation Instance for Metadata Storage
LakeFormation instances provide basic resources for metadata management. DLI can only connect to the default LakeFormation instance.
  1. Creating an instance
    1. Log in to the LakeFormation management console.
    2. Click Buy Now or Buy Instance in the upper right corner of the page.
      If there are no instances available on the page, Buy Now is displayed. If there are any LakeFormation instances on the page, Buy Instance is displayed.
    3. Set LakeFormation instance parameters as needed to complete instance creation.
      In this example, we create a pay-per-use shared instance.
      For parameter settings and descriptions, see Creating a LakeFormation Instance.
  2. Setting a LakeFormation instance as the default
    1. View the value of Default Instance in the Basic Information area.
      • true: The instance is the default.
      • false: The instance is not the default.
    2. To set an instance as the default, click Set as Default in the upper right corner of the page.
    3. In the dialog box that appears, select I understand the consequences of changing the default instance and have still decided to perform this operation. and click OK.
      DLI can currently only connect to the default LakeFormation instance. Changing an instance to the default may impact the services that use LakeFormation. Exercise caution when performing this operation.
Step 2: Create a Catalog on the LakeFormation Management Console
A data catalog is a metadata management object that can contain multiple databases. You can create and manage multiple catalogs in LakeFormation to isolate metadata of different external clusters.
  2. In the navigation pane on the left, choose Metadata > Catalog.
  3. On the displayed page, click Create.
    Set catalog instance parameters as needed.
    For parameter settings and descriptions, see Creating a Catalog.
  4. Once created, you can view information about the created catalog on the Catalog page.
Step 3: Create a Data Catalog on the DLI Management Console
On the DLI management console, you need to create a link to the catalog to access the catalog stored in the LakeFormation instance.
  • You can only create one mapping for each data catalog in LakeFormation.
    For example, a user creates a mapping named catalogMapping1 in DLI, which corresponds to the data catalog catalogA in LakeFormation. Once created, you cannot create a mapping to catalogA in the same project space.
  1. Log in to the DLI management console.
  2. In the navigation pane on the left, choose SQL Editor.
  3. On the SQL editor page, select a data catalog under Catalog.
  4. Click to create a data catalog.
  5. In the Create Catalog dialog box, set data catalog parameters.
    Table 2 Data catalog parameters
    Mandatory
    External Catalog Name
    Yes
    Catalog name of the default LakeFormation instance.
    Type
    Yes
    Currently, the only available option is LakeFormation.
    This option is fixed and does not need to be selected.
    Catalog Name
    Yes
    Catalog mapping name used in DLI. When running SQL statements, you need to specify the catalog mapping to identify the external metadata to be accessed. You are advised to set this parameter to the same value as External Catalog Name.
    Currently, DLI can only connect to the data catalog of the default LakeFormation instance.
    No
    Description of the data catalog.
  6. Click OK.
Step 4: Authorize to Use LakeFormation Resources
  • SQL job scenarios
    Before submitting a SQL job, you need to authorize DLI to access LakeFormation resources such as metadata, databases, tables, columns, and functions, to ensure that the job can access required data and resources during execution. Supported Actions for LakeFormation SQL Resources describes LakeFormation resources and corresponding permissions.
    To use LakeFormation resources, you need to separately complete IAM fine-grained authorization and LakeFormation SQL resource authorization.
    • IAM fine-grained authorization for LakeFormation: Authorize DLI to use LakeFormation APIs.
      IAM offers multiple methods to manage the permissions of users, groups, and roles to access resources. You can create policies on the IAM console to define which users or roles can call LakeFormation APIs. Then, attach these policies to the specified users or roles.
      • Method 1: Role-based authorization
        A coarse-grained authorization strategy that defines permissions by job responsibility. This strategy offers limited service-level roles for authorization.
        For example, grant users the read-only permission to query LakeFormation metadata resources by referring to LakeFormation Permissions Management.
        Alternatively, grant all operation permissions on LakeFormation-related metadata resources.
        Example:
            "Version": "1.1",
            "Statement": [
                    "Effect": "Allow",
                    "Action": [
                        "lakeformation:table:*",
                        "lakeformation:database:*",
                        "lakeformation:catalog:*",
                        "lakeformation:function:*",
                        "lakeformation:transaction:*",
                        "lakeformation:policy:describe",
                        "lakeformation:credential:describe"
      • Method 2: Policy-based fine-grained authorization
        A fine-grained authorization strategy that defines the permissions required to perform actions on a specific cloud resource under certain conditions.
