- Getting Started
User Guide
- Overview
- Resource Management
Application Management
- Creating an Application
- Modifying an Application
- Deleting an Application
- Creating a Component
- Modifying a Component
- Deleted a Component
- Creating a Group
- Modifying a Group
- Deleting a Group
- Transferring Resources
- Viewing Resource Details
- Viewing Capacity Rankings
- Multi-cloud Configurations
- Cross-Account Resources
- Resource O&M
- Automated O&M
- Faults
- Change Management
- Resilience Center
- Task Management
- Basic Configurations
- Viewing Logs
- Best Practices
- API Reference
- Product Consulting
- Resource Management FAQs
FAQs About Resource O&M
Patch Management FAQs
- Why Can't I Select a Node?
- Automation FAQs
- Batch Operation FAQs
- FAQs About Fault Management
- Resilience Center FAQs
- Change History
On this page
Show all
Modifying a War Room Rule
- Log in to COC.
- In the navigation pane on the left, choose Incident Management > WarRoom. Click WarRoom Rules.
Figure 1 War room rules
- Locate the war room rule to be modified and click Modify in the Operation column. Enter the rule name, select the region, application, incident level, and group information, and click OK.
Figure 2 Modifying a war room rule
- After the modification is complete, you can query the modified rule in the rule list.
Parent topic: WarRoom
