Updated on 2026-09-08 GMT+08:00
Permission Policies and Supported Actions for LakeFormation Resources
Supported Actions for LakeFormation SQL Resources
For the list of actions supported by DLI for SQL resource authentication, refer to Data Permissions List.
Table 1 lists the supported actions for LakeFormation SQL resources.
Table 1 Supported actions for LakeFormation SQL resources
Resource Type
Permission Type
Database
ALL
ALTER
DROP
DESCRIBE
LIST_TABLE
LIST_FUNC
CREATE_TABLE
CREATE_FUNC
Table/View
ALL
ALTER
DROP
DESCRIBE
UPDATE
INSERT
SELECT
DELETE
Column
SELECT
Function
ALL
ALTER
DROP
DESCRIBE
EXEC
LakeFormation Permission Policies (Spark)
Table 2 LakeFormation permission policies
Type
SQL Statement
Permission to Authenticate Access to Metadata Using IAM
Permission to Authenticate Access to SQL Resources
DDL statement
ALTER DATABASE
database:describe
database:alter
database:DESCRIBE
database:ALTER
ALTER TABLE
database:describe
table:describe
table:alter
database:create
database:DESCRIBE
table:DESCRIBE
table:ALTER
database:CREATE_TABLE
column:SELECT or table:SELECT
ALTER VIEW
database:describe
table:describe
table:alter
database:DESCRIBE
table:DESCRIBE
column:SELECT
table:ALTER
CREATE DATABASE
database:describe
database:create
database:DESCRIBE
catalog:CREATE_DATABASE
CREATE OR REPLACE FUNCTION (CREATE)
database:describe
function:create
database:DESCRIBE
database:CREATE_FUNC
CREATE OR REPLACE FUNCTION (REPLACE)
database:describe
function:describe
function:alter
database:DESCRIBE
function:DESCRIBE
function:ALTER
CREATE TABLE
database:describe
table:describe
table:create
database:DESCRIBE
CREATE VIEW
database:describe
table:describe
table:drop
table:create
table:DESCRIBE (source\target)
table:DROP(target)
column:SELECT
DROP DATABASE
database:describe
database:drop
database:DESCRIBE
database:DROP
DROP FUNCTION
database:describe
function:describe
function:drop
database:DESCRIBE
function:DESCRIBE
function:DROP
DROP TABLE
database:describe
table:describe
credential:describe
table:drop
database:DESCRIBE
table:DESCRIBE
table:DROP
DROP VIEW
database:describe
table:describe
table:drop
database:DESCRIBE
table:DESCRIBE(target\source)
table:DROP(target)
REPAIR TABLE
database:describe
table:describe
credential:describe
table:alter
database:DESCRIBE
table:DESCRIBE
table:ALTER
table:SELECT
TRUNCATE TABLE
database:describe
table:describe
table:alter
database:DESCRIBE
table:DESCRIBE
table:SELECT
table:UPDATE
DML statement
INSERT TABLE
database:describe
table:describe
table:alter
credential:describe
database:DESCRIBE
table:DESCRIBE
table:ALTER
table:INSERT
LOAD DATA
database:describe
table:describe
credential:describe
database:DESCRIBE
table:DESCRIBE
table:UPDATE
table:ALTER
table:SELECT
DR statement
SELECT
database:describe
table:describe
credential:describe
database:DESCRIBE
table:DESCRIBE
column:SELECT
EXPLAIN
Depends on the SQL statement.
Auxiliary statement
ANALYZE TABLE
database:describe
table:describe
credential:describe
table:alter
database:DESCRIBE
table:DESCRIBE
table:SELECT
table:ALTER
DESCRIBE DATABASE
database:describe
database:DESCRIBE
DESCRIBE FUNCTION
database:describe
function:describe
database:DESCRIBE
function:DESCRIBE
DESCRIBE QUERY
database:describe
table:describe
database:DESCRIBE
table:DESCRIBE
table:SELECT
DESCRIBE TABLE
database:describe
table:describe
database:DESCRIBE
table:DESCRIBE
REFRESH TABLE
database:describe
table:describe
credential:describe
database:DESCRIBE
table:DESCRIBE
table:SELECT
REFRESH FUNCTION
database:describe
function:describe
database:DESCRIBE
function:DESCRIBE
SHOW COLUMNS
database:describe
table:describe
database:DESCRIBE
table:DESCRIBE
SHOW CREATE TABLE
database:describe
table:describe
database:DESCRIBE
table:DESCRIBE
SHOW DATABASES
database:describe
catalog:LIST_DATABASE
database:DESCRIBE
SHOW FUNCTIONS
database:describe
function:describe
database:DESCRIBE
SHOW PARTITIONS
database:describe
table:describe
database:DESCRIBE
table:DESCRIBE
SHOW TABLE EXTENDED
database:describe
table:describe
database:DESCRIBE
table:DESCRIBE
database:LIST_TABLE
SHOW TABLES
database:describe
table:describe
database:LIST_TABLE
database:DESCRIBE
SHOW TBLPROPERTIES
database:describe
table:describe
database:DESCRIBE
table:DESCRIBE
SHOW VIEWS
database:describe
table:describe
database:LIST_TABLE
database:DESCRIBE