        For LakeFormation permissions policies, see LakeFormation Permissions and Supported Actions.
        For how to grant permissions, see Creating a User and Granting LakeFormation Permissions.
    • LakeFormation SQL resource authorization: authorizes users to use specific LakeFormation resources (such as metadata, databases, tables, columns, and functions).
      Users are allowed to access specific resources. This controls access to LakeFormation data and metadata.
      Two methods:
      • Method 1: Authorize access to resources on the LakeFormation management console.
        For LakeFormation SQL resource permissions, see Data Permissions.
      • Method 2: Run the GRANT SQL statement on the DLI management console.
        The GRANT statement is used for authorization in SQL.
        You can run the GRANT statement to grant users or roles the permission to access databases, tables, columns, and functions.
        Supported Actions for LakeFormation SQL Resources describes authorization policies for LakeFormation resources.
        Currently, you cannot authorize access to catalogs by running the GRANT statement on the DLI console. To authorize access, use method 1.
  • Spark Jar, Flink OpenSource SQL, and Flink Jar job scenarios:
    • Method 1: Use agency authorization. Before using Spark 3.3.1 or later and Flink 1.15 to run jobs, you need to create an agency on the IAM console and add the new agency information when configuring the job.
      For agency permission examples, see Creating a Custom DLI Agency and Agency Permission Policies in Common Scenarios.
    • Method 2: Use DEW for authorization.
      • You have granted the IAM user the IAM and LakeFormation permissions. For details, see IAM authorization in SQL job scenarios.
      • A shared secret has been created on the DEW console and the secret value has been stored. For details, see Creating a Shared Secret.
      • An agency has been created and authorized for DLI to access DEW. The agency must have been granted the following permissions:
        • Permission of the ShowSecretVersion interface for querying secret versions and secret values in DEW: csms:secretVersion:get.
        • Permission of the ListSecretVersions interface for listing secret versions in DEW: csms:secretVersion:list.
        • Permission to decrypt DEW secrets: kms:dek:decrypt
Step 5: Use LakeFormation Metadata During DLI Job Development
After connecting DLI to the default LakeFormation instance and authorizing access to LakeFormation resources, you can use LakeFormation metadata during DLI job development.
  • DLI SQL:
    For the SQL syntax of LakeFormation, see Data Lake Insight Spark SQL Syntax Reference.
    When running a SQL job, you can select the catalog where the SQL statement is located on the console, as shown in Figure 2, or specify catalogName in the SQL statement. catalogName is the mapping name of the data catalog on the DLI console.
    Figure 2 Selecting a data catalog on the SQL editor page
    • When connecting DLI to a LakeFormation instance, you need to specify the OBS path for storing the database when creating it.
    • When connecting DLI to a LakeFormation instance, you cannot set table lifecycle and versioning when creating a table.
    • When connecting DLI to a LakeFormation instance, the LOAD DATA statement does not support datasource tables, and partitions must be specified if the statement is used to import data into a partitioned table.
    • If the databases and tables created on the LakeFormation console contain Chinese characters, operations on them cannot be performed on DLI.
    • When connecting DLI to a LakeFormation instance, you cannot specify filter criteria to delete partitions.
    • When connecting DLI to a LakeFormation instance, you cannot create Truncate Datasource or Hive foreign tables.
    • DLI does not currently support the use of LakeFormation row filter criteria.
    • When DLI reads binary data for console display, it converts the binary data to Base64.
    • DLI does not currently support authorizing access to LakeFormation paths.
  • DLI Spark Jar:
    This part explains how to configure LakeFormation metadata when submitting a Spark Jar job on the DLI management console.
    • Example Spark Jar
      SparkSession spark = SparkSession.builder()
          .enableHiveSupport()
          .appName("java_spark_demo")
          .getOrCreate();
      spark.sql("show databases").show();
    • Configuring a Spark Jar job on the DLI management console
      • (Recommended) Method 1: Configure a Spark Jar job's access to LakeFormation metadata using the parameters (such as agency and metadata source) provided on the console
        When creating or editing a Spark Jar job, refer to Table 3 to configure the job's access to LakeFormation metadata.
        Table 3 Configuring a Spark Jar job's access to LakeFormation metadata
        Example Value
        Spark Version
        Spark 3.3.x or later can connect to LakeFormation.
