Updated on 2025-08-08 GMT+08:00
Overview
With the transformation from traditional IT infrastructure O&M to cloud service O&M, traditional O&M methods face challenges such as complex inter-service invoking, fast application iteration, massive O&M objects, and complex non-linearity systems. Service downtime will bring huge economic losses and reputational damage to the company.
Chaos engineering is introduced to the O&M process. Through periodic simulation, system weaknesses (such as software bugs, solution design defects, and fault recovery process points) can be identified before problems occur on the live network, and system availability problems can be detected and resolved in a timely manner, continuously improve application resilience and build O&M confidence. For unavoidable scenarios (such as hardware faults, abnormal server power-off, and network device board faults), formulate a contingency plan for quick fault recovery in advance.
COC allows you to perform automatic chaos drills covering from risk identification, emergency plan management, fault injection, and review and improvement. Based on years of best practices of Huawei Cloud SRE in chaos drills, customers can proactively identify, mitigate, and verify risks of cloud applications, continuously improving the resilience of cloud applications.
Chaos Drill Function Introduction Video
Image and Disruptor Version Support Statement
Currently, the chaos drill feature supports probe attack objects such as Elastic Cloud Servers (ECSs), FlexusL instances, and Bare Metal Servers (BMSs), and provides corresponding resource and network disruptors for you to drill. Probe disruptors include disruptors for practicing, host resources, host processes, and host network modules. By integrating disruptor modules and functions, you can accurately simulate faults in the actual environment and detect system availability issues as early as possible, continuously improving application resilience.
The following table lists the ECSs, FlexusL, and BMSs image versions and supported probe tools.
CentOS 6.10 images and earlier versions do not support some probe disruptors because the system does not have the shared libraries (GLIBC_2.14 and GLIBCXX_3.4.15) required for running corresponding probe packages.
Table 1 lists the probe disruptors supported by each ECS image version.
Table 1 ECS and disruptor compatibility list
Disruptor
Supported Image Version
Disruptors for practicing
Qualifying practice
CentOS 7.2, CentOS 7.6, CentOS 7.9, CentOS 8.2, Ubuntu 16.04, Ubuntu 18.04, Ubuntu 20.04, Ubuntu 22.04, EulerOS 2.2, EulerOS 2.5, EulerOS 2.9, EulerOS 2.10, Debian 8.2.0, Debian 8.8.0, Debian 9.0.0, Debian 11.1.0, and Huawei Cloud EulerOS 2.0
Host resources
CPU usage increase
Memory usage increase
Disk usage increase
Disk I/O pressure increase
Host process
Process ID exhaustion
The process IDs of the EulerOS image are used up. The protection mechanism may be triggered, causing the kernel to restart. As a result, the drill fails.
Killing a process/Continuously killing a process
Host network
Network latency
CentOS 7.2, CentOS 7.6, CentOS 7.9, Ubuntu 16.04, Ubuntu 18.04, Ubuntu 20.04, Ubuntu 22.04, EulerOS 2.2, EulerOS 2.5, EulerOS 2.9, EulerOS 2.10, Debian 8.2.0, Debian 8.8.0, Debian 9.0.0, Debian 11.1.0, and Huawei Cloud EulerOS 2.0
Network packet loss
Network error packets
Duplicate packets
Network packet disorder
Network disconnection
NIC break-down
If the NIC becomes faulty, the UniAgent may go offline. As a result, the UniAgent information cannot be received, and the page fails to be displayed.
DNS tempering
Port occupation
Server disconnection
If the server becomes fault, the UniAgent may go offline. As a result, the UniAgent information cannot be received, and the page fails to be displayed.
NIC bandwidth limiting
Connection exhaustion
Table 2 lists the probe disruptors supported by each BMS image version.
Table 2 Bare metal server image and tool compatibility list
Disruptor
Qualifying practice
CentOS 7.3, CentOS 7.9, Ubuntu 16, Ubuntu 1804, and EulerOS 2.3
Host resources
CPU usage increase
Disk usage increase
Host process
CentOS 7.4, CentOS 7.9, Ubuntu 16, Ubuntu 1804, and EulerOS 2.3
Host network
Network latency
Network packet loss
Duplicate packets
NIC break-down
DNS tempering
CentOS 6.9, CentOS 7.9, Ubuntu 16, Ubuntu 1804, EulerOS 2.3, and EulerOS 2.9
Port occupation
CentOS 6.9, CentOS 7.4, CentOS 7.9, Ubuntu 16.04, Ubuntu 18.04, EulerOS 2.3, and EulerOS 2.9
Table 3 lists the probe disruptors supported by each FlexusL image.
Table 3 FlexusL instance images and probe tool compatibility list
Disruptor
Qualifying practice
CentOS 7.2, CentOS 8.2, Ubuntu 16.04, Ubuntu 22.04, EulerOS 2.0, Debian 8.2, and Debian 11.1.0
Host resources
CPU usage increase
Disk usage increase
Host process
Host network
Network latency
CentOS 7.2, Ubuntu 16.04, Ubuntu 22.04, EulerOS 2.0, Debian 8.2, and Debian 11.1.0
Network packet loss
Duplicate packets
NIC break-down
DNS tempering
Port occupation
