Updated on 2025-09-17 GMT+08:00
Handling Alarms
After an aggregated alarm is generated, you can quickly handle it on COC and apply the response solution using jobs or scripts.
Precautions
Only the owner can handle the current alarm.
Handling Alarms
- Log in to COC.
- In the navigation pane, choose Fault Management > Alarms.
- Choose Aggregated Alarms > Unhandled Alarms.
- Select the alarm to be handled and choose More > Handle in the Operation column.
- Configure information in Task Type.
- If you select Contingency Plans, select the corresponding contingency plan from the drop-down list. If there is no desired contingency plan, click Create. For details, see Creating a Custom Contingency Plan.
- If you select a document-based contingency plan, you can view the name and description of the contingency plan step. No operation is required.
- If you select an automatic contingency plan, you need to set a contingency plan to be executed. Based on the handling mode (custom script, public script, custom job, or public job), perform the remaining steps by referring to Executing a Custom Script, Executing a Public Script, Executing a Custom Job, or Executing a Public Job.
- If you select Scripts, perform subsequent steps by referring to Executing a Custom Script or Executing a Public Script.
- If you select Jobs, perform the subsequent steps by referring to Executing a Custom Job or Executing a Public Job.
- Click OK.
The alarm is handled.