        3.3.1
        Agency
        Before using Spark 3.3.1 or later to run jobs, you need to create an agency on the IAM console and add the new agency information. Once set, the system automatically adds the following agency configuration to your job:
        spark.dli.job.agency.name=agency
        Access Metadata
        Whether to allow the Spark job to access metadata.
        Yes
        Metadata Source
        Type of metadata the Spark job accesses. In this scenario, select lakeformation.
        Once set to lakeformation, the system automatically adds the following configurations to your job to load LakeFormation dependencies.
        spark.sql.catalogImplementation=hive
        spark.hadoop.hive-ext.dlcatalog.metastore.client.enable=true
        spark.hadoop.hive-ext.dlcatalog.metastore.session.client.class=com.huawei.cloud.dalf.lakecat.client.hiveclient.LakeCatMetaStoreClient
        og
        // Load LakeFormation dependencies.
        spark.driver.extraClassPath=/usr/share/extension/dli/spark-jar/lakeformation/*
        spark.executor.extraClassPath=/usr/share/extension/dli/spark-jar/lakeformation/*
        You can also set the metadata source in the Spark Arguments(--conf) parameter. This means if you set the metadata source in both Metadata Source and Spark Arguments(--conf), the system preferentially uses the information configured in Spark Arguments(--conf).
        You are advised to set the metadata source through Metadata Source.
        LakeFormation
        Catalog Name
        Name of the data catalog the Spark job accesses.
        The data catalog created on the DLI management console is selected, that is, the mapping between DLI and the data catalog of the default LakeFormation instance. This data catalog is connected to the data catalog of the default LakeFormation instance. To specify other LakeFormation instances, configure the LakeFormation instances and data catalogs to be connected in Spark Arguments(--conf). For details, see Method 2: Configure a Spark Jar job's access to LakeFormation metadata using the Spark Arguments(--conf) parameter.
        Once set to LakeFormation, the system automatically adds the following configuration to your job to connect to the data catalog of the default LakeFormation instance:
        spark.hadoop.lakecat.catalogname.default=lfcatalog
        You can also set the data catalog name in the Spark Arguments(--conf) parameter. This means if you set the data catalog name in both Catalog Name and Spark Arguments(--conf), the system preferentially uses the information configured in Spark Arguments(--conf).
        You are advised to set the data catalog name through Catalog Name.
        You can also set the metadata source and data catalog name in the Spark Arguments(--conf) parameter. This means if you set the metadata source and data catalog name in both Metadata Source and Catalog Name, as well as Spark Arguments(--conf), the system preferentially uses the information configured in Spark Arguments(--conf).
        • To access a Hudi data table, add the following configurations to the Spark Arguments(--conf) parameter:
          spark.sql.extensions=org.apache.spark.sql.hudi.HoodieSparkSessionExtension
          spark.hadoop.hoodie.write.lock.provider=org.apache.hudi.lakeformation.LakeCatMetastoreBasedLockProvider
        • To access a Delta data table, add the following configurations to the Spark Arguments(--conf) parameter:
          spark.sql.catalog.spark_catalog=org.apache.spark.sql.delta.catalog.DeltaCatalog spark.sql.extensions=io.delta.sql.DeltaSparkSessionExtension
      • Method 2: Configure a Spark Jar job's access to LakeFormation metadata using the Spark Arguments(--conf) parameter
        When creating or editing a Spark Jar job, configure the following information in the Spark Arguments(--conf) parameter on the job configuration page to access LakeFormation metadata:
        spark.sql.extensions=org.apache.spark.sql.hudi.HoodieSparkSessionExtension // Hudi is supported, which is optional.
        spark.hadoop.hoodie.write.lock.provider=org.apache.hudi.lakeformation.LakeCatMetastoreBasedLockProvider // Hudi is supported, which is optional.
        // Access using an agency with the OBS and LakeFormation permissions. You are advised to configure the minimum permission set.
        spark.dli.job.agency.name=agencyForLakeformation
        // ID of the LakeFormation instance to be accessed, which can be viewed on the LakeFormation console. This parameter is optional. If unset, the default LakeFormation instance is accessed.
        spark.hadoop.lakeformation.instance.id=xxx
        // Name of the catalog to be accessed on the LakeFormation side, which can be viewed on the LakeFormation console. This parameter is optional. If unset, the default value is hive.
  • DLI Flink OpenSource SQL
    • Example 1: Connecting DLI to LakeFormation using an agency
      Create a Flink OpenSource SQL job and set the following parameters:
      Example Value
      Flink Version
      Flink 1.15 or later can connect to LakeFormation.
      1.15
      Agency
      Before using Flink 1.15 or later to run jobs, you need to create an agency on the IAM console and add the new agency information. Once set, the system automatically adds the following agency configuration to your job:
      flink.dli.job.agency.name=agency
      Enable Checkpointing
      Select it.
      Select it.
      Runtime Configuration
      • Type of metadata the Flink job accesses.
        flink.dli.job.catalog.type=lakeformation
      • Name of the data catalog the Flink job accesses.
        flink.dli.job.catalog.name=[Catalog name in LakeFormation]
      For the catalog parameters in the example, see Table 4.
      Table 4 Catalog parameters in the example Flink OpenSource SQL
      Mandatory
      Example Value
      type
      Catalog type
      Yes
      Fixed at hive
      hive-conf-dir
      hive-conf path, which is fixed at /opt/flink/conf.
      Yes
      Fixed at /opt/flink/conf
      default-database
      Default database name
      No
      Default database
       3
       4
       5
       6
       7
       8
       9
      10
      11
      12
      13
      14
      15
      16
      17
      18
      19
      20
      21
      22
      23
      24
      25
      26
      27
      28
      29
      30
      31
      CREATE CATALOG hive
      WITH
          'type' = 'hive',
          'hive-conf-dir' = '/opt/flink/conf',  -- Fixed at /opt/flink/conf
          'default-database'='default'
      USE CATALOG hive;
      CREATE TABLE IF NOT EXISTS
        dataGenSource612 (user_id string, amount int)
      WITH
          'connector' = 'datagen',
          'rows-per-second' = '1',
          'fields.user_id.kind' = 'random',
          'fields.user_id.length' = '3'
      CREATE table IF NOT EXISTS
        printSink612 (user_id string, amount int)
      WITH
        ('connector' = 'print');
      INSERT INTO
        printSink612
      SELECT
      FROM
        dataGenSource612;
    • Example 2: Connecting DLI to LakeFormation using DEW
      Example Value
      Flink Version
      1.15
      Agency
      Select it.
      Select it.
      For the catalog parameters in the example, see Table 5.
      Set properties.catalog.lakeformation.auth.identity.util.class to com.huawei.flink.provider.lakeformation.FlinkDewIdentityGenerator and configure DEW.
      Table 5 Catalog parameters in the example Flink OpenSource SQL (using DEW)
      Mandatory
      Example Value
      type
      Catalog type
      Yes
      Fixed at hive
      hive-conf-dir
      Yes
      default-database
      No
      If unset, the default database is used.
      properties.catalog.lakecat.auth.identity.util.class
      Authentication information acquisition class
      Yes
      Mandatory when DEW is used, which is fixed at com.huawei.flink.provider.lakeformation.FlinkDewIdentityGenerator.
      properties.catalog.dew.projectId
      ID of the project DEW belongs to. The default value is the ID of the project where the Flink job is.
      Yes
      properties.catalog.dew.endpoint
      Endpoint of the DEW service to be used.
      Yes
      Mandatory when DEW is used.
      Example: kms.xxx.com
      properties.catalog.dew.csms.secretName
      Name of the shared secret in DEW's secret management.
      Yes
      properties.catalog.dew.csms.version
      Version number of the shared secret in DEW's secret management.
      Yes
      properties.catalog.dew.access.key
      Enter the key corresponding to the access.key value in DEW's secret.
      Yes
      properties.catalog.dew.secret.key
      Enter the key corresponding to the secret.key value in DEW's secret.
      Yes
       3
       4
       5
       6
       7
       8
       9
      10
      11
      12
      13
      14
      15
      16
      17
      18
      19
      20
      21
      22
      23
      24
      25
      26
      27
      28
      29
      30
      31
      32
      33
      34
      35
      36
      CREATE CATALOG myhive
      WITH
          'type' = 'hive',
          'default-database'='default',
          -- The following is the DEW configuration. Change the parameter values based on site requirements.
          'properties.catalog.lakeformation.auth.identity.util.class' = 'com.huawei.flink.provider.lakeformation.FlinkDewIdentityGenerator',
          'properties.catalog.dew.endpoint'='kms.xxx.com',
          'properties.catalog.dew.csms.secretName'='obsAksK',
          'properties.catalog.dew.access.key' = 'myak',
          'properties.catalog.dew.secret.key' = 'mysk',
          'properties.catalog.dew.projectId'='330e068af1334c9782f4226xxxxxxxxx',
          'properties.catalog.dew.csms.version'='v9'
      USE CATALOG myhive;
      create table IF NOT EXISTS dataGenSource_dew612(
        user_id string,
        amount int
      ) with (
      create table IF NOT EXISTS printSink_dew612(
        user_id string,
        amount int
      ) with (
      insert into printSink_dew612 select * from dataGenSource_dew612;
    • Example 3: Connecting DLI to LakeFormation using an agency to write data to a Hudi table
      Example Value
      Flink Version
      1.15
      Agency
      Select it.
      Select it.
      For the catalog parameters in the example, see Table 6.
      Table 6 Parameters for configuring a catalog of the Hudi type
      Mandatory
      Example Value
      type
      Catalog type
      Yes
      hudi for a Hudi table
      hive-conf-dir
      Yes
      default-database
      No
      Default database
      mode
      The value can be 'hms' or 'non-hms'.
      • hms indicates that the created Hudi catalog uses Hive Metastore to store metadata.
      • non-hms indicates that Hive Metastore is not used to store metadata.
      Yes
      Fixed at hms
      Table 7 Connector parameters for a Hudi sink table
      Mandatory
      Example Value
      connector
      Flink connector type
      If set to hudi, the sink table is a Hudi table.
      Yes
      hudi
      path
      Basic path of the table. If the path does not exist, the system will create it.
      Yes
      Refer to the values configured in the sample code.
      hoodie.datasource.write.recordkey.field
      Unique key field name of the Hoodie table
      No
      Set order_id to a unique key.
      EXTERNAL
      Whether the table is foreign
      Yes
      Mandatory for the Hudi table and must be set to true.
      true
      CREATE CATALOG hive_catalog
        WITH (
          'type'='hive',
          'default-database'='test'
      USE CATALOG hive_catalog;
      create table  if not exists genSource618 (
        order_id STRING,
        order_name STRING,
        price INT,
        weight INT
      ) with (
        'fields.order_id.kind' = 'random',
        'fields.order_id.length' = '8',
        'fields.order_name.kind' = 'random',
        'fields.order_name.length' = '5'
      CREATE CATALOG hoodie_catalog
        WITH (
          'type'='hudi',
          'hive.conf.dir' = '/opt/flink/conf',
          'mode'='hms' -- supports 'dfs' mode that uses the DFS backend for table DDLs persistence
      CREATE TABLE  if not exists  hoodie_catalog.`test`.`hudiSink618` (
        `order_id` STRING PRIMARY KEY NOT ENFORCED,
        `order_name` STRING,
        `price` INT,
        `weight` INT,
        `create_time` BIGINT,
        `create_date` String
      ) PARTITIONED BY (create_date) WITH (
        'connector' = 'hudi',
        'path' = 'obs://xxx/catalog/dbtest3/hudiSink618',
        'hoodie.datasource.write.recordkey.field' = 'order_id',
        'write.precombine.field' = 'create_time',
        'EXTERNAL' = 'true' -- must be set
      insert into hoodie_catalog.`test`.`hudiSink618`
      select
        order_id,
        order_name,
        price,
        weight,
        UNIX_TIMESTAMP() as create_time,
        FROM_UNIXTIME(UNIX_TIMESTAMP(), 'yyyyMMdd') as create_date
      from genSource618;
  • DLI Flink Jar
      1. Develop a Flink Jar program, compile and upload the JAR file to OBS. In this example, the file is uploaded to the obs://obs-test/dlitest/ directory.
        The sample code is as follows:
        In this example, random data is generated using the DataGen table and then output to the Print result table.
        For other connector types, see List of Connectors Supported by Flink 1.15.
         3
         4
         5
         6
         7
         8
         9
        10
        11
        12
        13
        14
        15
        16
        17
        18
        19
        20
        21
        22
        23
        24
        25
        26
        27
        28
        29
        30
        31
        32
        33
        34
        35
        36
        37
        38
        39
        40
        41
        42
        43
        44
        45
        46
        47
        48
        49
        50
        51
        52
        53
        54
        55
        56
        57
        58
        59
        60
        61
        62
        63
        64
        65
        66
        67
        68
        69
        70
        71
        72
        73
        package com.huawei.test;
        import org.apache.flink.api.java.utils.ParameterTool;
        import org.apache.flink.contrib.streaming.state.RocksDBStateBackend;
        import org.apache.flink.runtime.state.filesystem.FsStateBackend;
        import org.apache.flink.streaming.api.CheckpointingMode;
        import org.apache.flink.streaming.api.environment.CheckpointConfig;
        import org.apache.flink.streaming.api.environment.StreamExecutionEnvironment;
        import org.apache.flink.table.api.EnvironmentSettings;
        import org.apache.flink.table.api.bridge.java.StreamTableEnvironment;
        import org.slf4j.Logger;
        import org.slf4j.LoggerFactory;
        import java.text.SimpleDateFormat;
        @SuppressWarnings({"deprecation", "rawtypes", "unchecked"})
        public class GenToPrintTaskAgency {
            private static final Logger LOGGER = LoggerFactory.getLogger(GenToPrintTaskAgency.class);
            private static final String datePattern = "yyyy-MM-dd_HH-mm-ss";
                LOGGER.info("Start task.");
                ParameterTool paraTool = ParameterTool.fromArgs(args);
                String checkpointInterval = "180000000";
                // set up execution environment
                StreamExecutionEnvironment env = StreamExecutionEnvironment.getExecutionEnvironment();
                EnvironmentSettings settings = EnvironmentSettings.newInstance()
                        .inStreamingMode().build();
                StreamTableEnvironment tEnv = StreamTableEnvironment.create(env, settings);
                env.getCheckpointConfig().setCheckpointingMode(CheckpointingMode.EXACTLY_ONCE);
                env.getCheckpointConfig().setCheckpointInterval(Long.valueOf(checkpointInterval));
                env.getCheckpointConfig().enableExternalizedCheckpoints(
                        CheckpointConfig.ExternalizedCheckpointCleanup.RETAIN_ON_CANCELLATION);
                SimpleDateFormat dateTimeFormat = new SimpleDateFormat(datePattern);
                String time = dateTimeFormat.format(System.currentTimeMillis());
                RocksDBStateBackend rocksDbBackend =
                        new RocksDBStateBackend(
                                new FsStateBackend("obs://obs/xxx/testcheckpoint/" + time), true);
                env.setStateBackend(rocksDbBackend);
                String createCatalog = "CREATE CATALOG lf_catalog WITH (\n" +
                        "    'type' = 'hive',\n" +
                        "    'hive-conf-dir' = '/opt/hadoop/conf'\n" +
                tEnv.executeSql(createCatalog);
                String dataSource = "CREATE TABLE if not exists lf_catalog.`testdb`.`dataGenSourceJar618_1` (\n" +
                        "  user_id string,\n" +
                        "  amount int\n" +
                        ") WITH (\n" +
                        "  'connector' = 'datagen',\n" +
                        "  'rows-per-second' = '1',\n" +
                        "  'fields.user_id.kind' = 'random',\n" +
                        "  'fields.user_id.length' = '3'\n" +
        /*testdb is a custom database.*/
                tEnv.executeSql(dataSource);
                String printSink = "CREATE TABLE if not exists lf_catalog.`testdb`.`printSinkJar618_1` (\n" +
                        "  amount int\n" +
                        ") WITH ('connector' = 'print')";
                tEnv.executeSql(printSink);
                String query = "insert into lf_catalog.`test`.`printSinkJar618_1` " +
                        "select * from lf_catalog.`test`.`dataGenSourceJar618_1`";
                tEnv.executeSql(query);
      2. Create a Flink Jar job and set the following parameters:
        Example Value
        Flink Version
        1.15
        Agency
        public class GenToPrintTaskDew {
                        "    'hive-conf-dir' = '/opt/hadoop/conf',\n" +
                        "    'properties.catalog.lakeformation.auth.identity.util.class' = 'com.huawei.flink.provider.lakeformation.FlinkDewIdentityGenerator',\n" +
                        "    'properties.catalog.dew.endpoint'='kms.xxx.xxx.com',\n" +
                        "    'properties.catalog.dew.csms.secretName'='obsAksK',\n" +
                        "    'properties.catalog.dew.access.key' = 'ak',\n" +
                        "    'properties.catalog.dew.secret.key' = 'sk',\n" +
                        "    'properties.catalog.dew.projectId'='330e068af1334c9782f4226xxxxxxxxxx',\n" +
                        "    'properties.catalog.dew.csms.version'='v9'\n" +
                String dataSource = "CREATE TABLE if not exists lf_catalog.`testdb`.`dataGenSourceJarDew618_1` (\n" +
                        "  amount int\n" +
                        ") WITH (\n" +
                String printSink = "CREATE TABLE if not exists lf_catalog.`testdb`.`printSinkJarDew618_1` (\n" +
                        "  amount int\n" +
                String query = "insert into lf_catalog.`test`.`printSinkJarDew618_1` " +
                        "select * from lf_catalog.`test`.`dataGenSourceJarDew618_1`";
        Example Value
        Flink Version
        1.15
        Agency
    • Example 3: Flink Jar jobs supporting Hudi tables
        In this example, random data is generated using the DataGen table and then output to the Hudi result table.
         3
         4
         5
         6
         7
         8
         9
        10
        11
        12
        13
        14
        15
        16
        17
        18
        19
        20
        21
        22
        23
        24
        25
        26
        27
        28
        29
        30
        31
        32
        33
        34
        35
        36
        37
        38
        39
        40
        41
        42
        43
        44
        45
        46
        47
        48
        49
        50
        51
        52
        53
        54
        55
        56
        57
        58
        59
        60
        61
        62
        63
        64
        65
        66
        67
        68
        69
        70
        71
        72
        73
        74
        75
        76
        77
        78
        79
        80
        81
        82
        83
        84
        85
        86
        87
        88
        89
        90
        91
        import java.io.IOException;
        public class GenToHudiTask4 {
            private static final Logger LOGGER = LoggerFactory.getLogger(GenToHudiTask4.class);
            public static void main(String[] args) throws IOException {
                String checkpointInterval = "30000";
                                new FsStateBackend("obs://xxx/jobs/testcheckpoint/" + time), true);
                String catalog = "CREATE CATALOG hoodie_catalog\n" +
                        "  WITH (\n" +
                        "    'type'='hudi',\n" +
                        "    'hive.conf.dir' = '/opt/hadoop/conf',\n" +
                        "    'mode'='hms'\n" +
                tEnv.executeSql(catalog);
                String dwsSource = "CREATE TABLE if not exists genSourceJarForHudi618_1 (\n" +
                        "  order_id STRING,\n" +
                        "  order_name STRING,\n" +
                        "  price INT,\n" +
                        "  weight INT\n" +
                        ") WITH (\n" +
                        "  'fields.order_id.kind' = 'random',\n" +
                        "  'fields.order_id.length' = '8',\n" +
                        "  'fields.order_name.kind' = 'random',\n" +
                        "  'fields.order_name.length' = '8'\n" +
                tEnv.executeSql(dwsSource);
                String printSinkdws =
                        "CREATE TABLE if not exists hoodie_catalog.`testdb`.`hudiSinkJarHudi618_1` (\n" +
                        "  order_id STRING PRIMARY KEY NOT ENFORCED,\n" +
                        "  price INT,\n" +
                        "  weight INT,\n" +
                        "  create_time BIGINT,\n" +
                        "  create_date String\n" +
                        ") WITH (" +
                        "'connector' = 'hudi',\n" +
                        "'path' = 'obs://xxx/catalog/dbtest3/hudiSinkJarHudi618_1',\n" +
                        "'hoodie.datasource.write.recordkey.field' = 'order_id',\n" +
                        "'EXTERNAL' = 'true'\n" +
                tEnv.executeSql(printSinkdws);
                String query = "insert into hoodie_catalog.`testdb`.`hudiSinkJarHudi618_1` select\n" +
                " order_id,\n" +
                " order_name,\n" +
                " price,\n" +
                " weight,\n" +
                " UNIX_TIMESTAMP() as create_time,\n" +
                " FROM_UNIXTIME(UNIX_TIMESTAMP(), 'yyyyMMdd') as create_date\n" +
                " from genSourceJarForHudi618_1";
        Table 8 Connector parameters for a Hudi sink table
        Mandatory
        Example Value
        connector
        Yes
        hudi
        path
        Yes
        No
        EXTERNAL
        Yes
        true
        Example Value
        Flink Version
        1.15
        Agency
